Question about GE WVSR1060A Top Load Washer
Ge 7 cycle wcxr1070t5ww agitator will not agitate, however it does spin on the spin cycle My GE wcxr10707 does not work in the washing cycle howevwer th motor is perfect because spins perfectly
    Genius:
  • 1,239 Answers
Hi
i have bad news, to me it sounds like your transmission is shot. reason i say that, its spins ok, it drains ok, but will not agitate.....the really bad sign is the oil leak.
the reason its causing the lights to dim, is the motors trying to turn the transmissions shaft, its got a seized gear, and causing the motor to draw too much current, be careful not to let that happen too often for too long, or else you'll be replacing the motor as well
the transmission could cost anywhere from $80 - $150....depends where you get it. if you need any help with the install, hit me up!
  • Drive belt could be worn out--see above.
  • On the Whirlpool/Kenmore dual action agitator, the agitator dog cam assembly or drive spindle could be worn out. If the agitator just wobbles around when you turn it by hand, you need toreplace the dog cam set.
  • The timer contacts for the agitate cycle could be fried. Time to blow the dust off that meter and read that wiring diagram.
  • On belt-driven Whirlpool/Kenmores: wig-wag plunger/lifter or transmission mode lever could be worn out. You'll need to look at the action of the agitate solenoid when the machine is in the agitation part of the cycle. If the plunger/lifter slips off the transmission mode lever, replace either the plunger/lifter or the mode lever, as appropriate.
  • On Maytags only: the lid switch could be fried. (Other brands will still agitate with a bad lid switch.)
  • Pressure switch is fried. You'll need to ohm out the contacts on it. How you gonna know what you're looking for in the contacts if you don't use the wiring diagram, too?
  • The air tube connecting to the pressure switch is pinched or you pulled it off by accident when you where tearing the thing apart because you didn't have a clue about what you we
Posted on Jan 11, 2009
  • 700 Answers
Sound like the dogs that make it wig wag need replacing, they are inside the middle of the drum. they are real inexspensive and easy to replace.
    Sergeant:
    Novelist:
  • 326 Answers
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
http://www.repairclinic.com/0088_11_1.asp#Level1_3
click the link for more help
    Brigadier General:
  • 8,619 Answers
Hi!
Thanks
Rylee
  • 1 more comment
  • Rylee Smith
    Rylee Smith Jan 11, 2009
    Also, the inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the transmission spline.
  • Rylee Smith
    If your socket is corroded then use 1/2" drive extension. This 1/2" is not the socket but the size of the square shaft the socket mounts onto.
    Thanks
    Rylee
  • Rylee Smith
    This also happens usually when the motor is not lined up right on the peg wall, check if the motor clips are very hard to put back on. One or more of those little alignment pegs on the back of the motor are not seated in the hole.
GE Washer WWSR3090T8WW does not agitate
Sounds like a transmission failure to me?
Good Luck !
Feb 10, 2010 | GE Washing Machines
GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
Tell me more Is there voltage to motor? The transmission makes it agitate .
May 28, 2009 | GE WBSR3140DW Top Load Washer
Agitater problems will not agitate
To Reset computer. Unplug for 2 minutes, plug back in, open and close lid 7 times slowly to reset computer. This should solve your problem.
May 09, 2009 | GE WBSR3140DW Top Load Washer
Will not go in to spin cycle
Remove agitator (it will pop off when pried) then you will find your answer. Mine was a broken tub collar to shaft.
Washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
coupling between motor and drive assy broken. take motor loose and you can get it out. Visual check first to see if motor is running when in agitate cycle.
Dec 03, 2008 | GE WBSE2090A Top Load Washer
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
GE WVSR1060A Top Load Washer Logo
90 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
