Question about Sewing Machines
Janome N190 can I do quilting when I drop the feed dogs the machine won't free sew?
  • 8 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Posted on Jan 01, 2008
SOURCE: frame quilting with janome 1600 db
am I right that the feed dogs do not drop on this machine?
Yes, this is correct....but you have to change the needle plate to a thicker one, so the feed dogs will be below the needle plate.
Posted on Feb 23, 2008
SOURCE: Free Motion Sewing
You need to set the stitch length to '0', use some stabilizer to help stiffen the material slightly (you can use it to trace your design onto as well) and try using an embroidery hoop this sometimes helps.
When you start you must push the needle down through the material and up again using the machines wheel and pull the bottom thread through from underneath. Do a couple of stitches to fix the thread and then go.
The most important thing to try and get right is the machines tension, this can sometimes be trial and error I am afraid. My machine tension works best on about a '3'.
Posted on Oct 14, 2008
  • 3 Answers
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Posted on Mar 07, 2009
  • 13 Answers
SOURCE: How to Drop Feed Dogs on Sewing Machine...
On many machines you tilt the machine back on its hinges to see the underside and there you will find a thumbscrew to lower the feed dogs...you also need to be sure that your machine is capable of having its feed dogs lowered...not all machines can do this!
Posted on Aug 28, 2009
I Inherited a Janome 1560 sewing machine, which didn't come with a manual, which I will download but cannot see how to drop the dog fed's completely down so that I can free motion quilt - Help
Here's a manual:
Janome 1560 Instruction Book
Page 36 of the manual states that you need to use the darning plate, ie the feed dogs do not drop on your machine. Instead, you put on the darning plate to cover the feed dogs.
Apr 09, 2018 | Janome Sewing Machines
I have been given janome 525s the material not feeding through the foot. Unless i pull material it wont move
Make sure the feed dogs have not been dropped, ie for darning or free motion quilting. Also, make sure the stitch length is set high enough to actually create a forward stitch.
Mar 18, 2017 | Janome Sewist 525S Mechanical Sewing...
How do I set up my Janome 1600p-qc for free motion quilting?
You will need a darning foot or free motion quilting foot for your machine (these feet are shorter than the regular feet which allows space between the foot and the needle plate to manually manipulate your fabric). Then drop the feed dogs and, if your machine does not have that capability, there should be a cover plate included with your machine that snaps over the feed dogs. Install a brand new needle in your machine, set it for a straight stitch, and test the stitch. Sometimes, the upper tension needs to be loosened a bit so the bobbin thread does not poke through the top of the fabric.
Then...practice, practice, practice...
How to Free Motion Quilt on Regular Sewing Machine
Free Motion Quilting Beginner Tutorial 1 of 4
FWIW, I've found it helpful to use a "Supreme Slider" on the base of my machine. It is slick and allows the fabric to move easily. Special gloves are helpful too because your hand will become dry and begin to slip on the fabric. Using cheap rubber gardening gloves works for some people.
supreme slider Google Search
quilt gloves Google Search
Feb 11, 2017 | Janome Sewing Machines
Janome Machine will not feed material !!
If the fabric is not feeding, the feed dogs are probably not operating properly. Check that they have not been dropped below the needle plate (which is done when darning or free motion quilting). In this setting, the feed dogs never rise above the needle plate to grab and pull the fabric.
The other issue could be that the feed dogs are defective or perhaps seized.
Since you did not provide a model, I can provide only this assistance. It would be helpful to locate (search for make model manual) for your machine.
Dec 30, 2016 | Janome Sewing Machines
How do I drop feed dogs on jem silver 662?
Here's a manual:
Instruction Manual Janome Jem Silver 662
The following is for a 660, but it doesn't mention anything about darning or free motion quilting:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwih_NGBzpjRAhXKh1QKHbKIAvwQFggoMAI&url=http%3A%2F%2Fjanome.com%2Fsiteassets%2Fsupport%2Fmanuals%2Fcompact-models%2Finst-book-jem-gold-660.pdf&usg=AFQjCNEwCPZs5n8s4wdgIHMGHbN-GvDe-w
You can also contact a Janome dealer. If the machine does not drop the feed dogs, there should be a special plate accessory to cover them in order to do darning or free motion quilting.
Perhaps this is the accessory you need:
http://www.sewingpartsonline.com/cover-plate-elna-janome-necchi-825018035.aspx
https://tv-sewingcenter.com/products/janome-quilting-attachment-kit-for-jem-series
Dec 28, 2016 | Sewing Machines
Yesterday, while machine quilting, I heard a clank. Now the feed dogs won't feed the fabric. The feed dogs seem to move back when I start sewing; it seems as if they stayed forward before...
Did you check to make sure the feed dogs weren't inadvertently dropped. Most sewists drop the feed dogs for free motion quilting or darning.
Oct 10, 2016 | Singer 4210 Inspiration Sewing Machine
How do I lower the feed dogs foR free motion embroidery. I have a jANOME harmony 2039
Look on the back of the machine behind the bobbin area. See if there is a slide switch. If not, your manual will tell you how to drop the feed dogs. If you can't drop them, you may have gotten a neede plate that will cover the feed dogs so you can do free motion embroidery and quilting.
Sep 16, 2014 | Janome Harmony 2039 Mechanical Sewing...
Quilting on Janome MC 4000
I have a MC4000 and a manual. To raise or drop the feed dog, remove the accessory box and feel at the back of the free arm there is a lever that will slide left or right to raise or lower the feed dog. I am not a quilter, but the manual says to use foot A (zigzag foot) and accessory L (quilter) which appears to be a guide. Cheers, Deb, Townsville, Australia
Aug 16, 2008 | Janome Memory Craft 4000 Sewing Machine
Frame quilting with janome 1600 db
Feb 13, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Sewing Machines Logo
52 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
