Question about Toshiba MK3276GSX 25 inch 320GB 5400RPM SATA Internal Hard Disk Drive SATA II Hard Drive
Toshiba MK3276GSX 320GB SATA driver
Floppy driver
2 Suggested Answers
johncorde40110
  • 720 Answers
SOURCE: my Toshiba mk3276gsx is a 320gb but it is only reading 127
Sounds as if you have not formatted this to ntfs instead of fat32.
Posted on Dec 07, 2014
My Toshiba mk3276gsx is a 320gb but it is only reading 127
Dec 06, 2014 | Toshiba Computers & Internet
Toshiba hdd
As far as I know it is not possible to remove a password from a hard disk. In some cases a manufacturer may be able to help, however, for security reasons I'm not sure they would.
Mar 18, 2014 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
Cannot install windows xp after formating
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you should go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
if you need more help with this or if i have misunderstood the problem
post a reply
hope this helps you
Sep 06, 2011 | Toshiba MK3276GSX 25 inch 320GB 5400RPM...
Toshiba Portege M400-S4031 Windows XP replaced hard drive SATA used restore cd from Toshiba after loading setup screen says finished and to restart but when restarted computer error (can not find hard...
.Thats because your restore cd does not contain the Sata driver. Go to toshiba site and find the sata driver. You will need a floppy drive (a usb one would be good). Burn the driver to a floppy and load it into the drive. Now when you start to install the restore cd at some point near the beginning you will need to tap F6 (it tells you at the bottom of the screen) which tells xp to look at the floppy. It will install the driver and continue installing xp. simples??
May 16, 2011 | Toshiba Portege M400-S4031 Notebook
MY TOSHIBA HARD DISK MK3265GSX 320GB CANNOT DETECT TTO MY PC
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 13, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
I have a Toshiba Tecra S3 laptop with a standard Toshiba SATA hard drive (MK6032GSX rv. AS311G). It was a corporate hand me down. It is in dire need of a re-format due to age and virus but when I try it...
Windows XP does not have the SATA driver on the install CD.
You need to download the SATA driver for your model laptop from the Toshiba WEB support/download page.
If the laptop has floppy drive, then copy the SATA driver to the floppy and when you boot up with the Windows XP install CD and then press F6 to install the SATA drivers which is on the floppy as instructed..
Oct 30, 2009 | Computers & Internet
Problem installing windows
you dont need SATA controller drivers..that F6 function is only if you are going to use a RAID setup. That is where you hook up multiple SATA drives in series..So don't hit f6 and just install
Oct 10, 2009 | Acer Aspire X1200 Desktop PC - Athlon X2...
I can not install windows XP on Toshiba Satellite U300, windows
You must have latest Windows Xp CD .
Latest Motherboard chipset does not recognise hard disk without proper sata raid or sata driver. So you can install sata driver if u have USB floppy drive by downloading latest Sata raid to floppy. At the time of installation you will see a message press f6 to if u need to install raid driver.then press f6 asking for floppy drive and floppy insert press enter to continue.
Jun 27, 2009 | Microsoft Windows XP Professional With...
Toshiba MK3276GSX 25 inch 320GB 5400RPM SATA Internal Hard Disk Drive SATA II Hard Drive Logo
229 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
