Question about Zynga Texas HoldEm Poker
WMessage Code: CA5hat's your problem?
TAB Service Code
check all safety circuit devices should have voltage both sides no voltage on 2nd side bad component water pressure switch see if copper line is plugged or loose wires
Jun 03, 2013 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
How to unlock my Nokia 5030 without using menu button?
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Jan 13, 2013 | Nokia XpressRadio 5030 Cell Phone
I have a facebook problem where the webpage doesnt open . It says error on page.
Proposed solution: uninstall Google Chrome Frame
I discovered the pb yesterday, trying to connect to Facebook on my XP SP3 Win32 desktop that runs fine, but on which I rarely connect to Facebook, so that I don't know for how long the problem has been here (days, weeks, but no more)
I struggled in various forums to find hints others than "use Chrome or Firefox" etc...
I finally found the solution hidden in:
http://blog.crosbydrive.com/?p=310
After uninstalling Google Chrome Frame, I just had to quit IE and launch it again.
Many thanks to "Lexington Computer Repair Blog " and Sue W (who hold the solution from a Facebook forum)
May 07, 2012 | Facebook Social Network
I need an unlocking code for my Sony Ericsson Xperia E15i
How to use the Unlock Code (This will be emailed along with your codes)
Sony Ericsson E15i Xperia X8 sony_ericsson.gif sony_ericsson-e15i_xperia_x8.gif
How to enter the Unlocking Code for a Sony Ericsson Model phone General Information about your Sony Ericsson unlock code
When you receive your email with your unique Sony Ericsson unlocking codes, you may see there's actually more than one code, as some models require more than one code to unlock them fully. However, for simplicity, we do aim to send you a single unlock code, which will be your network unlock code (known as the NCK).
(See below for more details about code formats and more - Please read all before you start unlocking?)
Option 1 - Sony Ericsson Models
1. Turn on the phone without SIM Card in it
2. Press the 'left arrow' or joystick left once
3. Press the * (Star) button twice
4. Press the 'left arrow' or joystick left once
5. The phone will display one of either messages saying 'Personalize with MNC2' or 'Personalize with MNC3'
6. Wait approximately 5 seconds.
7. The phone will display 'Network' and a picture of a closed padlock.
8. Press Select.
9. The phone will display 'Unlock (Net) 5' and 'NCK:'
10. You can now enter the Unlock Code provided.
Option 2 - Sony Ericsson Models
5. The phone will display the message 'Personalize with MNC2'
6. You can now enter the Unlock Code provided.
Note for options 1 & 2
- When doing the first 5 steps above you'll need to do it quite quickly. - If your phone has a joystick 'JOGDIAL' you must press the 'down arrow' instead of the 'left arrow' in steps 2 to 3 above. By 'Down Arrow' we mean move the joystick down
Quick Glossary
NCK = Network lock
SPCK = Service provider corporate lock
SPK = Service provider lock
Code formats you may receive for Sony Ericsson models:
Wherever possible we'll try and send you just a single unlocking code to unlock your Sony Ericsson.
However for certain models we may need to send you more than one code, even if you don't use them all.
It would be a sting of codes as per this example:
CCK: 0984118391686835 or 0984118391686835
ESCK: 0000000000000000 or 0000000000000000
NCK: 4176979876474847 or 4176979876474847
NSCK: 3908320398047435 or 3908320398047435
PCK: 2061751224321908 or 2061751224321908
SPCK: 9960493992337231 or 9960493992337231
Note: The NCK (Network unlocking code) is the main and usually the only one you'll need.
Please note:
- If you see the message 'NCK: (0)' or 'Not Allowed', this means the phone is hard-locked. The phone cannot be unlocked because there has been more than 5 wrong unlock attempts.
- If your Sony Ericsson has a Joystick, then you must press the DOWN Arrow instead of the LEFT Arrow. DOWN Arrow meaning Joystick downwards
May 30, 2011 | Sony Ericsson Cell Phones
Phone locked an don't know the code... never set one up!
Let me give you a little background and then some solutions. This is generic because I don't know your carrier. I'm using ATT as an example.
Phones are naturally unlocked, but a service provider might lock them
When originally manufactured, all GSM cell phones are unlocked. That is, they can be used with any SIM from any cellphone service provider - always assuming, of course, that the cellphone service provider has compatible GSM service on the same frequency bands that the phone can operate on.
