Question about RCA HD56W58 56" TV
My Tv started with flashing red/orange colors. Then later the screen turned red/orange and the TV shut off. When I attempt to turn it on again, the screen stayes red for a few minutes then shuts off.
    Top Expert:
  • RCA Master
  • 14,553 Answers
The problem based on the model number is in or around the red picture tube---the bright red screen causes the set to draw too much current and the shutdown circuit detects this and turns set off--self protection.
Each picture tube (3) has a IC chip on the board connected to it--shorted chip or bad picture tube.
Shop repair in most cases.
Posted on Dec 03, 2012
SOURCE: The tv keeps shutting off just after minutes of turning it on. We can wait about 5-10 min before turning it on again but then it only stays on for a few minutes.
This sounds like a heat related problem, which could be a faulty chip or a cold (bad) solder joint on one of the PCBs (printed circuit boards). Due to the lethal voltages present inside a CRT type television, it is strongly advised to have this repaired by a qualified technician. however, if you or someone you know is technically inclined, you can try to fix this yourself. Cold solder joints can often be spotted by visible cracks in the solder joints. a through inspection of all the boards could easily identify the problem which can be resolved with a quick tap with a soldering iron and perhaps a little extra solder added to the joint. if that yields nothing, another method is heat/cold stressing the boards while the TV is running. With the TV on, spray small areas of the PCBs with cold spray (or a can of compressed air duster turned upside down) until the tv shuts off. then heat the last sprayed part with a hot air gun (or a hair dryer) until you can get the problem to repeat regularly. inspect the area causing the problem and you will probably find the culprit.
Posted on May 26, 2009
SOURCE: d32f750tyx1
The flyback transformer is damaged.
Posted on May 28, 2008
  • 5 Answers
SOURCE: rca 35v432t
MHF318-19-4Z24
Posted on Mar 17, 2009
  • 8457 Answers
SOURCE: rca truflat 13
Ur video board that connected to the CRT(tv tube)long neck.It needed resolders the board it have cold solders.U know how to solders, resolders the ssockets pins that the CRT video board connected to.
Posted on Nov 10, 2009
  • 901 Answers
SOURCE: TV keeps shutting off. It will stay on a few
It looks like a power supply SMPS problem.
You have to replace the optical isolator in the SMPS feed back circuit. It is a 4 pin IC
Mostly this may be the problem. Take the help of the service personnel.
Posted on Sep 24, 2010
Samsung 55" LED UN55D6003 Intermittently turns off and on...T/S help
DO NOT ATTEMPT ANY REPAIRS, CALL THE FACTORY PHONE NUMBER IN THE OWNERS MANUAL AND FIND OUT WHERE TO HAVE THE TV SERVICED, IF YOU ATTEMPT ANY REPAIRS THEY WILL VOID THE FACTORY WARRANTY. THIS IS CAUSED BY AN ELECTRICAL FAULT INSIDE THE TV, IT SHUTS DOWN AS A SAFETY FEATURE TO AVOID ANY FURTHER DAMAGE.
Dec 06, 2011 | Samsung UN Televison & Video
Screen turns red then shuts off
Sounds like a bad red projection tube, disconnect red tube socket and try again if tv stays on reconnect tube soket and adjust screen controls on front of tv under the front panel which you will have to remove to do any of this. There are six adjustment controls 3 are for focus for each color and 3 screen controls for each color. Look close at the black plastic control module should be labled R G B for focus and R G B for screens. Good Luck!
Mike
Apr 14, 2010 | Sony KP-51WS500 51" Rear Projection...
Sony Trinitron screen flashing
The picture tube is starting to fail. The increased screen voltage allows it to stabilize at the expense of color quality. Sorry to say, but it is time for a replacement.
Dan
Dec 17, 2009 | Sony Televison & Video
56" sharp 56dr650 rear projection tv
Hi - wanted to let you know that I have the same problem and I contacted Sharp (800) 237-4277. They offered me a prorated exchange. Select #1 prompt for Operations and then they will create a case number if you don't already have one and then send you over to the Disbatch Dept. They are picking up my 56" TV and are selling me a LC52"D65U for under $450 current retail value of the new TV $1900. Give them a call and see if they can work out a deal for you too. The whole transaction will take 7 - 10 days. Good Luck!
Dec 10, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Random turn off
just soldering your color ic or your RGB ic
Jun 20, 2008 | Sony FD Trinitron WEGA KD-34XBR2 34" TV
My Maxent turns off when it comes back on it has dark colors.
goto maxentuse.com, open user manual and look under troubleshooter.
May 01, 2008 | Maxent MX-42EPM20 42 in. Plasma EDTV
I have a LG RU-44SZ61D DLP TV and recently replaced the bulb. After about two months the TV went really dim and then started shutting off. The problem increased to the point where you couldnt have the tv...
DLPs have flow chart trouble shooting techniques to pinpoint exactly why your set isnt completeing the boot sequence. If you would like the service manual for your model let me know and i will post a link where you can purchase a complete one.
Apr 06, 2008 | Televison & Video
RCA Scenium HDLP50W151
Color wheel bad #212184
Approx $400 by an authorized RCA shop
Dec 31, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
RCA HD56W58 56" TV Logo
146 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
