Question about GoPro Digital Hero 3 Digital Camera
How do I remove moisture from hero 3 lens
We sprayed the lens with glass cleaner; now we have a moisture bubble on the inside of the lens
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 21 Answers
Let it dry... but don't put it on a heater
Posted on Dec 02, 2012
We sprayed glass cleaner and now there is a bubble behind the lens
let it dry, glass cleaner are mostly alcohol and vaporize pretty fast
Dec 02, 2012 | Televison & Video
How do I clean the lenses of my rca HD52W67 t.v
With the set unplugged and rear cover removed---reach up and wipe the 3 large black lens with a lens cloth or a paper towel with glass cleaner sprayed on the towel.
May 15, 2012 | RCA Televison & Video
My akaipth5498 projection tv shows a dark picture, even after adjusting colors. it looks like a bootleg movie.
If you unplug the set and look with the back cover removed you will find 3 large black round lens inside---light source (red,green,blue) for your picture--clean them with a lens cloth or a paper towel with glass cleaner sprayed on the towel.
Should be done about 1 time a year.
Apr 26, 2012 | Akai PTH5498 54" Rear Projection...
HI I HAVE A PHILIPS MAGNAVOX TV THE PICTURE IS DARK ,IT.S KIND A HARD TO SEE SOMETIME .WHAT CAN BE DONE ABOUT IT . PLEASE HELP. .
If this is an older rear projection TV as the model number indicates, you can unplug and remove back cover.
Inside you will see three large round black lens---these are for the 3 picture tubes: Clean all the dust and dirt off of them with either a lens cloth or a paper towel with glass cleaner sprayed on the towel.
The lens are the light source for your picture and if dusty the picture will gradually become darker and some what blurry looking.
hope this helps you.
sj
Sep 18, 2011 | Philips Magnavox 51MP392H Rear Projection...
Clean
YES, with the set unplugged remove the back cover and you should see the three large black lens--clean them with a lens cloth OR a paper towel with glass cleaner sprayed on it.
This is a ten minute job and should be done one or two times a year.
Let me know if you have questions.
SD TECH
Jul 24, 2010 | Philips 51PW9363 51" Rear Projection...
Cleaning the scaner window.
Since it is glass, you should be able to use a mild cleaner like eyeglass cleaner. Also, glass cleaner like Windex should should, but you should remember to spray the cloth and then wipe, not to spray the scanner as the moisture could mess with the electronics.
May 04, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
Lawn mower not quite starting
Sounds like you have dirt and/or moisture in the carburetor float bowl. Remove the bowl and clean it out. place a small pan or bowl under it when you start to remove it to catch the fuel and look for water. It will look like a "bubble" floating at the bottom of the fuel. Get a can of areosol carburetor cleaner with a long tube on it, stick the tube up in the hole where the bowl nut goes and spray it out to remove and fine dirt that may be in there. The following is in CAPS because I cannot stress enough, the safety and hazards of using the carb cleaner:
USE SAFETY GLASSES/GOGGLES AND BE VERY CAREFUL USING THE SPRAY - - IT WILL BURN YOUR EYES AND IF YOU HAVE SENSITIVE SKIN IT WILL BURN THAT TOO
Sep 15, 2009 | Garden
The picture seems to be getting less and less bright. can I clean the mirror on the inside of the cabinet or something
the mirror is usually not the problem----this set has 3 lens that if dirty will make the picture darker and somewhat dull. most of these sets you can unplug and remove the back cover and see the 3 black lens----clean them with a lens cloth or with a paper towel(spray on the towel first with glass cleaner)
Aug 08, 2009 | Sony KP-51HW40 51" Rear Projection...
4Runner headlight has moisture inside. Light works fine
yes. it should be a fairly easy job, just be careful when removing the glass, and make sure you get your headlight re-alligned when it is done, as it will fail its mot if not done.
hope that helps.
Mar 18, 2009 | 1999 Toyota 4Runner
Misty Images
Ouch!
  1. Make sure lens is clean on both ends. Use a lens cleaner NOT glass cleaner & use a cleaning glasses cloth. No paper.
  2. If that does not solve problem you have moisture (condensation )on you image pickup. you can take lens off let camera air out place clean lent free towel over opening to keep particles out off camera.
  3. If that does not work you will have to have it cleaned by a repair shop.
Going from hot or clod environments or wet climates can cause moisture to gather on image sensor & inside camera always try to keep camera in a camera bag & avoid sudden temperature changes.
Mar 08, 2009 | Nikon D40x Digital Camera
GoPro Digital Hero 3 Digital Camera Logo
173 people viewed this question
Top GoPro Cameras Experts
David Steeves
David Steeves
Level 1 Expert
abdul rauf
abdul rauf
Are you a GoPro Camera Expert? Answer questions, earn points and help others