Most cell phone service providers electronically 'lock' the phone so that it can only be used with their service. There are obvious reasons why they choose to do this - in particular, to force you to pay what are usually very high roaming charges when you take your phone out of their network and use it elsewhere in the world.
Fortunately, this locking is reversible. With some phones, it is possible to simply enter an unlocking password code into the phone and it is immediately then unlocked. Other phones need to be connected up to a special unlocking data terminal.
Your phone has to be unlocked by the carrier. LG, Motorola, Sony Ericsson, Nokia and most of their ilk, will not give consumers the unlock codes but don't despair.
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from your carrier. For example, if you have AT&T to unlock your SIM card, you can obtain your phone's PUK code from AT&T by:
● logging in to your my wireless Account online
● using their Technical Support Chat
● calling Customer Care at 1-800-331-0500
To get your phone's PUK code online from ATT:
● Log in to your my wireless Account.
● Select My Services under My Account.
● From the My Services screen, select My Phone/Device.
● Select Unblock SIM Card.
● The Unblock SIM screen will display your PUK code.
Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code.
Note: If you enter the wrong ATT PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator."
There are three other ways to unlock a phone:
● The carrier will unlock the phone for you at one of its retail outlets;
● You can do it yourself by clicking on this link Free Unlock Codes ,
● Pay $3.89 at the following website: www.theunlockshack.com/. I have absolutely no affiliation or relationship with The Unlock Shack or its principals.
I trust that this is helpful and solves your problem. All the best
Ben
May 28, 2011 | Casio G''zOne Type S Cellular Phone
Lg phone model#AX155 need unlock code
Ben
May 27, 2011 | Cell Phones
I forgot got the unlock password and i clicked on 'forgot password', it told me to type in my email and password, it told me they were incorrect. how do i get into my phone?
Ben
May 25, 2011 | Cell Phones
How do I do factory reset of my motorola i9 phone
It sounds as though you don't have a password. If you don't the phone must be unlocked.
Let me give you a little background and then some solutions. This is generic because I don't know your carrier. I'm useing ATT as an example.
Your phone has to be unlocked by the carrier. LG, Motorala, Sony Ericsson, Nokia and most of their ilk, will not give consumers the unlock codes but don't despair.
● logging in to your myWireless Account online
● Log in to your myWireless Account.
May 23, 2011 | Cell Phones
SCREEN SHOWS PHONE LOCK AND HAVE FORGOTTON CODE HELP PLEASE
Let me give you a little background and then some solutions. This is generic because I don't know your carrier. I've used ATT as an example.
logging in to your myWireless Account online ● using their Technical Support Chat ● calling Customer Care at 1-800-331-0500
Log in to your myWireless Account. ● Select My Services under My Account. ● From the My Services screen, select My Phone/Device. ● Select Unblock SIM Card. ● The Unblock SIM screen will display your PUK code.
Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code. Note: If you enter the wrong ATT PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator." There are three other ways to unlock a phone:
The carrier will unlock the phone for you at one of its retail outlets; ● You can do it yourself by clicking on this link Free Unlock Codes , ● Pay $3.89 at the following website: www.theunlockshack.com/.
May 21, 2011 | Cell Phones
Hi my name is ibrahim,im from Malaysia,can you help me to unlock my Nokia c3-00,i cannot find the restriction code,can you help me? my imei:353760047875317 my email:Kikaigizmo@yahoo.com please help...
If your Nokia mobile phone displays Phone Restricted with an Undo option and selecting Undo results in an Enter Restriction Code error, your Nokia mobile phone is Network Locked. This means your Nokia mobile phone has been restricted for use on one specific network and a Restriction Code or Unlock Code must be entered before the phone can be used with alternative networks.
The good news is that you can eradicate the annoying 'Phone Restricted' and 'Enter Restriction Code' errors simply by unlocking the phone with a Nokia restriction code from Unlocks. You can get restriction code for ANY Nokia mobile phone displaying the 'Phone Restricted' and 'Enter Restriction Code' message from only £12.50! You just clik on the following link
http://www.unlocks.co.uk/enterrestrictioncode.php
May 05, 2011 | Computers & Internet
Zynga Texas HoldEm Poker Logo
130 people viewed this question
Top Zynga Facebook Apps Experts
 Grubhead
Grubhead
Corne Viljoen
Are you a Zynga Facebook App Expert? Answer questions, earn points and help others
