Question about Ovens
GE oven JKP26GOP2BG wont heat
The bottom oven that is controlled by the rotary knobs works fine. The top oven operated by the touch pad will not heat. When you set the temprature and start the oven it waits a few seconds and indicates that it has reached the proper temp but neither element gets hot.
    President:
  • Ovens Master
  • 1,922 Answers
Either the temp sensor probe in the oven cavity it open/shorted or way off scale and telling the control board the units up to the temp set point,theres a way to test these with an ohm-meter for resistance at certain temperature but i dont have the chart for that test,it may be inside the unit if you can locate it
Posted on Dec 03, 2012
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    SOURCE: Top oven will not heat up
    Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
    Posted on Jan 06, 2008
    aborcass
    • 2651 Answers
    SOURCE: GE Profile -Installed wall oven - won't heat
    brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
    Posted on Mar 30, 2008
    SOURCE: GE JTP56 double oven controls OK top OK bottom no heat
    have you inserted the business card as described in the solutions?
    Posted on Jun 28, 2009
    • 291 Answers
    SOURCE: Oven doesn't reach temperature setting
    It could be the plug/receptacle that the element plugs into. It could also be that the elements have separate thermostats and that the one for the lower element is bad. If you can post the model number I can look at the electrical schematic and know for sure if it has one or two thermostats.
    Posted on Aug 31, 2009
    GE JKP26Gop2bg
    If the oven is 23 years old, it could be time to replace it.
    May 20, 2017 | GE Ovens
    I recently ran the self-clean option on my GE Profile JK955B0F5BB. Now when I set the touch pad to 350 degrees or more, the oven heats up to beyond 500.
    That is not a valid model number, the issue is most likely the thermostat has failed. The part is about 12 dollars.
    Jan 07, 2017 | GE Ovens
    Cannot get the top part of my double oven to heat nor broil. The oven model is JKP26GOP2BG GE appliance. I have check voltage going to the oven and it 240 VAC and ohm the elements and they checked fine. ...
    the thermal control has failed
    http://applianceguru.com/forum1/18946.html
    check here
    perhaps as you get 126vAC ?? strange its half the supply volts
    perhaps a missing something
    i think your elements are in series or a missing nutral ???
    each will measure 126 this way
    you can atleast check the sensors resistance
    mesure from nutral at the mains to each element point
    did you disconnect the elements then test there resistance
    even getting 126v they will heat .. half up....
    so something isnt right
    hope i can help
    Dec 09, 2014 | GE Ovens
    How do I set the clock
    Set the clock by following these steps: a). Touch TIME pad. b). Turn rotary knob clockwise until CLOCK appears. c). Touch TIME pad. d). Turn rotary knob in either direction. The time displayed will change in 10-minute increments and indicate AM or PM. Turn the knob in the opposite direction and the display will change in one-minute increments. e). Touch TIME pad. The clock is now set. in some units there is button instead of knob in that case the clock indicating button has to be pressed . This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
    Feb 06, 2010 | Bosch Appliances 27 in. Wall Oven Electric...
    F7 Error on GE Profile electric oven. No response from keypad.
    The F7 error code on your oven indicates the touch pad has failed. To repair it, you will need to replace the touch pad which is listed as a control panel.
    If you do the repair yourself, disconnect the power to the oven. Take the 3 screws out above the door that holds the control panel on to the oven. Pull the control panel out at the bottom and lift it up, then pull out the top and drop it down so you can see the back side of the control panel, and you will see a ribbon connector going from the touch pad to the electronic oven control (ERC).
    There is a latch holding the ribbon connector to the ERC, raise the latch to release and pull the ribbon out of the ERC.
    Replace the part and reverse these instructions to replace the control panel.
    Hope this helps.
    Thanks for using Fixya.
    Dec 15, 2009 | GE Ovens
    Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
    Instructions required
    I have a GE double oven. JKP44G with touch pad controls
    Top oven door will not lock for cleaning cycle. I think I need a new motor for that.
    Bottom oven will work sometimes and other times when I turn it on and select the temperature, thinking it is coming on - all of a sudden the temp light goes out like the oven is off and the oven does not heat. Sometimes I touch the clear button and then turn it on. Sometimes it works and other times not.
    Could the connections in the control panel be dirty and not making connection at times?
    Main question. How do I get to the control panel. How can I pull the oven out to clean the circuit or connectors and change the door motor. If I could just get into the panel I feel I could fix it.
    Nov 14, 2008 | Ovens
    Nov 14, 2007 | GE JKP45 Electric Double Oven
    Ovens Logo
    137 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
