Question about Champion International Garden
2003 case 580sm engine has troublr starting and runs for a few minutes and dies
Drained fuel.changed filter.cranks catches starts dies .finally runs better and better then runs fine high idle then dies and just cranks doest catch and so on
  • 22 Answers
SOURCE: engine turns over but won't start
your starter bendix is bad
a common problem
any small engine shop will have a new one
Posted on Nov 27, 2008
SOURCE: Lawn mower engine runs rough and puts out white smoke
Pull the carburetor and clean it for staters.Be sure to change oil any little bit of moisture in the crankcase will let it smoke white by seeping by the valves and piston rings.Also put a little small amount of dry gas in the gas tank to rid all of the water that may have been left in the tank. I some of this will help you.
Posted on Mar 19, 2009
  • 202 Answers
SOURCE: craftsman garden tractor stalls after running for about 20 minute
do you have the right fuel filter? some are for pressure and some are for gravity feed, the pressure type (fuel pump) wont flow the gas correctly. another possibility would be the coil.
Posted on Jul 07, 2009
  • 302 Answers
SOURCE: Model Number 917272670. 17.5 HP Craftsman Lawn
Sounds like coil is giving trouble after getting warm poss need to replace coil.
Posted on Jun 30, 2010
SOURCE: John Deere 115 lawn tractor - won't start.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Posted on Aug 18, 2010
White smoke from exhaust and rotten egg smell then engine dies
Are you the Joe Thomas from the Cleveland Browns. I think your right the crank sensor lets it start then it dies a few minutes later. My blazer did this and i replaced the crank sensor and i ran fine again.
Apr 18, 2014 | 2003 Chevrolet Blazer
Car dies intermittently
check your fuel filter & fuel pressure. best place to start.
Dec 25, 2013 | 1995 Oldsmobile Ninety Eight Regency
Car takes a long time to start, like a few minutes. Runs fine once it finally starts. It gets closer the longer you crank. Changed pugs, fuel filter and some vacuum/pcv pieces, No difference.
FUEL PUMP GETTING BAD THE CHECK VALVE LETTING ALL FUEL DRAIN BACK TO FUEL TANK.HAVE VECHICLE SCAN FOR CRANKSHAFT SENSOR FAULTS. CAMSHAFT SENSOR FAULTS.
Dec 22, 2010 | 2002 Audi A4
1991 nighthawk won't start. battery is drained so jumped it. cranks fine. At first it would start for a few seconds then die. Now it just cranks and cranks. I cleaned spark plugs. Checked plugs for...
test battery for holding a charge-must hav over 12v to run rite-thats the problem with batt-coil ignitions--they dont run off alternator like a car once started--r ur carbs clean-thats an old bike--mite need a compression test too
Sep 27, 2010 | 1991 Honda CB 250 Nighthawk
03 Altima 2.5, Wont turn over on cold start
First, change the fuel filter, and make sure the lines are good. Check the intake manifold bolts for tighness, check all vacuum lines. Best to have it running, wiggle them around and listen for a hiss. Lastly, change idle control sensor, if the other suggestions don't make a difference.
Jun 30, 2009 | 2003 Nissan Altima
My diesel truck won't run for more than ten seconds.
It sounds like a fuel leak - possibly around injecrors. Papa-D
Oct 24, 2008 | 1986 Ford F 250
Stalls / Dies / dead
this engine fuel pump prassurae low. it fuel pump celan. Your problem sovel
Jul 13, 2008 | 2003 Ford E150
Garden Logo
24 people viewed this question
Top Champion International Garden Experts
JohnPaul Robertson
Douglas Wade
Douglas Wade
Level 1 Expert
Jordan Lee
Level 1 Expert
Are you a Champion International Garden Expert? Answer questions, earn points and help others
