Question about Kenmore Washing Machines
Kenmore Series 70 Model 110 works fine in the Heavy setting, but will not agitate in the Normal or Delicate settings.
  • 3 more comments
  • Bruce Anderson Dec 04, 2012
    1104760292
  • Richard Roth
    Richard Roth Dec 04, 2012
    OK, if it works fine on the delicate setting but not in the other settings you will need to replace the timer. Here is the part to order.http://bit.ly/TLYprT
  • Bruce Anderson Dec 05, 2012
    Thanks. It works only on the Heavy Duty setting. The timer was replaced and the problem remains.
  • Richard Roth
    Richard Roth Dec 05, 2012
    Something isn't right. I would check all the wiring connections to and from the timer.
  • Bruce Anderson Dec 09, 2012
    I spent the weekend with my series 70. I pulled the wiring connectors off both ends of the harness and sprayed them with electrical contact cleaner. The washer still works on the Heavy Duty setting. The washer fills on the Normal and Delicate settings with the agitator starting on the Normal wash with Medium and Full water levels. It will agigtate from the 10 min mark until the 6 min mark and stop with the timer still humming until it reached the rinse and spin cycles which work normally. The Delicate/Permenant Press cycle will not agitate at all.
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Dec 03, 2012
  • 113 Answers
SOURCE: Kenmore 70 series Agitation and Spin Cycyle clicking
Sounds like you have a broken motor coupler. Not expensive. #13 on the diagram. Part # 285753, dave www.washermd.com
Posted on Dec 16, 2008
SOURCE: kenmore 80 series modej # 110 20842 990
Problem solved with a new washer
thanks
TheMobilian
  • 8220 Answers
SOURCE: 70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Posted on Mar 27, 2009
SolutionGuy
  • 331 Answers
SOURCE: What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
Posted on May 02, 2009
SOURCE: Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Posted on Jun 17, 2011
I have the kenmore heavey Duty 70 series 92273100 Model 110 that we just moved. Was working fine before. Now it won't stop filling, overflows, and doesn't go into wash cycle. It will only s
either the pressure switch is bad or the pressure switch hose from the wash tub to the pressure switch is kinked or plugged so air pressure cant reach switch and operate switch,remove hose at tub and blow into it and see if machine now operates,if not the switch is bad
Feb 19, 2012 | Washing Machines
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
My Kenmore 70 series is 18 years old. It will not
Hello. Since your machine is 18 years old and the agitation/spin is costly to repair I would definitely recommend a replacement washer.
Jul 06, 2009 | Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Bottom portion of agitator works, the top portion does not
Pry the agitator top off with a screwdriver (in the little slot provided)and remove the part with a 7/16" socket. Lift out the top part of the agitator and replace the four plastic dogs with parts from RepairClinic.com http://www.repairclinic.com/Appliance-Parts?s=t-110.82870820-%3d%3dc201 for $4.95 plus shipping.
I am replacing mine for the second time in 18 years. John
Jun 05, 2009 | Kenmore Washing Machines
Kenmore 70 series 110 washer won't drain or spin, but agitates
You have a broken lid switch. Check to see if the switch is broken off of the two screws that hold it under the lid. If it is, get a new one, take off the case and replace old switch with the new one.
Apr 06, 2009 | Kenmore 24932 Top Load Washer
Kenmore series 80 washer only works on heavy duty cycle.
bad transmission,,check voltage...below 110 with load and water pressure switch or hose defective..
Dec 24, 2008 | Kenmore 24902 Top Load Washer
No agitation in the delicate and regular modes.
does you washer have a delicate, or normal speed adjustment switch, if it does make sure its not between setting or it will sound like a machine gun......you may need to replace that switch
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Dec 12, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
105 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
