Question about Fuji FinePix A900 Digital Camera
Protected card message
I can't use my camera how do you get rid of the protected card message?
On the side of some picture cards there is a little tab that slides back and forth. If your card hs this try sliding it the other way. These are a write protection so to speak, or a lock in a sense
Posted on Mar 31, 2009
How to get rid of protected card
Since you didn't specify the make and model of your camera I'm assuming it uses SD/SDHC cards.
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 21, 2013 | Cameras
I get the message 'protected card' Next trick?
There are several possible causes for "memory card locked/protected", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Dec 10, 2011 | FUJIFILM HS20 EXR Digital Camera
I just bought a new battery for my Nikon CoolPix S560 and when I put the battery in, I am getting the message Memory card is write protected. How to I get rid of this?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 17, 2011 | Nikon Coolpix 4500 Digital Camera
Unable to take photos on my vivicam 8225 because it gives message of card protected. howdo i get rid of this message
Jun 21, 2011 | Vivitar Cameras
When camera is turned on "PROTECTED CARD" comes
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Feb 02, 2011 | Sanyo VPC-S880 Digital Camera
Every time I turn on my camera a message appears on the screen that says "write protect". What is "write protect" and how do I get rid of the message?
1) It could be your camera has write protect switched on. Go through your camera's menu and look for picture protect and remove it.
2) Your SD card could be write protected. Take out the SD card and check, there's probably a sliding notch on the left hand side, move the to write enable.
Jun 27, 2010 | Olympus FE-190 Digital Camera
Finepix Z20fd Digital Camera: How to get rid of Protected card...
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 18, 2010 | Fuji Finepix Z20fd Digital Camera
Protected card on my camera
Check your owners manual about protected photos. There is a setting in the camera's setup that keeps you from accidentally erasing photos.
Apr 30, 2009 | Fuji FinePix S1000FD Digital Camera
"Memory card is protected"
This error message indicates that the memory card is locked. The switch on the memory card is in the write-protect position. Reset the switch as shown on the camera screen.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Fuji FinePix A900 Digital Camera Logo
381 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
