Question about Miele Washing Machines
Miele w1926 main light is on Rinse 1-2 light blinking
The washer filled with water and then the rinse 1-2 light came on and the washer will not go threw cycle. I have powered it on and off and it is still stuck.
Thanks
Dan
3 Suggested Answers
  • 91 Answers
SOURCE: Miele W1926 check inlet light flashes
Hi dear.It sounds like you'll need to change water inlet valve very soon.Because,machine waiting water level to be reach,in specific time frame in chosen program parameters to be get completed.If that does not happen,then it starts giving fault indication.Indication stops after fill,because task been competed & computer disregards the fault.If that won't happen then machine going to get stop completely & indication will carry on.Chage the water inlet valve if you can.I hope that helps. Thanks.
Posted on Aug 29, 2010
  • 91 Answers
Hi dear.According to what you're saying,It has faulty water inlet valve.Machine unable to get enough water to do it's cycle in given parameters in time period & starts giving error but before the cycle complates,however it takes enough water,that's why error lights goes off.If you can,you need to change the valve or call service department.I hope that helps.Thanks.
Posted on Sep 02, 2010
How to put top back on miele w1926
1 Remove stacking kit from top of unit.
2 Reatach the two plastic clips to the back of washer.
3 engage the two slots on the washer top into the clips , pull forward drop lid down on top of washer then secure with two screws on either side of lid.
Dec 29, 2013 | Miele W1926A Front Load Washer
Rinse light flashes on miele w828
1) the water must be preheated, test the heating element if is defective
2)drain line is clogged proceed to fix it see the diagram
3)some sock must be removed, use plier
4)pump defective, inside with the propeler, replace
5)frozen pulley pump, replace
6)improve the drain, if about 4 inches cut of the diference.
b) if lower , install air/gap siphon break assembly.
God bless you
Jun 25, 2012 | Miele Novotronic Premier 500 Front Load...
The "Rinse Aid" red light
The rinse aid light is just an indicator to let you know the rinse aid is low. You fill it in the container next to where you put the detergent. Just push the yellow button and the lid will pop up. rinse aid is more important on the newer miele dishwashers, as they dont have "active drying" like the older dishwashers did. They depend on the rinse aid to sheet the water off the dishes at the end of the cycle. They are designed this way to reduce energy consumption. If you choose not to use rinse aid, and you dont mind wet dishes at the end of the cycle, either disregard the red light, or fill the rinse aid dispenser with water to trick the machine into thinking it is full.
If you are not going to use the onboard water softener, you can turn it off. Refer to your owners manual, or call miele tech support at 800 843 7231 and they can walk you through the programming to disable the water softener. these are not fault lights, they are simply reminders that you need to fill the containers.
Jul 20, 2011 | Miele Dishwashers
I have a Miele Novotronic W1926 washing machine and it is filling very slowly during the main wash on the cold setting. it does not fill slowly if hot setting it selected, but will fill slowly once it...
I have he same exact washer with the same exact problem. I have checked everything you checked as well. I took the cold side solenoid off and trouble shot it into a bucket and it seems that the solenoid is not opening like it should. Now I am stuck with whether its a bad solenoid or its not getting a signal. I'm thinking it is the solenoid but I will have to get some one with a multimeter to check the contacts to make sure it is getting a signal. If that's the case I will have to order a solenoid. It's simple to replace. Now I have to find out the part number and a place that sells it. I will try to keep this blog updated to help anyone else out that may run into the same problem.
Apr 06, 2011 | Miele Washing Machines
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Jul 26, 2010 | Miele W1926A Front Load Washer
Miele W1926 check inlet light flashes at the end of rinse fill. When the fill ends, the light goes off. I cleaned all 4 filters at the intake hoses. The problem still exists. What does it mean?
Jul 25, 2010 | Miele W1903A Front Load Washer
Jul 25, 2010 | Miele Novotronic Premier 500 Front Load...
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Washing Machines Logo
144 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
