Question about Mintek DTV-263 26 in. TV/DVD Combo
How do I get it off HDMI mode - Mintek DTV-263 26 in. TV/DVD Combo
    Top Expert:
  • Mintek Master
  • 14,553 Answers
With the original remote in the setup menu---select another input or if set has a source or input button use that.
Posted on Dec 03, 2012
Hooked up my HP pavilion dv7-1240us (Vista) to our HDMI cable, then into the TV, as usual. Slept he computer, then disconnected the HDMI cable. Since then, I cannot get any screen at all. Have tried...
restart pc in safe mode, change video back to standard VGA of HD VGA video. PC has to be in HDMI mode and your TV has to be PC mode. Use a DIV to HDMI connector or better yet HDMI to VideoPort if your TV supports it, HDMI almost never gives you the screen output you really want anyway.
Jan 17, 2014 | HP Pavilion dv7-1240us Notebook
How do set the resolution on a samsung 50" plasma (ps50q7hx)
make sure that the tv is in "HDMI" mode. If there are multiple HDMI ports on your tv then check to see which one it is. You should see HDMI 1, HDMI 2, etc. Then when you are sure what port it is in on either your tv directly or using the remote press the input button until the desired input is selected. So for example, if you have it in HDMI port one, press the INPUT button on either your tv or remote and cycle up or down until you select HDMI 1 and that should do it! sorry if it doesn't!
Dec 13, 2012 | Samsung Televison & Video
When connecting ps3 to Hdmi tv via hdmi lead or av connection ,ps3 is powering up ok but error message appears on tv screen saying game mode not supported.
hello,,when you connect a hdmi you have to into the menu and select hdmi this should give you a 1080p picture mode
regards
shaun
Oct 08, 2010 | Sony Playstation 3 (PS3) Console
No sound
Check the on screen sound set up to see if the sound for HDMI mode is set for analog output (using RCA Red and White audio output jacks) or through the HDMI port.
Jul 02, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
How do I get the HDMI connection on my HP Pavilion dv9000 to work. I have a HDMI connection on my Pioneer HD TV but I don't know how to get the connection on my computer to work. It there some trick I...
Normally the computer will detect that you have hooked in the HDMI cable and will automatically send an signal to the HDMI cable. It sounds like the "automagic" didn't work.
What you need to do is press fn+f4 to cycle the display mode to send a signal through the HDMI port. This works in a multi-mode way. You hold down fn and press f4 one time. Don't let go of fn and you should see a mode indicator on the laptop display. Each time you press f4 it will cycle to another mode. Depending on your specific configuration you might need to cycle through VGA first to get to HDMI.
Jan 09, 2010 | HP Pavilion dv9000z Notebook
In hdmi i only get standard picture mode??
Have you tried another source on the HDMI to see if you get the same results? If not then the source for some reason is locking out those modes. If the second source doesn't work then it is a feature not available while using HDMI.
Nov 29, 2009 | Samsung HP-T4254 42 in. Plasma Television
Hdmi wont work
If the hdmi is in your playstation 2 and on the tv, you need to change your tv mode to the right mode for it to receive the video
Aug 14, 2009 | Pelikan HD System Selector PL-970 for...
I have tried to connect my SD 6100 and am getting no picture. I get sound.
You must use the remote to toggle the player OUT of HDMI output mode to use the non-HDMI outputs (like standard RCA-jack VGA or s-video or component video output). The device displays black screen by default unless you're using HDMI, so it's not possible to see the menu if using s-video. The manual states to press the 'Progressive' button to change modes. Unfortunately, you can't see what mode you're toggling through until you hit the right one (Toshiba blew it here!!). Power on the device WITHOUT a disk in (you can't change modes during DVD playback mode). There are four output modes, so press the 'Progressive' button on the remote and wait for 3 to 5 seconds for the player to switch output modes. Repeat this up to four times to cycle through the available modes. During one of the modes, you should see output to your screen through the cable hookup you've physically attached. You will also notice the led's on the front panel go on and off during the process at times. If you ARE using HDMI, then you have to select a mode your TV or monitor can handle. When in HDMI mode, you'll notice the front panel HDMI led's will light up. There are five modes here - 480P, 720P, 1080i, 1080P and AUTO (when all four leds are lit). Select the HDMI mode that your TV works with. Good luck ~ and don't bother calling Toshiba support ... friggin waste of time talking to a recording that's dumber than Sh#@!!
Jul 09, 2009 | Toshiba SD6100 DVD Player
How to reset the default value for the toshiba sd 6100 dvd player
If you want HDMI 'Auto' mode (the factory default), you need a combination of selecting the proper output mode (use the remote's 'Progressive' button to toggle between the four output modes: HDMI, RCA VGA, component video out and s-video. Once you're in HDMI mode (the led's on the front of the box are a dead give-away!), then you can press the front panel 'HDMI Select' button to move through the five available HDMI settings: 480P, 720P, 1080i, 1080P and 'Auto'. You're in 'Auto' mode when all four led's are lit.
Jan 25, 2009 | Toshiba SD6100 DVD Player
No picture but sound on panasonic plasma
Unplug the TV and disconnect any HDMI cables to the set. If the issue goes away there is a possibility that your HDMI source is causing the problem. Anything on the HDMI can cause odd problems with the TV since the serial data and serail clock lines are routed on HDMI. Those are the 2 commmunication lines used throught the TV for operation so anything HDMI that might load down one of those can cause issues.
Mar 07, 2008 | Televison & Video
Mintek DTV-263 26 in. TV/DVD Combo Logo
41 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
