Question about Pioneer PD-M426 6-Disc CD Changer
Replacement for Pioneer PD-M450 CD Player
Lens has fallen out and I was told it is cheaper to replace unit than to have it repaired.
4 Suggested Answers
Duncan
  • 218 Answers
SOURCE: Pioneer PD-M430
If you can't put it back then the laser unit is no good anyway so it may be worth a try. I would not recomend super glue because it outgasses a substance that may cloud the lens. (that is how they use super glue to get finger prints from objects) Maybe use a thin film (very thin film) of rubber cement very carefully applied to the edge of the lens would do the trick. You must act fast because rubber cement cures so very fast. Another possible glue would be epoxy. It would give you a little more time before it starts to set up. Be sure you have the correct side up when you attach the lens, and be SURE that it is well seated in its socket so that you don't screw up the focus of the laser. Do a dry run or two with no glue to get the feel of what it takes. Don't forget to clean the "inside" side of the lens before you glue it in. You can clean the outside once it is glued in place. If all else fails you still are in a situation where you have to change out the laser assembly. Nothing ventured, nothing gained. Good luck.
Posted on Jun 10, 2008
SOURCE: Pioneer PD-M501 6-CD Player manual and what magazine cartridge
The standard cartridge for the Pioneer PD-M501 is the Pioneer JD-M300 6-disc magazine, and you can find them at Amazon.com for $25 new. The JD-M300 fits a lot of different brands of CD players, not just this particular brand and model. And here's a link to a copy of the owner's manual: http://www.scribd.com/doc/22613342/Pioneer-PD-M601-M551-M501
Posted on Jul 10, 2010
40longyears
  • 275 Answers
CDs go in the Upside Down position. Your PD M501 will accept PRW 1139, PRW 1141 and 163.
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM
Posted on Feb 28, 2011
Pioneer PD-M550
The player have problem with the laser pickup unit.
Try one thing, there is a disc available for cleaning the laser pickup unit (). You will get in any cd shops(instructions will come with it). Buy the cd and the insert it in any one of the tray. It will clean the laser unit if there is any dust in it. After cleaning put a disc and check is the problem remains. If the problem remains the you have to change the laser pick up unit. You can fin a link here which will lead you to the laser pick up unit. You will get the part only against confirm order.
PEA1030
Laser cleaning CD
Ajin
Jul 24, 2012 | Audio Players & Recorders
Pioneer PD-M40 changes through all 6 cds but does not stop to read any of them
The laser pickup assembly is at the end of life, remove top to expose the laser lens, use a Q-Tip and rubbing alcohol and gently clean, allow several minutes to dry, if no change! far cheaper to replace the cd changer.
Jul 02, 2012 | Pioneer PD-M603 6-Disc CD Changer
Player not reading disc , what could it be
Hello
Just clean the laser pickup unit lens, by inserting a disc cleaning disc. this disc an be bought from most of the electronics spare part selling shops at your town. If it doesn't help you, there is no other way than replacing its Laser Pickup Unit with same type and number. OK.
Jan 15, 2012 | Pioneer PD-F507 25-Disc CD Changer
also:
BMW 740 OEM
May 15, 2010 | Pioneer PD-M603 6-Disc CD Changer
My Pioneer PD-TM1 18 Disc player reads through all three disc magazines searching on each individual CD disc one at a time, and then will not play any one of the disc?
Seen alot of these "drop" the laser lens inside the unit! Have had some luck glueing the lens back on using radio/tv cement. Don't try super glue or it will ruin the lens! No luck replace the laser!
Apr 12, 2010 | Audio Players & Recorders
Turned on my Pioneer PD M501 one day and it would not play. Disc tray will not retract into cartridge and cartridge will not eject.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams.
Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
BMW 740 OEM and others.
Feb 18, 2010 | Pioneer PD-M603 6-Disc CD Changer
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
Many Magnavox, Denon, JVC,
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
Have a pioneer cd player model number PD-Z560T. Has started making my cd's jump while i'm playing them.Have tryed cd lens laser cleaning disc but still no good any ideas?
My cd unit on the pioneer pd-z560t also jumps. I also tried lens cleaner, with no luck.
It was suggested to me that cleaner is only any good for a good - but dirty - lens, but no good if the lens has actually deteriorated and become weak.
I would be curious to know how a lens could actually deteriorate pls.
plese try to reply to: clerical@live.co.uk
Thanks
Andy
Nov 01, 2009 | Audio Players & Recorders
Pioneer PD-M423 CD player will no longer read CD's. For each CD, I hear either a high-pitched buzz for a few seconds, or 3 clicks, then it moves on to try the next CD. Unit was recently moved several...
Have the same problem. Had friend, electronic tech look at it. Pickup assembly failure. Use Partstore.com or Pioneer to find part and then cross reference with other models that use same part. I bought used item on Ebay, $40 to repair my unit. Simple 5 screws, two pug in cables. Be sure to discharge static electricity from body before touching interior parts. Up and running in 20 min,
Dec 30, 2008 | Pioneer PD-M423 CD Player
Pd-m403 cd player skips thru all six cds (they are oriented correctly) without playing any selection, then get a message "no disc"
Hi there
Sure you can.for 12 years I was a prefferred service agent for Pioneer. I have repaired dozens of these units with this problem. It has been happening since they came up with the six disc changer mech. The Pioneer preferred way is to replace the optic, set the diffraction grating(not an easy task without the right gear) and mechanical alignment of the new optics. DO NOT USE CYNOACRYLATE BASED GLUES This is super glue. the fumes will cloud the lens and render it useless, I use Tarzan's Grip, a clear general purpose repair glue,used for say china,metal plastic etc.
  • I always make sure that the lens in orientated the same way as it came out. You can usually tell by the glue marks on the sides of the lens and the holder it seats into.
  • Refit the lens, then dab the sides of it and the holder, don't get too carried away.
  • I use at least 3-4 dabs about the sides of the lens, but don't put it under the lens before you seat it .
  • I then put something on top of it for at least 12 hours till the glue sets. then hopefully if all went as planned, it should again work.
I used to always check focal offset and tracking offsets, and tweak also the RF pattern to refocus the repaired assembly. You do need test gear to do that, but generally, the player will work if the lens is seated correctly and secured properly. Happy to talk to you more about my experience doing this job,or answer any questions about it.
regards
robotek
Nov 14, 2008 | Pioneer Audio Players & Recorders
Pioneer PD-M426 6-Disc CD Changer Logo
88 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
