Question about Toshiba Satellite Computers & Internet
My toshiba l675d-s7013 laptop screen won't come on?
    Sergeant:
  • 206 Answers
Hi
turn off your laptop take out the battery and hold the power button for 20-60 secs to discharge it and then put the battery back in and reboot or remove the battery and the ram clean the ram or try another stick of ram then press the power button and see if that restores your laptop.
if not plug another monitor into the external vga port, if the external monitor works then your laptop screen is faulty.
if the external monitor is also black or blank then the inverter inside the laptop needs to be checked or replaced.
cheers
Posted on Dec 02, 2012
raimund24
  • 83 Answers
SOURCE: I INSTALLED ON MY LAPTOP TOSHIBA SATELITTE L675D
Your problem might be solved if you connect your UTP cable back to your PC then after that install driver checker:
driver checker will update your system missing drivers.
Posted on Dec 26, 2010
prashant2012
  • 1127 Answers
SOURCE: i want to buy a
Hi
Please click the mention below link to download the CD application Creator
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2760012&rpn=PSK3JU&modelFilter=L675D-S7052&selCategory=2756709&selFamily=1073768663
Posted on May 11, 2011
Khman
  • 180 Answers
SOURCE: what is the difference between a toshiba
Hi
Here is the webpages for both models, you can check and choose the best for you
  1. Toshiba L675D-S7100
  2. Toshiba L675D-S7107
Please tell us your impression
Good Luck
Posted on May 14, 2011
  • 1082 Answers
SOURCE: my laptop won't go on properly just has a
Sounds like you have the "blue screen of death" , BSOD, problem. You need to determine the error message so it can be fixed.
Restart your computer and hit F8 several times a second until you have a black and white scree with several options. One will be "turn off restart on error" Turn that off.
Now when you get the error you can see what the message is. Post it here for more help.
Posted on Oct 10, 2011
SOURCE: hp laptop keyboard won't type "b n 1"or ''tab esc'' other keys ok..
Either your keyboard cable needs to be reseated or your keyboard is going bad and needs to be replaced. The keyboard cable is under the keyboard and it attaches to a slot on the motherboard. You'll have to partially disassemble the laptop to get to it. Hopefully you're not having this problem because you spilled a liquid on the keyboard.
Here's a fail safe alternative. Bring up google's website www.google.com and in the search box type "download.cnet.com" (without the quotes) and click the link to go to their site. When the site comes up look immediately to the left and you will see a gray area that says Find Software. Type in "free virtual keyboard" (without the quotes) and click the mirror to search. It will bring back a page and the Free Virtual Keyboard is listed first. Look to the right of it and click the Download Now button. Download and install it. Once it is install you can look in Start/Programs and right click on it and select Pin to Start Menu then right click again and select Desktop (Create Shortcut). It's a neat keyboard to have just in case your real keyboard goes bonkers. You simply click on the letter with your mouse pointer that you want. It has all the functionality of a physical keyboard. You can open a web page, place your mouse in the address line then bring up the virtual keyboard by clicking on it from your desktop or start menu and it will sit on top of whatever you were trying to do. You can move it to see the typing area as you click on a letter. It works the same way if you opened a word document. In your case anytime you need the space bar, just click on it.
Posted on Mar 21, 2012
I have a Toshiba L675-S7013, it powers on but won't boot.
I think so, because when it tries to post aznd finds no ram you will get beep code
Jan 30, 2013 | Computers & Internet
Satellite L655D-S5093 keyboard removal
This is the User's Manual for the L655-S5098 laptop:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2759985&rpn=PSK2CU&modelFilter=L655-S5098&selCategory=2756709&selFamily=1073768663
Predictably, its useless when performing maintenance such as keyboard replacement, but page 82 indicates that this laptop supports "most USB-compatible [external] keyboards", so, while the chicklet keyboard is down, you can boot and use the system with a workaround USB keyboard.
I could not find an L655-S5093 laptop model on the Toshiba support web site, which is found at http://www.pcsupport.toshiba.com
The closest I could locate for you are these two How-to Guides:
Here's a teardown of the Toshiba L645/L645D laptops:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/remove-laptop-motherboard-1.htm
Here's a teardown of the Toshiba L675D laptop:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L675D-L670D/dismantle-laptop-1.htm
Nov 27, 2011 | Toshiba Computers & Internet
Need to remove a bios password on a toshiba satellite L675
basically your only option is to take it to a Toshiba dealer or repair depot with proof f ownership. Then they can reset things for you. Some charge for this, some don't but most shops want to make sure you own it which is why you need the bill of sale. It only takes a minutes and uses a master password (you won't find that out on the net anywhere )so unless they are certified by Toshiba a shop won;t have this.
It is a pain to have to do to reset it but the password is stored on a chip on the motherboard and other than replacing ihe chip this is the only way around it.
Sep 01, 2011 | Toshiba Satellite L675D-S7046 Laptop
I could not find my computers video card driver.My computers mark Toshiba Satellite L675D-S7052.Can you help me?please
Hi!
You here is a link for the drivers and softwares for your Toshiba Satellite L675D-S7052. Please click this link Toshiba Satellite L675D-S7052.
Jul 20, 2011 | Toshiba Satellite L675D-S7052 Laptop
Whats the difference between a toshiba L675D-S7100 and a S7107? which is a better laptop
http://us.toshiba.com/computers/laptops/satellite/L670/L675D-S7107/ is the link for the s7107 and http://us.toshiba.com/computers/laptops/satellite/L670/L675D-S7100/ for the s7100
the s7107 is better out of the two because of the better processor and it has a blu ray drive BUT if you dont need the blu ray drive save the 120 dollar difference and get the s7100 as for the price difference you wont notice much if any difference in speed with the processor also on the right of the page look at the ones near the bottom that have the intel i3m processor for around the same price its much better
May 14, 2011 | Toshiba Computers & Internet
What is the difference between a toshiba L675D-S7100 and a L675D-S7107 and which is a better laptop
Hi
Good Luck
May 14, 2011 | Toshiba Satellite L675D-S7100 Notebook PC
I want to buy a recovery dics for toshiba laptop satellite l675d - s7052. But i don't know where it's bought.
I do not believe Toshiba sells recovery discs, instead they have a utility called Toshiba recovery disc creator. Which should already be on your laptop if not download from Toshiba website.
May 11, 2011 | Toshiba Satellite L675D-S7052 Laptop
Computers & Internet Logo
238 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
