Question about Tech Solution TS-900 Calculator
Can't get numbers to display
I haven't used this in some time, so I replaced the battery and I cannot get the on/off button to work. It will only turn on when I press the AC key. When I do, no numbers will register on the display. It just stays as 0. What is not right here?
  • 186 Answers
Make sure there is not a key stuck in the depressed state. If so try to pull it back up and you should be set. If the machine had a liquid spill this could cause that type of error too. In which case the machine is junk.
Posted on Jun 16, 2007
Camcorder wont turn on at all
Are the batteries fully charged ?
Jun 17, 2017 | Mitsuba DV777 Camcorder
I have had my radio for many years but when I wanted to put it in another room it displays a half "L" on the display when I plug it in. Do I have to replace the battery when I'm using an...
Hello
You haven't specified nothing about your Emerson Smartset Clock Radio. Nothing is there about its model number. Yet I posts this solution before you assuming that yours' is a CKS3528 Emerson Clock radio.
There is a long life lithium battery installed in this clock radio when you buy it.
This battery can maintain the time and alarm settings for 3 to 5 years, or even
longer, so there is no need to pay for a new 9-volt battery every 6 months, as
is recommended in other clock radios with normal battery back up.
But if this lithium battery has gone down [ in terms of voltage]; the display 'L" will be there. It means that, it is time to replace this backup battery. It will be of disc type, usually used as bios setting storage, used in computers. OK.
May 13, 2011 | Emerson Smartset Clock Radio
Operating instructions for EM-2R power meter. it has 3 plug-in sender units with remote reader. How do I resynch the senders and reader after replacing battery in reader? Cheers DaveK
I have what appears to be the same device. My instructions list the following method:
1. turn off or disconnect all the remote monitors.
Use the code button on the display module to set the channel. It displays 1 --:-- for channel 1.
Plug in the first remote sensor into the power outlet and press and hold down the SET button until the LED flashes.
The receiver will show numbers where the dashes were in the display.
Change the channel on the receiver to 2 withb the code button, it displays 2 --:--.
Plug in the second remote sensor, press the set button till the LED flashes.
Repeat for channel 3 with the third remote sensor.
This is the same method used to set them up the first time. Having to turn off or unplug the device is the unintuative bit. I assumed it would reconnect after replacing the batteries.
Dec 19, 2010 | Kitchen Appliances - Others
I'm having trouble setting this item. I can get it to come on, but it won't turn off at the set time. What am I doing wrong? Thanks, Janene
I don't have a Woods 59112 Manual
Here's link to Woods 49063 manual aka Woods TD1000 aka Noma TD1000
If manual is same/similar as your manual, then read solution given below
If solution below is incorrect, the write out your instructions ... I found that writing out instructions makes things clear.
Solution:
I think you have set ON time but did not set corresponding OFF time
Below is whole programming layout for you to read through
The important thing is to look at the display while programming
For example, lets say you are setting ON time for PROG1
For ON time, the display shows 3 things:
-display shows PROG in upper left corner
-display shows the number 1 to right of time
-display shows the word ON to the right of the number 1
Now you want to set OFF time for PROG1
For OFF, the display shows 3 things:
-display shows PROG as before
-display shows 1 as before
-display has changed and shows the word OFF to right of number 1
Here's how to set Woods TD1000 timer
Plug in timer to see if battery will recharge. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set current time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Oct 05, 2010 | Woods INDUSTRIES 59112 INDOOR DIGITAL...
Hi. I have a Casio CE-3700 that is only used for a few weeks of the year. Once I month I try to turn on the machine and leave it powered up for around a day. I am now wanting to actually use the machine....
It sounds like the machine has lost some programming. What you were doing once per month is what I recommend if not used regularly, but the battery has probably now got to the stage where it is too old to even hold charge for a month. It is probably best to get the battery (internal vanadium type) replaced as it may have started leaking if it is too old. The dealer who replaces it can reset your decimal places at the same time. If you just want to get it running as is and take a chance, then do the flag clear (to get the FFFFFFFFFF on display then SUBTOTAL) on one of your WORKING machines, and tell me the big number that it prints out (this will not lose any data on your working machines, it just reads the settings)
Jul 26, 2010 | Casio Parts Cash Register PC Desktop
The calculator is intermittent: Most of the time
Not knowing what to do, I tried anything that could possibly help:
I installed fresh batteries and I pushed the reset button on the back of the calculator (Sharp EL-546L) and finally, it work all right after more than 5 years I own the calculator and where it did work correctly for 5 minutes. I tried the reset button in the past (long time ago) and it didn't work. This time it worked because, maybe, I've used fresh batteries.
Marcello
Jun 03, 2009 | Sharp EL-738 Scientific Calculator
Radio stuck in safe mode
Turn on radio - the word SAFE will appear in the display. Press th P.SCAN and RBDS buttons simultaneously and hold them down until "1000" lights up in the display.Release buttons.Do not, under no circumtances, continue holding them down or press them once again. This will cause the radio to consider the number 1000 to be the input code.Use station buttons 1,2,3,and 4 to enter the code number on your Radio Card. Use the button 1 to enter the first number 2 for the second number 3 for the third number and 4 for the last number.Once you have entered the code and it shows on the display,press the P.SCAN and RBDS buttons down again simultaneously and hold them down until the word SAFE appears in the display.Release buttons. Soon afterwards a frequency will be displayed.
PLEASE RATE THIS !!!
Jun 11, 2008 | 2002 Audi TT
Remote control for dvd/vr
As advised by a client of Fixya, I pressed 1 and enter at the same time and, hurrah!, everything worked. Let's hope it continues. Thank your!!!
Tonsil
Apr 24, 2008 | Televison & Video
ADX5355 clock
you just have to turn the power on, push the display button so the time is showing on the display. (The only buttons involved are the "BAND" button, the number 4 roulette button which is the top right station preset button and the "DISPLAY" button.) I think you push and hold the BAND button and while holding it push the number 4 roulette button. (you don't have to hold it for any specific time you just have to push BAND in when you push the number 4 roulette button.) the time will flash and you use the vol/seek knob to adjust the time. When done push the BAND button again.
=> This really work, thanks!
Dec 23, 2007 | Clarion ADX5355
Tech Solution TS-900 Calculator Logo
79 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Michael Galve
Michael Galve
quennie732
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
