Question about Solar Christmas Tree 6 Outlet Foot Switch Extension Cord
I have an Everstar pre-lit Christmas. I need to know if I can buy a replacement main AC plug with the fuses in the plug.
2 Suggested Answers
SOURCE: We purchased an Everstar pre-lit Christmas Tree
I have a 3 piece Everstar 7/12 slim pine and here are the plug portion of the assemblly instructions . "1) connect the plug(A1) of string with the end cord (B1) of string. 2) Insert the plug (B2 & C1) of string into the wall outlet. 3) After the plugs are plugged into the wall outlet your entire tree should be lit. If some bulbs do not light, search for any loose plugs, broken, loose or missing bulbs that may have caused the problem."
My illustration shows the A1 in the top section of the tree while B1 is in the middle section. Both the middle section and bottom section get plugged into the wall or extension cord. Hope this helps
Posted on Nov 29, 2009
Everstar 4 piece Christmas tree, how do I hook up lights?
Setting Up your Pre-Lit Christmas Tree - YouTube
? 4:56
https://www.youtube.com/watch?v=qe1fbGZV-Ys
Jul 3, 2008 - Uploaded by Christmas Central
Here are instructions on how to put up your pre-lit Christmas Tree, courtesy of http://www.christmascentral ...
Video: How To Assemble a Pre Lit Artificial Tree by Sterling ...
www.christmascentral.com/t-Video-How-To-Assemble-a-Pre-Lit-Artifici...
Learn how to assemble your Artificial Christmas Tree in less than 10 minutes! Sterling Inc has teamed up with Christmas Central to make this instructional video; ... Do you want to learn how to decorate like the pros? ... These lights can be used for all kinds of visual motion effects, from a waterfall to a flashing starfield!Missing: everstar
We purchased an Everstar pre-lit Christmas Tree - Fixya
Dec 12, 2015 | Home
Pre-lit tree won't twinkle
Have you tried one blinker at beginning , closest to where the main plug in is?
Nov 29, 2011 | Christmas Lights Etc Toys
I have an artificial pre-lit Everstar 7 1/2' slim montana pine tree. One of the screw holes in the base stand is stripped and allows the tree to tilt. Where can I find a replacement stand? The tree...
Call Everstar customer service 1800 833-3390 They do NOT have a website. I think because they are a bunch of retired christmas elves without internet service.
Dec 26, 2010 | Solar Christmas Tree 6 Outlet Foot Switch...
We purchased an Everstar pre-lit Christmas Tree and we can not locate the manual or instructions that came with the tree any help since half the tree doesn't light up and all the plugs are plugged in....
Millie, Get an extension cord. Unplug all of the plugs, then test each one individually with your extension cord. You may have just one cord that is bad, and you can isolate it this way. It is probably a blown fuse in that one set. The male end of the bad set (the end with the two metal prongs) probably has a plug that pulls apart to reveal two small fuses inside. Look at the plug closely, it isn't obvious that it opens. The fuses are little glass cylinders with a metal cap on each end. If you can't tell by looking at the fuses if they are blown, then you can switch them with other known good fuses to be sure before you go search for new fuses. Good luck and Merry Christmas. Al K
Dec 18, 2010 | Solar Christmas Tree 6 Outlet Foot Switch...
7-1/2 inch pre lit slim christmas tree by everstar
I think a chain saw is not the problem, but the solution to your tree.
Dec 17, 2010 | Garden
My pre lit Christmas tree came with no plug! just the iwres. I purchased a plug that is put onto the lires by pushing them into the base and then putting back a little yellow thing that pinches it all...
Is this a led string of lights? Is it only two wires, if so how many lamps is on the wires this may be a battery run unit. I would need more info, if you can list more so maybe I can help.
Aug 25, 2017 | Solar Christmas Tree 6 Outlet Foot Switch...
How to connect the lights on a 3 section pre lit christmas tree
Did you plug one section of the tree back into itself?
Dec 06, 2009 | Electrical Supplies
Nov 28, 2009 | Solar Christmas Tree 6 Outlet Foot Switch...
No power/RCA ctc187cl
Check for 5 volts present at pins of EEPROM IC. ( 8 pin-center
front) = no 5 volts = Re-check power supply components such as AC in resistor 2.7 Ohm ?....Or 5 volts ok,then suspect EEPROM corrupted........part # 223957 ( install 8-pin socket,then re-plug in original, if that doesn't clear it, plug in
new part) Use pre-programmed after-market replacement,if you
can get it.....Let me know....T.
Oct 30, 2007 | RCA F32450 32" TV
Solar Christmas Tree 6 Outlet Foot Switch Extension Cord Logo
64 people viewed this question
Top Solar Electrical Supplies Experts
Steve
loft404
loft404
Level 1 Expert
obsteiner
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
