How do you replace batteries in a sony rm-sp350 remote
How do you open remote to replace batteries?
    Top Expert:
  • Televison & ... Master
  • 35,654 Answers
On the back of the remote, press the battery compartment cover where indicated and slide the cover off. It may be difficult to remove
Posted on Dec 04, 2012
  • 23 Answers
SOURCE: it is broken. I have sony integrated remote commander RM-AV3000 .Need codes
what is a mySTR-DE698? but more generic, like brand and what it does. TV or DVD etc...
Posted on Oct 15, 2008
  • 17 Answers
SOURCE: sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Posted on Oct 30, 2008
SOURCE: How to open remote control Sony RM-Y181
I had open a Sony RM-GA010 because the transmitting bulb was stucked inside after a fall. The two screws inside the battery compartment was not really holding the case together. I used two flat screwdrivers working on the side of the remote control; one levered open a bit and the other slipped in further and levered more to split it open. I think a blunt knife may also do the job; but never a sharp one because it will be too dangerous. You need to accept some permanent depression at the edge of the control (better than a useless remote). Once you open some part, it become much more easy. After opening the outer case, you can access the buttons, but not he transmitting bulb in my case. I need to loosen two additional screws (i.e. totally four, including the two inside the battery compartment) to loosen the electronic board a bit and I could correct the bended transmitting bulb. Then put everything back, clicked up the case and the remote worked again!
Ben
Posted on Aug 29, 2009
  • 19 Answers
SOURCE: Code for Sony RM-V310A remote.
try going to and plug in the information there and see what you get
http://www.oneforall.co.uk/us_US/support
SOURCE: how can i open my sony rm-ed009 remote control
insert wide flat blade (such as a wide flat bladed screw driver) into seam along one side. Twist carefully until seam starts to prise apart - carry on until you hear the "crack" of the press-tabs coming apart and repeat along the the length of the seam until you can carefully pull it apart.
Posted on Jan 02, 2011
How do you Open Sony rm-yd059
SONY RM-YD059 remote is easier to disassemble then other models. Slide battery cover open 1 inch or half open. Using a plastic toothpick or similar device pop cover using the groove. There are three sliding locks on each side. You will now see six screws holding halves together - remove. There are six more clips holding remote together. Starting at the top working towards the bottom, there are three per side, location of clips at red and blue buttons, at between 4&7 and 6&9 rows, and finally at muting and jump buttons. Voila - Happy cleaning. Note: directional ring is keyed with thin and fat tabs, fat tabs are positioned towards the bottom.
Feb 04, 2013 | Sony RM-YD059 Remote Control 148947911
Sony internet tv remote stuck
open the remote control and clean the keypads from dirty, corrosion, oxide, and bad contacts, with c. cleaner very well. with carefully.
2) replace a new battery with the same type:alkaline
3) clean the contacts batteries with c. cleaner
4) try again.
5) if the problem persist you have 2 options go to repair shop TV for fix it, or REPLACE IT.
God bless you
Oct 12, 2012 | Sony RM-VL1000 LCD Remote Control
Sony Remote RM-YD035 does not change channels or turn off TV
You have worn those buttons on your remote out. Those are you most used buttons. You can have you remote repaired by pros here. You can buy a new Sony RM-YD035 here. Or you can purchase the keypad repair kit here and fix it yourself.
Oct 05, 2012 | Sony Rm-yd035 Remote Control
Hi my name is Oscar I have a tv element model FLX-3211B and do not work the remote control codes sony RM-VZ320 and need help please!
Please reset the codes and try again. You must replace the batteries by new ones type alkaline b) clean the contacts batteries c) retight the spring contacts batteries with pliers d) open the remote control for clena the keypad switch from dirty, dust, oxide, bad contacts or open , remember they send infrared signal from Syscon to the microncontroler Receiver. see the blck..d
go to the next web pages, give your model, mark.
www.remotecodelist.com + remotes.com
God bless you
Jul 29, 2012 | Sony RM-VZ320 Remote Control
Disassemble or open the remote control Sony RM-YD035
if Sony Remote RM-YD035 does not change channels or turn off TV, the buttons got dirty coz those are you most used buttons.
You can repair Sony Remote RM-YD035 yourself. It's quite easy and fast, with perfect result!
To disassemble or open the remote control Sony RM-YD035, first remove a single screw in the battery compartment. Then use a very thin but strong screwdriver and insert it between top cover and the body at the back part of the battery compartment. Move the screwdriver up and down and slowly move it to the left and to the right and continue along the perimeter. Use two or three such screwdrivers and in 2-4 minutes the top cover plate with buttons will separate from the body/bottom/casing.
Clean both parts thoroughly. And then gently put them back together in the opposite order. The parts will snap closing.
You are done.
Mine is now working perfectly
Apr 01, 2012 | Sony Rm-yd035 Remote Control
How to fix a Sony Tv RM-YD026 remote after getting milk in the buttons
take batterys out then take out the little screws in battery compartment pry open the two halfs clean the board and buttons and let dry dont wipe the carbon off it is the main part of the switch for the buttons just clean with water and let dry
Oct 20, 2009 | Sony RM-YD023 Remote Control
There should be small screws (usually phillips head) at either the top, bottom or both ends of the back of the remote. Unscrew those and pry loose. If not, they will be under the batteries, inside the battery cover.
I assume that's what you mean by open?
:D
Aug 10, 2009 | Televison & Video
Sony universal remote will not operate sony dream system
Solution is to buy Sony original remote for DAV-FR10W system from Sony Accessories Store under following part number..
147869811 RM-SP350 REMOTE CONTROL
Feb 05, 2009 | Sony DAV-FR10W System
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
Electro Med Services...
