Question about Philips PET710 Portable DVD Player
Black spot on the screen
My DVD player has a black dot about of size of a quarter in the upper region of the screen. Do you know what caused this and how to remove it?
  • TERMATT May 09, 2009
    I ALSO HAVE TWO BLACK SPOTS ON MY SCREEN. CAN YOU HELP. THANKS YOU
    President:
  • 814 Answers
This could be caused by a number of problems, such as a bad power inverter or bad backlight. This could also be a problem with the LCD screen malfunctioning. You can call Phillips customer support and give them the model number of your DVD player. Tell them about the problem with the malfunctioning LCD screen. They will help you find a solution. You can also visit the Phillips website and go to the customer support and put in the model of you DVD player and check the frequently ask questions and troubleshooting section to see if this is a know problem with a solution already found. The website is http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=PORTABLE_DVD_PLAYERS_CA&sct=PORTABLE_DVD_PLAYERS_SU&g Just click on the address and it will take you to the website. I hope this information helps you with your problem.
Posted on May 31, 2009
I have a sony lcd projection tv model kf-60xbr800, green spots on the lower right corner , it start with one spot and now the spot are all over the screen
Those Rear LCD TVs get bad light engine on some. Causes fuzzy spots size of quarter. Or sharp small bright spots looks like road map or 'stars'. Need new/rebuilt light engine.
Apr 08, 2014 | Sony Grand WEGA KDF-60WF655 60" Rear...
Region unlock code
You can get a region free code for your player from these WEB sites.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/
www.download-info.com/dvd/index_new.htm
Feb 14, 2013 | Philips PD9012/37 9-Inch LCD Dual Screen...
My tv screen has a black spot
HI,
Are you sure that there is balck dot on the sreen. Check one more time is it any dust on the screen.
Black spot Means pixel of the Lcd sreen is fault. There are thousands of pixels in an lcd screen. when any of the pixel or a group of pixels become faulty the black spot will appear. Its not possile to rectify the problem other than replacing the LCD panle if its avilable. The avilability of lcd screen is very rare.
Ajin
Jun 16, 2012 | Emerson EWL20D6 Television
On my toshoba pc 17'' sreen I have black spot on the top corner and the bottom of my screen , is my screen diying oley one year old
There are two types of black spots. The first, I call bruising. This is a dark area on the screen that can vary in size and still allows for proper viewing. The second is a black dot. If it is a black dot about the size of the period in this sentence, it is a dead pixel. Most manufacturers allow for up to 5 dead pixels before they will treat it as a problem. In either case, dead pixels and bruising are more of an annoyance than anything. I have seen screens with both issues work for up to 5 years under these conditions. They will eventually fail but how long it takes it to fail, is anyone's guess. There are numerous outlets for new or used screens. If you plan on keeping this for a while, I would recommend contacting the manufacturer to see if they will do anything or pick up another screen and have it on hand to replace it if it should fail.
Dec 25, 2009 | Belkin Computers & Internet
Canon power shot sd1000 black dot on lens
If by saying the upper right corner of the lens you really mean that there is a dark spot on each image AND the rear display, there may be dirt or dust on the lens itself. Clean the lens with an optical quality cleaner. Do not use paper towels and Windex or the like - as paper towels can scratch the lens.
It is also possible that the dark spot is a "stuck pixel" on the image sensor inside the camera. There is no way to repair a stuck pixel outside of replacing the sensor. Any dark spot (regardless of source) can be edited out by using image editing software. This will allow you to to make the dark spot less noticeable - or practically invisible.
If the dark spot is on the rear display only, it can also be a result of a "stuck pixel" on the display itself. This should not show up an images, but only on the display. There is little that can be done outside of replacing the entire rear screen.
There are other things that can cause these problems, but those listed above are the most common.
I hope this was Very Helpful and good luck!
Nov 20, 2009 | Canon PowerShot SD1000 Digital Camera
I repaired the female power jack in my Averatec and must have compromised something else in the process as now my screen has two large black quarter sized black spots, on quarter of the screen at upper...
If you put any pressure on the screen while repairing the power jack then yes, the LCD will need to be replaced. If you are certain that you did not physically damage the screen during the repair then it is possible that you damaged the motherboard (which houses the video processor). If the motherboard was damaged I would say it's time for a new laptop.
Aug 24, 2009 | Averatec 3200 Notebook
I have black spots on my monitor screen that seem to multiplying.
The black dot will just grow until the rest of the screen fades.
It is pixels dieing in the monitor
Jul 22, 2009 | Computers & Internet
All region code for Medion DVD recorder MD84100
Found on another board, tried and it worked on my Medion
P70002 / MD84100 DVD recorder:
Turn on DVD recorder
Press HOME on remote
Go to SETUP in Easy Menu
Move down to padlock icon
Press 0 seven times
Message appears:
Congratulations!
Region Change Free!
YES (press ENTER)
It now plays US and UK as well as Australian (in my case).
Dec 31, 2008 | Electronics - Others
Dell W3000 display issue - band of red dots on the left side
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 11, 2017 | Dell W3000 30 in. HD-Ready LCD Television
Philips PET710 Portable DVD Player Logo
237 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
