Question about GE Kitchen Ranges
I have a GE XL44 that I inherited in my new house. For some reason that I cannot figure out, the previous homeowner cut a circular hole in the floor below the stove and ran a vent line (looks like a six inch vent pipe) underneath the hole (but not extending up through the hole towards the oven) along my basement ceiling and out to a hooded flapper exhaust vent on the brick exterior of the house. Do you think he previously had a stove that used a pilot light and he was (overly) concerned about CO buildup? The reason I ask is that I think chipmunks/mice are getting into the basement through this vent and I would like to know if I can safely close off this vent.
    Prodigy:
    An expert who has answered 500 questions.
  • GE Expert
  • 650 Answers
It is possible that a down draft venting stove such as a Jenn-Air could have been previously installed and now there is this stove that doesn't need this vent system.
Posted on Dec 03, 2012
  • psmirman2085
    psmirman2085 Dec 03, 2012
    Thanks. That makes perfect sense. There was a bunch of stuff (shards of plastic) shoved in the elbow of that vent line (I guess it\'s closer to 10 inch diameter). I guess I\'ll just screw down the flapper so critters can\'t get in again.
3 Suggested Answers
SOURCE: Wolf oven won't light after only 3 years since last repair.
You could try a new thermocouple and/or cleaning the pilot assembly. The thermocouple is the tube that screws into the pilot safety valve and runs to the actual pilot and is heated by the pilot flame. If you change this part be sure not to over tighten the thermocouple into the safety valve as it can break. You should go finger tight plus a quarter turn. Also you should check to see if the pilot is solid, not weak. Thermocouples can be purchased from your local equipment service company, sometimes Home Depot has them for water heaters, be sure you get on with proper length. Hope this helps.
Posted on Apr 30, 2009
  • 14 Answers
SOURCE: I have a GE XL44 gas stove/oven. We did some
gas valve regulator or clogged line
Posted on Sep 03, 2009
I believe my oven igniter is bad in my GE Profile XL44 Stove. How do I go about replacing it myself?
On most GE models: Remove oven bottom by removing two screws at very back of oven floor, lifting up back side of floor, pulling back a bit to disengage front of oven floor, and remove. Next, remove flame spreader, allowing you to see burner and igniter. It is easiest to remove the burner assembly to change out the igniter.
Mar 13, 2011 | GE Kitchen Ranges
Describe your GE Profile Spectra XL44 Oven
My GE Profile Convection Microwave Oven will beep and display a F2 for no apparent reason. What is this?
Mar 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
The return spring for the blade guard on my Makita 5630D cordless circular saw came off. It is attached to the blade guard, but I can't figure out where it attaches to the saw housing. Any hlep would be...
there should be a hole in the housing towards the back of the saw, you can go to Makitatools.com and download a breakdown for this tool.
Feb 01, 2010 | Makita Saws
Convert GE XL44 from LP to gas
replace original orifices and adjust regulator to natural gas
Dec 30, 2009 | Kitchen Ranges
Fix hardwood flooring replace damaged hardwood flooring wood planks
During the whole process be aware of the edges of the flooring that is going to stay. First prepare the area for dust control. Mark the boards to be replaced. With a flat wood bit in your drill, bore a hole near, but not at both ends of the pieces being replaced. Bore only to the sub-floor. Set your circular saw to cut thru the flooring but barely touch the sub-floor beneath. Make two passes with the saw about 1/2" in from each edge. Lift out the center of the piece being removed. With a sharp chisel split the small end pieces at each saw cut and remove. With a chisel, tap the groove side of the piece toward the middle and remove. There may be a little chisel work to get it out. There will be a bit more chisel work on the tongue side. Chisel the tongue side until the fasteners are located and remove them. Remove the piece completely and remove any paper between the flooring and the sub-floor. Vacuum the area to prepare for the new board. Lay the new piece next to the opening and mark the length. If this is end match, t&g at teh ends cut the ends square. I mark heavily and leave my mark when I cut. It can be cut again if it is too long. Choice here are, cut the bottom of the groove and or the tongue off the new board. I leave the tongue and hook the piece in place. Easier to remove it though. Back cut the length on a table saw, being careful not to reduce the size of the face. This will make the bottom of the board narrower than the face. A sander can be used if no table saw is available. Once sized put glue on the sub-floor and put in the replacement piece. If the tongue was left, it must be tapped sideways to get to the point where it will drop in. Do not hit the wood directly. Used a scrap piece as convincer. When lined up, use a scrap piece of wood to drive the new piece down into place. The new board will be thicker and will need sanding. Congrats.
Dec 29, 2009 | Saws
Trouble changing a glow igniter on a GE Spectra xl44
Your replacement should have come with wire nuts.
Unplug the range.
Snip the wires and strip them back 3/8 inch and attach the wires from the replacement ignitor.
Feb 21, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Bake ignitor Location
Hi Kurt, welcome to FixYA!
In the diagram below, Part #28 is your ovwn ignitor. (See the red markings to highlight it)
It is located underneath the oven floor, and the floor should come out by removing the two screws located in the bottom rear of the oven cavity. Take out the racks, take out those two screws, and lift the oven bottom up from the rear, then disengage the front lip and lift it out. I hope this is helpful info and thanks for allowing us to be of service to you.
a16646a.jpg to you.
Dec 22, 2008 | GE Profile Spectra JGBP85 Gas Kitchen...
Low Heat from GE XL44 gas range
you can increase the sides of the flames by opening the orifices, if not differences. make the orifices holes a bit bigger, you can have as big of a flame as you want. those orifices are at the connection of the burner with the valve that supplies gas to the burners.
Dec 08, 2008 | GE Spectra JGBP35 Gas Kitchen Range
GE gas stove XL44
I have the same exact problem with my XL44, any ideas? Time to buy a new stove? If I do, no more GE for me!
Sep 21, 2007 | Robert Yick Co. RanRYC168 Gas Kitchen...
can ya post a picture of the piece and the door for refrence? thanks :-)
Sep 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Open Questions:
Kitchen Ranges Logo
358 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
