Question about Kenmore 62622 Electric Dryer
When I tried to start my dryer it ran for about 30 secs. then quit
I heard a little click before it quit I checked the plug in the breaker box and cannot figure out what it is
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Dec 03, 2012
5 Suggested Answers
SOURCE: my kenmore dryer will not come on - was working
Jun 08, 2009 - after checking all the timers start button thermal fuse at element, finally found another thermal fuse at the front of the dryer on top of the exhaust blower. Checked out bad on meter and replaced it for $8.00 at local repair shop. Dryer started right up.
Posted on Jun 08, 2009
  • 942 Answers
SOURCE: Kenmore Dryer won't turn on
Hi...
This are the tipe on how to Troubleshot dryer follow the steps below
IF the dryer is noisy
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
If the dryer tumbles, but there is no heat
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Good luck !!!!
Regards
PCmania
Posted on Jul 03, 2009
SOURCE: kenmore elite won't start,
kenmore elite won't start, Solve kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on... (More) kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on when you open the front dryer door either
Posted on Jul 11, 2009
iwillfixforu
  • 619 Answers
SOURCE: Still more of the same
The exhaust is clogged or restricted holding too much heat in the exhaust housing or the limit t-stat has gone bad. This is the t-stat sitting next to the thermal fuse. Good luck.
Posted on Feb 11, 2010
Hi just removed my dryer to clean, and had to pull out the dryer a little to pull plug. I then heard a spark tried to start dryer again and nothing on the display panel?
Musta flipped the breaker check the power is what i would do and find the short check the prongs of the power cord unplugged against the frame of the dryer. if get a reading check heating element dryers only require 120 volts to run but need 240 for heat if it uses electric elements. Me doing various checks on dryer
Dec 31, 2016 | Dryers
Hi, I have a nice master B150D that ran flawlessly last season,brought it out this year replaced nozzle,spark plug,new fuel. Fired it up ran for 30 sec. pop's the circuit breaker,reset,runs 20 sec....
if a circuit breaker pops i assume its an RCELD or is it a MCB type
it is some leakage to earth somewhere in the electrics
if it runs and pops the breaker
and you can plug it in and it will sit there
then i assume its something do do with the fan system
or ignitor . driver system
look for sources of leakage to earth
and you could measure the peek current it uses with a multimeter inline
set to AC amps
anyway its defo not a gonner just some bad electrics
Dec 09, 2014 | Heating & Cooling
I have a Maytag dryer model MED5740TQ0 that won't start. Dryer was recently moved to a new location. House was being remodeled so plug and breaker had to be installed. Plug is a 3 prong and dryer had 4...
If you are only getting 120v to the dryer, you still have a breaker tripped. It should be right next to the single pole 30. It takes 2 breakers to get the 240v you need to run the dryer. Try resetting another breaker expecially the ones marked 30amp. You do need to get a double pole breaker installed even for safety reasons.
Apr 12, 2011 | Maytag PYE2300AY Electric Dryer
My dryer ran for about a min. It then quit and
Did the circuit breaker trip or fuse blow? Check to see if the dryer is getting power.
Sep 12, 2009 | Dryers
Hi...
Level the dryer
Check the drum belt
Check the glides
Check drum bearings
Check the blower
Check the baffles
Good luck !!!!
Regards
PCmania
Jul 03, 2009 | Kenmore 63942 Dryer
Just purchased a used Whirlpool Duet dryer(2 to 3 yrs. old). I hooked it up and placed it on a normal automatic cycle. The unit started up a little noisey but quitened down in approx. one min. Shortly...
try replacing the power cord, and make sure that you have a "dedicated" power sorce for the plug. The system board will shut the dryer down if a power supply issue is detected. This feature is to prevent fire hazards. Make sure your electric box is grounded and up to code.
Jun 26, 2009 | Whirlpool GEW9250 Electric Dryer
New Maytag MED5707TQ dryer purchased. plugged in and it ran for about a half hour. Stopped and won't start. seems to be power getting to back of dryer when plugged in. any ideas?
thanks for the question you need 2 30 amp fuses to run the dryer i would check your breakers or fuses it needs 240 volts thanks the appliance doc
Sep 17, 2008 | Maytag Dryers
Lights come on and makes a clicking sound when I push start.
Try checking your fuse box or circuit breaker panel first.The dryer requires 2-30 amp fuses to operate normally...replace both fuses instead of gussing which 1 is bad. OR, the dryer uses a double pole 30 amp circuit breaker...Flip it to OFF then back to ON. Then try your dryer and if it works you can send me flowers...just kidding! If it doesn't work, write me back and we will do some more soul searching.
Thank you for contacting us at FIXYA.com
Dave, (Illeagle)
May 28, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer will not start, timer sounds like it is running
Possibly a door switch, or starting switch near timer assembly. it could also be a bad breaker, dryers have a double breaker, even if you are getting electricity to part of your dryer 1 bad breaker might not let the rest of the dryer work. With electrical experiance,and elect. tools, have some one test breakers and plug voltage.
Apr 08, 2007 | Maytag PYE2300AY Electric Dryer
Kenmore 62622 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
