Question about Canon PIXMA MP780 All-In-One InkJet Printer
Printer error 6a81 comes up on my printer - Canon PIXMA MP780 All-In-One InkJet Printer
How can I fix an error msg #6A81 on the Pixma mg5320?
Error 6A81 is described here: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#5011
Description
A printer error has occurred.
Resolution
  1. Turn off the machine and unplug the power cord from the power supply.
  2. Plug the machine back in and turn the power on.
    NOTE- If you disconnect the power plug, all the faxes stored in the machine's memory are deleted.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility.
Feb 19, 2016 | Canon PIXMA Office Equipment & Supplies
Canon printer error code 6A81
Solution 1: This is a purge unit error.
There maybe something jamming the purge unit or just a absorber out of place which is picking up on the carriage preventing it from moving correctly.
Try to move the carriage away from the purge (its where the printhead/carriage parks its self on the right side of the machine) with no resistance then you can shine a torch into the machine and look at the purge unit.
There maybe crumpled paper jammed in the purge.
If all looks well, the purge unit may be defective and had to be replaced.
Solution 2:
The wiper on the purge may have stuck. It slides back and forth and they have been known to stick.
Push it with a long screwdriver to see if it moves.
Solution 3:
Something is blocking the printer inside. It could be a paper jam or a foreign object.
Check using a flashlight, to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen.
If there is nothing obvious, unplug the printer power supply.
Dec 02, 2015 | Canon PIXMA MX882 Wireless All-in-One...
5220 quit. says "turn off and on"-no fix. Says "see manual"-no info. Shows "6A81 on top of screen. Error Code?
6A81 means the carriage is blocked by something. Start by checking the following image to verify there are no paper jams.
http://ww2.justanswer.com/uploads/wa94sound/2012-04-25_230949_sdf.png
Reply back and let us know what you find.
Feb 19, 2015 | Office Equipment & Supplies
Error 6a81
Turn off power, remove power cord and wait 10 minutes, then reconnect power cord and turn unit on, if this does not work then advised to contact canon service centre
Apr 28, 2014 | Canon Office Equipment & Supplies
I need specification of laser jet color printer
way of for the solution of if printer ix6560 kluar of code error 6a81
as step to do.
Oct 31, 2013 | Canon Office Equipment & Supplies
Error 6A81 from canon ip 4840 printer thanks
hi
head cleaner must be service, immediatly head cleaner press down then close door printer will be ready enjoy it
Jun 19, 2011 | Office Equipment & Supplies
Canon PIXMA MP780 All-In-One InkJet Printer Logo
339 people viewed this question
old marine
old marine
