Question about Crown Audio Players & Recorders
PZM-6D wiring. The cable was pulled out of the connector and I cannot reliably determine the connection on the circuit board - red white and shield. Can you help??
SOURCE: Mitsumi FA4o4M Combo Floppy Card and Data card reader/writer
black cable to be connected on a free usb outlet on the motherboard
Posted on Feb 13, 2008
SOURCE: Schematic and/or wiring diagram - Magnavox TV Mod 20ms233s
the problem in my tv is the sound no have
Posted on Jul 04, 2008
  • 4 Answers
SOURCE: maytag ice dispenser wiring diagram model MSD2456GEB
apc...appliance parts center has a good web site that might get you a wiring diagram. or your local appliance supply store might.
Posted on Jul 10, 2008
  • 93 Answers
SOURCE: F7-E0 Fault code. All connections and components checked.
Change your temperature sensor first and check if cleared the code. If not change your control board.
Posted on Jul 24, 2008
SOURCE: need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Posted on Jan 07, 2009
My connection for the cable on the back of my tv is broken!
If you have RCA inputs for video and sound their will be a white and red which is audio and yellow is video. If you have a cable box that you use to change channels, this should have the RCA outputs for your audio and video. You will also have to set your tv to select that input to get the cable. Hope this helps
Apr 17, 2013 | Sony KP-53V85 53" Rear Projection...
I trying to connect my SFC-4160 (security first color ccd camera) the wiring has been cut n there is 5 wires black,red,yellow,white and a bare wire ???? help
Inside the camera is a 4 pin connector connected to the LED Board, with the connector in hand, turn it till you see the pins inside the connector, from left to right wires 1st-white, 2nd-black, 3rd- bare wire or shield, 4th-red, yellow is not connected, the RJ45 end, face the latch away from you, wires are 1st-red, 2nd-white, 3rd-yellow, 4th-shield(bare wire), 5th-black, the LED Board has the wire positioning marked,,,,,
Nov 27, 2012 | Car Audio & Video
My dryer stops and shows E1 flashing
I suggest unplugging the dryer and checking the wiring connection of the thermistor to the electronic control board. The thermistor attaches to the control board on the P2 connector (red/white and black wires on pins 5 and 6).
The image below shows the procedure for accessing the control board in this dryer (click image for zoom). If the connection is okay, pull the connector off of the control board and check the resistance through the red/white wire and black wire with a volt/ohm meter (with the dryer still unplugged). You should measure about 10K ohms (10,000 ohms) at room temperature. Make sure that your meter is set to the proper range. If you read infinite resistance (open), then you could have a wire harness connection problem between the control board and the thermistor. Check the resistance across the leads of the thermistor (with at least one wire removed from the thermistor). If you measure normal resistance (10K ohms) at the thermistor, then you will need to repair the wiring connection between the control board and the thermistor.
If you measure the proper resistance through the thermistor circuit at the connection to the control board (red/white wire to black wire on the P2 connector), then the electronic control board is bad and will need to be replaced.
Hope helps.
Jul 19, 2011 | Kenmore Elite HE4 Electric Dryer
A creative speaker SBS A200 connector pin was damaged. we need to connect that cable directly into the board.so we need that pin details.
Hi, I hope this helps,
Pins look like this: (Top view, not copper side)
1 2 3 4 5
6 7 8 9
1 = Thin white wire from thick white cable (Left input)
2 = Gray (Speaker out)
3 = Orange (+V return from volume unit to bass unit)
4 = Not connected
5 = Thin Red wire from thick red wire (Right input)
6 = Blue (+V power from bass unit to volume unit)
7 = Black (GND - if socket removed, solder 3 socket shield holes to each other or solder black wire directly leftmost hole)
8 = Not connected
9 = Shield copper from thick red wire
Shield copper from thick wire : Solder to GND or Left unconnected
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
The screen is blue and greem
The most probable cause is a break in the cable (red signal line). Try gently wiggling the cable at the computer connector and right at the monitor - these are the usual places for breaks. If this brings the red back into the picture (pun intended), you'll have to find a way to repair or replace the cable.
If you have red or white when the cable is disconnected (check cable warning message) or in the monitor adjustment menus, it is definitely either the cable or the computer video card.
If you can't get red to work at all with the tests in the preceding paragraphs, then it's time to open up the monitor. Check for continuity on the red line (pin 1 on the DB-15 connector to the red shielded wire where the cable terminates inside the monitor). Note: if you are not comfortable working near high voltage or don't know what not to touch, leave this task for an electronic technician. If the cable tests good, then it's time to troubleshoot the red cathode driver circuit on the CRT board, starting with the input signal. You'll probably need an oscilloscope for this job.
Jan 02, 2011 | Acer P201WD CRT Monitor
I need to replace my headphone plug end
See my tip on replacing dodgy cable and plugs on headphones.
May 26, 2010 | Sony MDR-V150 Professional Headphones
Audio Technica PRO-35: need wiring diagram for mic end
If you feel the shield goes to the middle, try red on one terminal and white on the other. If not, reverse it.
If it's labeled on the circuit board...pin 1, pin 2, pin 3, then pin 1 is usually ground, pin 2 is hot (red), and pin 3 is cold.
Mar 31, 2010 | Audio Technica Audio-Technica AT2020...
Wiring internal board of labtec computer speakers
The shielded wires are for ground, so they get connected together. Plug the wire into the PC and run some music. Then touch each wire to the others. You only have a couple of combinations to try...red-to-green and white-to-yellow, or red-to-yellow and white-to-green, . You can do this while the PC is one and music playing until you get sound thru the speakers. There virtually no current running thru the wires and you can't hurt the PC by doing this.
If the speakers use an external power supply, have it plugged in and working when trying these connection options.
Sep 07, 2009 | Labtec LCS 1040 Computer Speakers
Meastro 4040 wont charge reliably
I had the same trouble exactly. The yellow power input socket has a pin and shield connection that must be contacting the center and side of the power input plug. I opened the Magellan and found that one side of the shield contact had never been soldered to the PC board. It was only a matter of time and use, before the piece moved up and away from the outer part of the power socket. A dot of solder solved the problem. The case for the Magellan is easily opened by removing four very small screws from the four corners of the black back and then prying the silver framed screen from the back exposing the printed circuit board. I am sure this completely voids the warranty with Magellan, but they will not repair out of warranty units anyway. Be aware there is a connector from the screen that is plugged into the circuit board. This is easily pulled apart with a pair of fine needle nose pliers and replaced the same way after the repair. The soldering should be done by someone with PC board assembly experiance.
Handy John
Feb 21, 2009 | Magellan Maestro 4040 GPS Receiver
Internal wiring
Hi - I have a Garmin GPS 126 in bits on my desk ready for a new cable as the socket in the back has some broken pins.
Also refer to the Garmin GPS to PC Wiring Instructions here on the Garmin site: http://www8.garmin.com/support/faqs/faq.jsp?faq=68
The internal 8 pin white connector on to the back of the circuit board is as follows:
1 Red Positive
2 Black Negative
3 Yellow Data Out
4 Green Data In
5 not used
6 not used
7 White Alarm
All the best, Tony at KiwiGPS, New Zealand
Jan 23, 2008 | Garmin GPS 126 GPS Receiver
44 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
