Question about Bosch Washing Machines
I have a bosch washing machine and the drum will not go round or spin?
My washing machine will not wash my laundry. it fills up fine and drains but it will not spin at all. can you help me?
    Top Expert:
  • Bosch Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Dec 03, 2012
SOURCE: bosch 1200 classic express washing machine wont spin
Providing the machine isn't requiring major breakdown repair, the problem should be solved by emptying the machine and cleaning the drain pump. If this is obstructed the maching won't drain or spin as any bits left in clothes (paper clips, coins, nails, screws etc) wedge themselves into the (what I call a fly wheel) the pump impeller wheel at the back. If the fly wheel can't rotate the machine cannot pump or spin.
So.........turn off the washing machine before you fiddle about with it. Then, at the bottom right-hand side at the front of the machine there's a drop down door. Take this down and take it off. Then, lower the drain hose from its holder and pull the hose out of its housing. Be very careful if you're doing this while you have very hot water in the machine. To be safe, let the water cool before starting. Next take off the closing cap from the hose and empty the water from the machine. There are times when the water doesn't empty by this method so carefully open the door to the machine and bale it out. If the water does come out via the hose, have a suitably sized bucket at the ready as up to 20litres can be drained. Once you've done this, put back the closing cap of the drain hose and returned the drain hose to its holder, unscrew (anti clockwise) the petrol tank cap look-a-like placing a towel underneath as a little residual water will flow out. The pump impeller (fly wheel) must be able to rotate so clean out any residual fluff from the thread of the pump cap and pump housing before returning the pump cover and screwing tightly on. Put back the drop down flap and, hopefully, away you'll go again.
Hope this is of some help.
Posted on Jul 23, 2009
SOURCE: IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Posted on Jul 25, 2009
nikeananth
  • 267 Answers
SOURCE: Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see o circular lid there, turn it on anti-clockvise to open. All of the water blocked will come from there, be careful. Look carefully that there are some objects blocking the water draining. Then turn on the machine on draining programme, the plastic rotor should turn fastly when the machine is on. If it is not running, change the pump motor. If it is running, but machine is not draining again you can understand that there is an objeck stuck on the hose between drum and pump motor. Lay down the machine on its rear facade, you will see a large and black hose between drum and pump motor. When you remove it, you will see that there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
Posted on Oct 04, 2009
barkencoa
  • 3463 Answers
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Posted on Dec 09, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
Beko WMI71641 won't agitate or spin - drum doesn't move!
your pump is blocked,at bottom of machine there should be a flap with a round plug in middle .unscrew,it will have water come out so use a bowl or big towel.the impeller should turn freely,once plug is unscrewed at front put washer into a drain program see if the pump turns.if this is free youll need to get the pump off(unplug machine first)and then feel inside the big pipe from the drum to pump.it may have a sock or something like inside.this means it will work but wont get out all the water.also note when trying to spin a pillow,or big towel the load will be uneven so it will reduce its spin speed so it doesnt destroy its self
Apr 16, 2014 | Beko WMI71641 Built in washing machin
My Bosch washing machine won't turn the bowl
Hi Justene,
i Think its control circuit has a problem.
or the fuse for motor drive circuit is damaged.
please check with electrician.
regards.
nuwan
Jan 13, 2014 | Bosch Washing Machines
Washine machine not spinning
It sounds like a snapped belt or a broken motor. Can you here the motor run? You can access the motor and the belt from the back of the machine. If it is the belt snapped, this is easy to replace yourself. If it is the motor, you will need a repair man.
Jul 17, 2010 | Bosch Washing Machines
The machine wheel inside wont go round
I suggest that you remove the motor, and check the brushes in the motor.
If there is less than 3 or 4mm left, then replace them.
Please rate my solution.
Thanks.
Nov 17, 2009 | Bosch Classixx WFL 2066 Front Load Washer
We have a WFL 2090 UC Bosch Axxis Front end load washer. When we use the Power Wash option, the clothes are soaking wet when the cycle is completed. Are we supposed to use the Power Temp or Power Boost...
Are you sure that your washer spins? that your pump drains? You should not have this problem. Do you load your laundry properly (too much laundry- should not be more than 3/4 of the diameter of the drum)?
Jun 28, 2009 | Bosch Axxis WFL2090UC
Bosch Washing machine will not spin
Are you able to see the belt? Maybe it broke. If the drum is not spinning than sometime broke that would make the drum spin. If you machine is a direct drive then there is a problem with the drive shaft.
Jun 01, 2009 | Washing Machines
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
Washing Machines Logo
80 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
