Question about Maytag SAV5710 Top Load Washer
Maytag performa washer basket leans to one side and goes off balance in spin cycle no matter how big or small the load is. what could be the problem?
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Open the unit and check the suspension springs.
Posted on Dec 03, 2012
  • Steve Mahoney Dec 06, 2012
    I did yake the cabinet apart to look at the springs and they seemed to be all connected to the drum and lower supports. When I movwd thw washmachine from its location I did notice a big pile of white plastic looking dust under it. So I am not sure but I think the snubber ring is bad. I dod not have a tool to pull that apart so I guess I am going to have to call a repair man to come and fix it unless there is a nother way for me to do it.
    sorry about some of my spelling
SOURCE: maytag top load washer
This solution applys to many Maytag washing machines. Perhaps not all.
Maytags have three damper pads in the bottom of the machine that must be lubricated from time to time. If they are not, they can be ripped off. They are glued to the bottom of the machine, the drum rests on top of them. When they become dry or lost, the machine shakes violently and no amount
of leveling or load balancing will fix it. Replace and/or lubricate the pads and magically it works again.
This is not a difficult repair for those that have modest mechanical skills and a few basic tools.
replacement pads and lube come in an inexpensive kit.n
I will create a web page with instructions if there is interest.
Posted on Sep 10, 2008
  • 641 Answers
SOURCE: Maytag Performa PAV1000AWW top load washer
Try to replace the capacitor. Good luck
Posted on Jul 19, 2007
  • 84 Answers
SOURCE: Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Posted on Jul 27, 2009
SOURCE: Maytag Performa Washer spins out of balance
There was a recall on the washer base, which caused the unbalanced problem. Find Technical Buletin TDL-0050B-B issued by Matag.
Posted on Oct 09, 2009
  • 152 Answers
SOURCE: I've got a Maytag Performa, problems with spin
You may have an oil leak from the tranny leaking onto the friction ring at bottom allowing tub move to freely
Posted on Feb 17, 2010
Why does the Drum spin erratic even without clothes in it?
might be a warped spin basket or the dampers could need to be replaced. could even be a bad spin bearing. if it was bearing, normally would be associated with a loud noise during the spin cycle though.
Feb 27, 2015 | Maytag Ensignia MAV2757AWW Top Load Washer
I need to know how a maytag performa pavt-1 washer drains. does it drain beneath the agitator or through the holes in the basket?
It drains through the holes in the plastic tub. You may hear a sloshing sound when you move the tub and this is normal. There is a solution sealed inside the tub on this unit to balance out the spin cycle.
Sep 01, 2011 | Maytag Performa PAV2200
Maytag Performa Washer PAV1000AWW. Shakes when spinning out
My washer doesnt drain in the rinse cycle?? dont kno what to do
Feb 15, 2010 | Maytag Performa PAV2200
Maytag washer tub leans to the right
I have a Mayag Washer and dryer The washer someimes spins of balance. the dryer has no heat, this just started. would it be the element?
Oct 23, 2009 | Maytag Performa PAV2200
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
Jul 05, 2009 | Maytag Performa PAV2200
Leaks water on floor and spin cycle very loud
if it sounds like a boeing jet, you will need a new seal & bearing kit. This is something a technician would have to do. many "special" spanner wrenches and spring tools required
Feb 23, 2009 | Maytag PAV2300 Top Load Washer
My PAVT920AWW won't spin hard enough to get all the water out
I have had teh same problem. I calledin the Maytag service and they did replace something out of goodwill but the technician told me that the load balance sensor is sensitive. If your load is unbalanced then the machine will spin slowly so it does not walk across the floor. With larger loads the wieght will make the machine bang against the sides and walk.
The solution is quite simple. Make sure the load is balanced. The agitator has a way of unbalancing a load from time to time so you need to do this manually. It is a very rare occurance and it is best to make sure your load goes into the machine balanced first.
Dec 19, 2007 | Maytag Performa PAV2200
Maytag SAV5710 Top Load Washer Logo
145 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
