Question about Dryers
Dryer will only run for 5 or 10 minutes when I press start.
Seems like it heats fine. Vent is clear. Lint trap is clean.
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Dec 03, 2012
  • 2 more comments
  • mathew taylor Dec 03, 2012
    Kenmore model 417.84072300 serial xd43506030
  • Richard Roth
    Richard Roth Dec 03, 2012
    OK, you will need to replace the motor. Here is the part to order.http://bit.ly/UjcKxg
    The motor seems to run better on the timed dry option. I think it has the early shut off problem on the moisture sensing cycles. Would it be a moisture sensor that needs to be replaced or do you still think its the motor?
  • Richard Roth
    OK, I didn't know you had the problem in the sensor dry cycle only. The sensor would be the problem then. Here is the sensor to order.http://bit.ly/TESRzW
  • 184 Answers
SOURCE: Dryer doesn't heat.
THE FIRST THING TO CHECK IS YOUR POWER. THE OUTLET HAS TWO ANGLED HOLES THAT SHOULD TOTAL 240VOLTS ACROSS THEM. THE L SHAPED HOLE IS THE GROUND AND THERE SHOULD BE 120VOLTS FROM EACH ANGLED HOLE TO THE L SHAPED HOLE. THE DRYER'S MOTOR ONLY RUNS ON 120 VOLTS ( FROM ONE ANLGLED HOLE TO THE L SHAPED HOLE). THE HEATING ELEMENT CIRCUIT RUNS FROM ONE ANGLED HOLE TO THE OTHER(240VOLTS)
THE DRYER WILL RUN BUT NOT HEAT WITH ONE SIDE OF THE CIRCUIT BREAKER TRIPPED.
IF POWER IS O.K., THE NEXT THING TO DO IS PULL THE BACK PANEL OFF OF THE DRYER. THE HEAT ELEMENT IS IN A BOX ON THE RIGHT SIDE WITH TWO RED WIRES GOING DOWN TO THE BOTTOM OF IT. IF YOU HAVE A METER, CHECK FOR 240VOLTS AT THE TWO WIRES ATTACHED TO THE BOTTOM OF THE HEATER. IF YOU HAVE
240VOLTS THERE, THE HEATER IS BAD. IF NOT, THE ROUND ITEM NEAR THE BOTTOM IS A HIGH LIMIT THERMOSTAT. IF YOU HAVE 240VOLTS AT THE TWO TERMINALS ON THE THERMOSTAT, IT IS BAD. PART #
279769 COMES WITH THE HIGH LIMIT THERMOSTAT AND THE THERMAL FUSE FOUND AT THE TOP OF THE HEATER ASSEMBLY. CHECK THE THERMAL FUSE THE SAME WAY.
IF IT IS BAD, YOU WILL SEE 240VOLTS ACROSS IT.
IF ALL THOSE COMPONENTS ARE GOOD, IT COULD BE THE TIMER, TEMP SELECTOR SWITCH, OR THE MOTOR'S CENTRIFUGAL SWITCH. YOU WOULD HAVE TO READ THE WIRING DIAGRAM INSIDE THE CONTROL PANEL TO CHECK THOSE ITEMS.
Posted on Apr 03, 2008
ronpar
  • 27 Answers
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Posted on Jun 29, 2008
tony2155
  • 64 Answers
SOURCE: Dryer runs fine but no heat
change the fuse in back of the dryer
Posted on Jun 23, 2009
  • 128 Answers
SOURCE: dryer is not heating up electric dryer
First make sure the heat setting is set for heat. If you dryer is connected to a fuse panel, Check to make sure that BOTH 30 amp fuses are good. If both fuses are good (check with a multi meter not just visual) you will have to check the electrical circuite for the heating system. I'm not really sure what make or model you have so if its a Inglis,Roper,Kenmore or Whirlpool you will have to remove the rear panel and first visually check all the wires to make sure non are burnt off, If wireing looks ok check the resistance of the element and all the thermostats to make sure the complete the curcuite. On some models there is a thermal fuse (white plastic with 2 wires going to it) attached to the heating box, make sure the circuite through the thermal fuse is closed. If everything checks out ok you may have to take the panel off behind the timer and selector switch and inspect the wireing there. If you check the wireing diagram you can see what switched are sopose to close when you select different temperatures and check the switches in the timer and selector switch.
If you check everything on the wireing diagram you will be sure to locate where the problem exists.
Posted on Jan 09, 2010
apart4u
  • 213 Answers
SOURCE: dryer not heating
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Posted on Jan 13, 2010
No heat in drum heat out of vent maytag mle2000ayw
Are you sure you dont need a professional Dry Vent inspection and cleaning?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Mar 17, 2013 | Maytag Neptune Dryers
About 12 to 20 minutes into the drying cycle, the dryer stops and all of the led lights start flashing (drying, cool down, press saver, clean lint filter". Also, the dryer doesn't seem to get warm,...
sounds like a restriction in the venting process, i would first disconnect the vent tube and run the dryer, if that clears the problem then I would clean out the vent tube. If not then I would take apart dryer and clean out all of the lint. Hope this helps Tim
Nov 26, 2010 | Dryers
My electric dryer runs for awhile then it just shuts off after about 15 minutes of running? Its a neptune.
a couple of things here may be the problem.. First I would check to make sure my lint trap and the dryer exhaust is not full of lint causing the dryer to heat at a higher temp throwing the high limit switch into disconnect due to the amount of heat generated by the coils. This hi limit switch is a safety device to prvent fires. If you find a lot of lint in the dryer vent or the dryer lint trap, once cleaned, see if the machine doesn't operate like you want. Second. The motor bearings or strator may be going out and the motor is going into thermal overload and shutting down to prevent, as you guessed, a fire. I would check the lint trap and dryer exhaust first since it is more than likely the problem and is cheaper to fix. A wet/dry vac should do the trick. Also remove the back of the dryer to clean out the lint paying special attention to the area around the motor vent which can get blocked causing the motor to over heat. Once these vents are cleared the motor may be fine. Make sure to do all of the above with the dryer disconnected from the power source..
Good luck hope this helped you some
Dave
Jan 28, 2010 | Dryers
Jun 23, 2009 | Kenmore 73952 Gas Dryer
Will not dry clothes fully. the machine heats fine but it takes two or more cycles to fully dry a little load. someone told me about a part that may need repaced around the lint trap.. Any ideas?
Your lint exhaust is blocking the heat flow.
Remove the vent from the rear of the dryer and run a timed cycle load for 40 minutes.
If laundry is dry, repair the outside vent.
If not dry,open the dryer cabinet and clean the inside lint and heat vent.
Mar 05, 2009 | Kenmore Dryers
Dryer turns, heats up but won't dry
check the outside of your house to see how strong the blowing is if it's weak then it's in the vent tube
Jan 25, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Fisher and Paykel electric top load dryer
Dd you try to unscrew the larger lint trap underneath the lint cup collector. My serivce person showed me how to do this and after a year I cleaned it out and was surprised how much lint was caught in there. My dryer was not heating and drying quickly, this helped the problem.
Sep 11, 2008 | Fisher DEIX2 Dryer
Dryer takes longer
check the humidity sensor not working
Mar 09, 2008 | Dryers
Whirpool Dryer......
GAS or Elect. does not make a diffrence 95% of drying too long problems are from a clogged vent try to run a normal load with the vent off the the back letting the hot air into the house if it drys normal then you need to clean out the venting going to the outside If you are worried about the lint blowing inside you can put an old pantiehose over the vent to catch the lint dust
Jan 21, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
