Question about Maytag Washing Machines
Machine will not start
Cam appears ok, I subspect switch is not making contact with cam
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 03, 2012
I can't start the wash cycle. I turn the dial on but the start button doesn't light up. What can I try?
Make sure that power is reaching the unit. Having confirmed that then proceed to see that the power is being properly directed to other components. Check switch contacts., cams.
Feb 15, 2016 | Washing Machines
Why is my start button not working after I replaced the control board on my fishel paykel washer and everything works except the start button...what could be wrong?
Door switch not making contact to let panel know it ok to start
maybe something on door that's keeping it from full contact with switch
Feb 15, 2015 | Washing Machines
Cannon image runner 2525 error code E0000002
on the control panel press:
aditional function
aditional function
should appear ins screen "#sssw"
search with the left arrow until "CLEAR" appear on screen
press ok
search with the left arrow until "ENGINE" appear on screen
press ok
the screen displays: ERRCLR press ok again
turn off the machine from the main switch (located on the left side of the machine) for 5 seconds
turn back on the machine and try to make some copies
if problem persist replace fixing film assembly
Apr 28, 2014 | Canon imageRUNNER 2200
Not stitching correctly after using pattern selectors - zigzag very messy stitch
Describe in more detail a messy stitch. It may be the cam follower that creates the patterns is not aligned and is contacting two different cams at the same time. The machine then sews both patterns at the same time. The solution may require an expert.
Apr 03, 2014 | New Home Sewing Machines
Series 60 washer = Fill does not turn off.
Washing machines use timers to set fill and empty cycles. These have micro-switches that contact cams turned by the timer motor. Cams are circular metal discs with high points and low points. Something is probably misaligned. You usually can manually turn the timer control. If you turn it directly to the empty cycle and the fill valve opens, then the micro-switch controlling the fill valve is not contacting' the cam. It may just require bending the bracket holding the micro-switc.h so that it will contact the cam
Oct 04, 2013 | Kenmore Washing Machines
I have a Rowe ami R92 jukebox, when I turn it on I get error 37
Did you ever get an answer to you question on the error 37 for the Rowe R92 Jukebox
Peter
Rowe R-92 Jukebox
Dec 09, 2012 | Audio Players & Recorders
2002 Kia Sportage will not start.
p0560 is system voltage problem. open or short between the battery positive and the ecm.CHECK ALL FUSES. dosnt matter what they are labeled under dash and under hood replace any that are bad and retry to start. no start then check voltage to ecm grounds to. i dont have a wireing diagram to give you but for a small fee or free the dealer can make you a copy.make sure all the wires that go to battery terminals are not corroded and are making good contact [verified with volt meter]. if after all checks ok then replace ecm. as a side note i havent had to change one ever.
Apr 11, 2010 | 2002 Kia Sportage
Kenmore washer lid switch problem
Good day,
Common problem, Change the switch, and make sure if it is the model with a plunger for the switch mounted on the lid, that that be replaced as well.
Thank you for using FixYa
Dec 29, 2009 | Washing Machines
My Kenmore elite 100.24942301 Lid switch problem
You may can slightly bent the part the lid contacts so it will be depressed further thereby making the switch. If that doesn't work then you will need to replace the switch.
Betamax SL-HF500 VCR Cassette won't load
It is caused by components failing due to age. It was manufactured circa 1984 and had a projected life of 20 years. You may find a service centre that will undertake a refurbish but I have no idea where you are so cannot recommend any one.
Jun 17, 2017 | Televison & Video
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
