My e machines home computer won't come out of.
  • 2,072 Answers
Power save mode is just the message a monitor will display when there is no video signal from the computer to the monitor.
If the computer has no lights the problem is most likely the power supply and it will need to be replaced. Pretty easy to do, youtube it for tons of videos.
It also could be the motherboard is bad. I would start with the power supply first.
Posted on Dec 03, 2012
SOURCE: power saving mode upon start up
i) usually an computer enter's into power saving mode if computer monitor is not receiving any singals from the computer tower, so it has nothing do withur computer monitor(computer monitor is working fine), there is some problem withur computer tower.
ii) now try  removing all the physical connections going to computer tower(back side), wall socket  and replace them ....., (to avoid loose connections)
   now see whether ur computer is turning on and working properly so that your computer monitor receive singals ....
  let me know what is happening
Thanking you
M. Sridhar
Posted on Jan 02, 2009
  • 1575 Answers
SOURCE: dell 8200 beeps 10 times monitor won't come on says power saving mode
Hi
Remove the sound card and blow the slot with dry air to rid off dust.
Examine it to make sure nothing's damaged and fix it again.
Checkout the RAM's.Probably remove them,wipe the slots off dust and fix them again.Make sure they're well seated on their slots.
Posted on Feb 05, 2012
tomba_nzxt
  • 205 Answers
SOURCE: I have a presario SR1250NX and it won't come out
if you are not an technician i'd suggest to take it to the service center.
i think it might be the psu/memory related issue and as an user you are not able to remedy the situation yourself
Posted on Mar 09, 2012
flamez_fu
  • 47 Answers
SOURCE: windows XP won't load on my emachine t3516
You may need to check to make sure Windows XP was installed properly, if the computer had crashed, you can do a repair, I am a computer technician, and I can tell you, that replacing the power supply will not do that.
Posted on May 22, 2012
SOURCE: computor won't power up. in power saving mode
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Posted on Jun 07, 2012
Bobbin won't wind and display shows me in bobbin wind mode and won't turn off, so i can't use the machine at all
it sounds like it's a problem with the computer motherboard and the
machine needs to be checked
Dec 04, 2012 | Sewing Machines
Have a E-Machine that keep displaying in powersave mode
eMachines are a budget computer.
Designed to save the consumer money.
One of the items used that cost is saved on, is the Power Supply.
Power Supply is generic, and of low quality.
1) Low quality Electrolytic Capacitors
2) Low quality Power MOSFETs
3) Low quality Rectifier Bridge
4) Too small a gauge of wiring is used
Plus most consumers do not keep the inside of the computer clean, and if they do the Power Supply is usually neglected.
The two leading causes of desktop computer failure; the computer is dirty inside, and/or the Power Supply is bad.
With a weak voltage power rail you may see LED's light, and maybe fans spin, but there won't be enough power to turn the Processor on.
[No Processor operating, no computer. No computer = no video signal to the monitor. No Signal, Power Saver Mode, or Sleep Mode is indicated ]
1) If ALL of the LED's were lit up they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use from 51 to 125 Watts of power.
Just depends on what Processor it is.
See if there is an unused working computer that has a KNOWN to be good, Compatible power supply; that you can use for a test unit.
Or use a multimeter to test the three main voltages, coming out of the Power Supply
3.3 Volts (DC) [ Orange wires ]
5 Volts (DC) [ Red wires ]
12 Volts (DC) [ Yellow wires ]
[ALL Black wires are Ground wires ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 16, 2012 | E-Machines Computers & Internet
My computer won't turn on
when it is blinking red it means its in sleep mode. at that time the fan is turned off by your computer to save power. Press the power button oce again and u should have it up and running.
Aug 15, 2012 | HP Computers & Internet
Dell logo won't go away.
If you are lucky a hard power reset will fix this. Disconnect all the cables, hold the power button on for 10 seconds, release the power button, reconnect the cables and turn it back on. Otherwise you may have a hardware problem.
Jul 09, 2017 | Dell E2210 22" Widescreen Flat Panel...
Forgetting that the computer was on, I went to turn it on and shut it off while in sleep mode. The screen won't work.
A monitor does not normally save any states such as sleep. If unplugging the monitor from the power source for ten to twenty minutes and re-plugging it in does not fix the problem check and see if the monitor's menu comes up.
Even in sleep mode, the menu for the monitor should show. If it does, try resetting the monitor to factory default settings. If the menu does not show up, then there is an issue with the monitor.
Jul 04, 2012 | Dell Computers & Internet
Windows XP won't load on my emachine t3516
May 20, 2012 | E-Machines eMachines Desktop PC
Dell 8200 beeps 10 times monitor won't come on says power saving mode
Hi
Feb 05, 2012 | Computers & Internet
My iphone is hanged its shows apple logo only, hw can i solved this problem without loosing my all data,like my videos,contacts,pictures,pls help me out
Try pressing and holding both the POWER & the HOME button at the same time for around 3 to 10 seconds until it turns OFF. Then turn it back on again.
If it still won't go past the Apple logo, use tinyumbrella to Fix Recovery or to Exit out of Recovery. Download tinyumbrella using the links below: for Mac for PC (Windows)
Update tinyumbrella first if it tells you that there's newer version available.
NOTE: Your computer must be able to recognize your iPhone before you can use tinyumbrella to fix it. If your computer could not recognize your iPhone, you first need to put it to DFU mode. To learn more about DFU mode, CLICK HERE.
If those things still don't work, you'll have no other choice but to restore. Again, your computer must be able to recognize your iPhone before you can restore it using iTunes. Put it to DFU mode if your computer won't recognize it.
Read more tips for iPhone, iPad and iPod touch, CLICK HERE.
Apr 25, 2011 | Apple iPhone 3G
Dell Monitor Power save mode activate using pc
yes right click on desktop select properties then click on screen saver then increase wait time problem will solved
Oct 29, 2008 | ViewSonic VE155b 15" LCD Monitor
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
