Question about RCA D52W19 52" Rear Projection Television
Hd quality I have noticed the quality of high defintion on other sets (friends house,sports bars) so i decided to have comcast cable connect an hd box and the picture quality is not the same.I've just noticed that i don't have any connection to the DVI-HDTV port in the back of the unit. Is this something that i need? Your help is greatly appreciated. Thanks, RayQ
    Problem Solver:
  • 5 Answers
It sounds as if your need to tweak your picture settings from the menu you should be able to go to menu then select pre set setting and or tweak diferrant part for your viewing pleasure, it would seem they were off before you upgraded box to hd
Posted on Jan 25, 2009
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
Comcast Causing Purple/Green Hum Bars
this is normally caused by voltage on the coaxial cable which simply can be solve by a surge protector with a cable in and out.. but this is just a way to passify the issue. More than likely there is a bad ground either in your house or on the comcast line
May 06, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Recieving hy defintion picture
You need to do the following:
1: use HDMI cable to connect Cable box to TV
2: Call Cable company to activate HD service
3: Enjoy!
You can use component input, but the HDMI is best HD quality!
I hope this helps! please rate highly!
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
Figuring out the TV channels for Comcast using the Sharp remote
Unfortunately there is no listing. I suggest taking a little time to sit next to the television with an notepad to go through each channel one at a time to label what stations come in on what channel numbers. Sorry.
Jan 09, 2009 | Sharp LC46SB54U 46 in. LCD TV
Cannot optimize picture width on new flat screen HD
On your cable box remote press the hd zoom button. I have comcast cable box and it worked for me.
Dec 25, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
HD Picture is Scrambled, but Has Sound
I had the same problem
you have to set up the componant on DTV.
the signal my be hd 1080i and the only connection with componant that can support this is the DTV port.
the other componant connections only support 480,
good luck
Apr 06, 2008 | Mitsubishi WS-55711 55" Rear Projection...
VIsta Media Center and Comcast Digital
nechmads,
The s video connection is not a digital signal, it is analog.
This should help you get what you need to set it up.
http://www.microsoft.com/windowsxp/using/mce/expert/hdtv.mspx
Feb 17, 2008 | Computers & Internet
Magnavox 15" LCD TV
If the LCD only has coax, it will never display a HD picture quality. However, the Comcast HD Box will still display a picture using the coax connection. So, you could watch any HD channel, but the picture quality will not be high definition.
Jan 22, 2008 | Philips Magnavox 27MS343S 27" TV
Changing Screen Size on Samsung HP-R4272
you must not have the correct picture settings in the cable box, as although they are not HD they will still be widescreen, so check both tv and box for picture settings.
Oct 14, 2007 | Samsung HP-R4272 42 in. Plasma HDTV
Sony KDF-46E2000 hd picture problems
MY Sony (same model) has OUTstanding picture resolution and quality., I never have blockiness on any of the sports channels. I would say, give Comcast a call and complain about their signal.. they have a tech come over for free diagnostics on your wiring..
Aug 13, 2007 | Sony KDF46E2000 46" Projection HDTV
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
