Question about Honeywell HZ365 Ceramic Compact Heater
I'm searching for a Honeywell HZ365 ceramic compact heater to purchase
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
This one is similar...
http://www.amazon.com/Honeywell-50250-S-99-97%25-Round-Purifier/dp/B00007E7RY/ref=sr_1_fkmr0_1?ie=UTF8&qid=1354484907&sr=8-1-fkmr0&keywords=Honeywell+HZ365
Posted on Dec 02, 2012
Honeywell HZ-338 thermostat problem
See if there is a little brass-looking bulb on a wire (sensing bulb) inside that can be moved away from the heat. My other thought would be maybe there is supposed to be some insulation between the control unit and the heating element that was inadvertently discarded?
Nov 27, 2013 | Honeywell HZ-338 Ceramic Compact Heater
Honeywell HZ 338 is turning on by itself
I have never heard of a heater coming on if its unplugged?? I could say if its plugged in and the control is faulty, it could come on by itself? Can you tell me more?
Shastalaker7
Mar 19, 2012 | Honeywell HZ-338 Ceramic Compact Heater
How many amps is the Honeywell HWLHZ370
Your heater is a 1500 watt model. Based on a house voltage of 110 Volts AC you should have about a 13.64 amp load. You might consider it a 15 amp unit to play it safe.
Mar 30, 2011 | Honeywell HWLHZ370 Ceramic Electric...
This heater sits for a year without use and now I can not turn it on. Does it have multi-button reset to turn it on again?
These types of plug in portable 1500 watt or less heaters use fusible links, limits, safetys etc some of which dont auto reset, many times failing due to one of these essentially non servicable components,I have several times taken these various defective heaters apart, rarely unless an older better built unit, have I seen fan motors fail, nor heat strips, 90% are some safetys/limit, the rest are the switch. unles you can bang or tap it to come on its through. I myself hack the heaters bypassing the failed part, often running them direct , no limit, fusible link or even switch, only to use them in situations where I wont sleep or leave the area, as there is zero safetys now! i do not recommend this to anyone except a technician, i have several motors and coils hanging by the cords running sans their plastic housings a naked heater, they work for years this way so clearly the limits/safetys are the weak pots on these units, by design I suspect.
Dec 16, 2010 | Honeywell HZ365 Ceramic Compact Heater
THE HEATER RUNS FOR 2-3 MINUTES AND AUTOMATICALLY
Thermal safety is tripping, clean it out , no repairs viable for theses units,
May 23, 2010 | Honeywell HZ365 Ceramic Compact Heater
Honeywell
You have too many things on the circuit you are on. Either move it to a different plug, or turn some things off. A plug in heater uses as much electricity as the breaker should carry if it is a 15 amp, like most are. Try to find a plug on a different circuit, or clear some things off of it.
Dec 22, 2008 | Lasko 5540 Ceramic Compact Heater
Help me please
we want to know haw to use it
Oct 15, 2007 | Honeywell HZ365 Ceramic Compact Heater
Heater kicks out
Honeywell heaters like HZ3650 have a screen on the air inlet at the back side of the heater. This screen can be partially blocked off by an accumulation of lint, etc. The lint blocks some of the air flow which may cause heat increase within the heater to the point that the safety shutoff thermostat shuts off the power. Operation is returned after a cool down period only to repeat the shut down cycle after a short period of operation. If this is the cause of the problem the screen must be cleaned.
Sep 19, 2007 | Honeywell HZ365 Ceramic Compact Heater
Similar model compact heater will not "power up" after storage
they is no reset internal the electronic circuit is deferctive some electronics parts need no be changed. i have fixed one and modify it to be more reliable.
Oct 01, 2006 | Honeywell SureSet HZ-339BW Ceramic Compact...
Honeywell HZ365 Ceramic Compact Heater Logo
106 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
