Question about GE ZDW24A Wine Cooler
How to remove GE ZDW24a RBB wine cooler - GE ZDW24A Wine Cooler
4 Suggested Answers
  • 19 Answers
SOURCE: My GE Profile wine cooler temp does not respond to any temps
Call GE answer center 1-800-626-2000 ask for tech help,have Model # off data plate ready.
Posted on May 09, 2009
  • 358 Answers
SOURCE: Ice build-up on GE ZDW24A wine cooler cooling coil
Probably the thermostat is bad , you can bypass it by putting together the two wires from the thermostat and if the unit starts working ,replace the thermostat ;only do this if you havesome knowledge of electrical work and be very carefull.
Posted on Nov 04, 2009
  • 403 Answers
SOURCE: I have a GE ZDB24A under counter wine cooler that
check the door seal, make sure that its not ripped or dirty. Its possible that moisture is entering the wine cooler thru the door gasket. Frost is normally the result of warm moisture mixing with cold air. The door gasket should be the problem. if you thoroughly examine and its fine, let me know and we'll go to the next step.
Posted on Feb 06, 2011
I have a GE Monogram Wine Chiller ZDW24A RBB. Everything works fine, but today the light stopped turning off when I shut the door. I checked the sensor on the bottom and it seemed to be in order. H
On the right of the thermostat on the grill below the door is a rocker switch, turn it off as this is a light switch not a power to unit. Its just the switch was turned on during your cleaning process. Good Luck
Oct 14, 2014 | Furniture
GE Refrigerator Model ZDWC240NABS not cooling
if it is a clicking sound maybe it is a relay. try replacing that
Oct 27, 2012 | GE Monogram ZDWC240NBS Stainless Steel...
I have a GE ZDB24A under counter wine cooler that continues to frost up regardless of the setting. I have a second cooler downstairs which stays clean - no frost. What do I need to do?
Feb 06, 2011 | GE ZDB24A Wine Cooler
Nov 04, 2009 | GE ZDW24A Wine Cooler
The compressor and the fan don't run.
its your contactor or the wire feeding it
Aug 16, 2009 | GE ZDW24A Wine Cooler
Thermosthat doesn't work
Hi , yes it sounds like the thermostat is stuffed.  To replace it is relatively simple but always keep in mind , switch off and un-plug it before working on it for safety ,  to replace it you will need a phillips head screw driver , a flat screw driver and a note pad,  where the dial is , that is the thermostat , the surrounding screws are what hold it in position so removal is only a matter of having a real good look inside . Thermostats for this purpose are about $15 to $35 dollars depending on your country . replacement time is about a hour depending on how much trouble to have getting the old one out. remember that this device has a small alloy tube which is the sensing part of the thermostat , be careful not to damage this because it carries a small refrigerant charge which is the primary temperature sensor so please be very careful and above all take your time .
I hope this helps you ,
Thank you and have a nice day:)
May 12, 2009 | GE ZDW24A Wine Cooler
May 09, 2009 | GE PWR04FANBS Wine Cooler
GE ZDW24A Wine Cooler Logo
104 people viewed this question
Top GE Furniture Experts
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Day Coker
Are you a GE Furniture Expert? Answer questions, earn points and help others
