We sprayed glass cleaner and now there is a bubble behind the lens
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 21 Answers
Let it dry, glass cleaner are mostly alcohol and vaporize pretty fast
Posted on Dec 02, 2012
Black on the right hand side of a3 copies
This is normally caused by dirt on the glass - if you have some glass cleaner and a microfibre cloth give the lens a good spray, wipe gently in a single direction only - no swirling.
Dry the glass with a separate cloth. This should solve the problem
Sep 06, 2016 | Toshiba e-Studio 2051C Multifunction Color...
The sony xperia photo lense is fogged and wont take clear photos what can I do to fix it
This is quite common, if its what I think it is. The lens needs buffing down past the protective film, which is what's causing the 'fog' effect. For some reason it goes slightly opaque on some phones.
You'll need a soft cloth or lens cleaning kit of some kind, or glass cleaner... anything that will clean glass really well.
Take the back off the phone, spray some cleaner on a cloth/rag/glasses cleaner and start to polish the lens. You may/should see the tint coming off. It takes some time. I took me about 10 minutes to do my xperia mini, which had the same issue. Stick with it and to see if what you are doing is working take a few pictures and look at the results.
Jul 06, 2014 | Sony Ericsson XPERIA X10 Cell Phone
How do I clean the lenses of my rca HD52W67 t.v
With the set unplugged and rear cover removed---reach up and wipe the 3 large black lens with a lens cloth or a paper towel with glass cleaner sprayed on the towel.
May 15, 2012 | RCA Televison & Video
My HDTV rear projector picutre is getting darker - Problem/Solution?
if it is the model listed here pt53w53 the lens on the three tubes may require cleaning, a fairly easy process===with set unplugged remove back cover and clean the three large lens you see at the top--glass cleaner sprayed on a paper towel is fine or a lens cloth will do.
Mar 17, 2012 | Panasonic PT-53TW53 53" Rear Projection...
How do i get cob webs out from behind my screen
easy way is remove back cover with set unplugged and use a swiffer type duster, do not force the duster as you can scratch the inside of the screen.
At the same time also wipe the three large black lens with a lens cloth or a paper towel with glass cleaner sprayed on the towel.
Let me know if this helps as I am here to help.
SD TECH
Dec 11, 2010 | Toshiba Televison & Video
How to clean behind the screen. there is cobwebs and dirt showing when the tv is on. making a bad picture thanks deb
The safe and easy way to do this is to first unplug the set and then remove the back cover.
Most likely you are seeing spider webs; with the back off I use a swiffer duster with a fairly long handle. Clean the three large black lens you will see with a lens cloth or a paper towel with glass cleaner sprayed on the towel.
With the duster get all the webs and do not apply force for any attached to the inside of the screen.
Common problem and I have seen it many times. It is a good idea to clean the lens on the three tubes once a year--any dust on them will make the picture look somewhat darker and dull.
SD TECH
May 14, 2010 | Sony KP-53HS30 53" Rear Projection...
When copying, vertical lines appear on copy not the ink cartridge, they are new
clean the scanning glass with a lint free cloth as well as the glass from your top document feeder and the rollers in the top feeder. the glass may not look dirty but the scanning bulb is so intense it picks up any little particle of dust lint etc. what ever you do do not spray glass/lens cleaner on the glass, spray it on the cloth.
Mar 29, 2010 | HP Officejet 6310 All-In-One InkJet...
Need to remove the screen on ws55859 to clean mirror and lens, it is almost 10 years old and time to be cleaned.
Remove front speaker grill(s) at the bottom of the screen behind the speaker grill you will find four or more black screws hold the bottom in. Look carefully to see the front keyboard needs to be unplugged---usually one or two different size plugs; you may have to remove the inspection plate located in back of the speaker grill to get to the point where they can be disconnected, with the keyboard disconnected the entire screen lifts straight up(you need to bring it up 3-4 inches and then it comes straight out(there are two hooks on either side that it goes into--when you finish line up a little and slide it back until it is back in place.
Clean the mirror with glass cleaner and the lens can be cleaned with a lens cloth or with a paper towel with glass cleaner sprayed on it.
Replace the screws and the speaker grill unit for the set.
I do this here for free so if this helps you give me a vote here.
SD TECH (San Diego)
Aug 28, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
