How do i connect my pc with only a vga cable to my hitachi tv (model #l40a105a)?
VGA /audio cable
  • 2,072 Answers
You can buy a vga to hdmi cable from monoprice.com Although this will only do video. VGA is video only, HDMI supports audio and video. You could, in conjuction get a 3.5 headphone jack to RCA or composite on the same site for sound. Both cables are pretty cheap.
Posted on Dec 02, 2012
Pyrhyc
  • 2028 Answers
SOURCE: connecting PC to TV
Most tv's are not compatible in this matter. They were made to be a tv, and not a computer monitor. Some of the newer tv's are compatible. If they have a vga port then they are compatible, but may not support or have the resolution expected. The vga to s-video cables were designed mainly for the use of the newer computers with vga ports to older flat panel monitors with s-video ports, at the time that vga was first coming out. This cable is on the verge of obsolete. So, I don't believe that you're going to be able to hook the two together, and get the outcome you want.
Posted on Jul 26, 2008
ItWillBoK
  • 108 Answers
SOURCE: connecting laptop to sony hdmi tv
There is a option on T.V.'s that you need to put it to VGA on the t.v. also you can go into properties on the output of the video to the t.v. and laptop to verify that it is sending a signal.
Also check to make sure all the cords are pressed in properly and that the cord doesn't have any cuts or cracks in it or any pins are bent at one or another end it happens sometimes it get's plugged in the pins aren't hard to bend.
Happy Holidays
Posted on Dec 25, 2008
coldsilver20
  • 113 Answers
SOURCE: VGA and Audio cables connected to PC but no audio through TV
if your tv has vga input there should be a "line in" input very near it. VGA can only get its audio source through a "line in" connecting to the coaxial audio inputs will apply the music stream to a different video input on your tv. your tv has video 1, video 2, vga, and so on, but the vga cannot show video and then audio from the video/audio coaxial inputs. you will need something like a dual male tipped 3.5mm audio connector.
Good luck and pls rate this post
Posted on Mar 16, 2009
  • 7 Answers
SOURCE: Connecting Dell Inspiron B130 PC Notebook to HDTV
Youll need a regular VGA cord and a 3.5mm to RCA conversion audio cable from Radio Shack like the one below. http://www.radioshack.com/product/index.jsp?productId=2428708
forget going the HDMI route, it isn't worth the money youd have to spend on a converter. once you got your cables hooked up, consult this: http://www.microsoft.com/windowsxp/using/setup/learnmore/northrup_multimon.mspx
Posted on Jul 17, 2009
drifterK
  • 4924 Answers
SOURCE: How do I connect my laptop to my TV wiyh a VGA
http://www.cablesnmor.com/vga-to-rca-cable.aspx
this is a cable that will do the work if your TV supports hdtv ..if not you will need to have a video card that has more options ...anyway the idea is that the connection will be like a DVD player in RCa cable ..and the sound the same ..need a cable with a 3.5 jack ..and a rca in he other end..or 2 if you have stereo input ...same elder models have single jack stereo input for sound..
Posted on Nov 26, 2009
How do i connect my pc to my hdtv
It is quite possible the tv may have a VGA input in which case a standard VGA cable will allow you to connect the laptop to the tv. Otherwise you will need one of the following depending on what connections the tv has:
1. VGA to HDMI cable: http://www.amazon.com/Video-Cable-Black-Support-Necessary/dp/B002TUC64W/ref=sr_1_1?s=electronics&ie=UTF8&qid=1355697785&sr=1-1&keywords=vga+to+hdmi+cable
2. VGA to RGB cable: http://www.amazon.com/eForCity-Premium-Component-Cable-Black/dp/B0012SPNII/ref=sr_1_1?s=electronics&ie=UTF8&qid=1355697879&sr=1-1&keywords=vga+to+rgb+cable
If you do not have an HDMI input, you will also need to get an audio cable as well. Standard mini-stereo audio cables should allow you to connect the laptop to the tv.
Dec 17, 2012 | Computers & Internet
How do i hook my compaq preario cq56 laptop to my hitachi hd plasma tv
The laptop looks like it has an external VGA port only and without knowing what model of Hitachi tv it is. It is quite possible the tv may have a VGA input in which case a standard VGA cable will allow you to connect the laptop to the tv. Otherwise you will need one of the following depending on what connections the tv has:
Dec 16, 2012 | Compaq Computers & Internet
Does my HP dv9449us has HDMI port? Can I connect it with my tv using this cable or what cables do I need? We have LG LCD tv.
Your laptop does not have a HDMI port. You only have VGA, you have to purchase a VGA to VGA cable VGA is video only interface. So you will need it along with the stereo audio cable
http://pctvcables.com/vga-with-audio-pc-to-tv-cables.html
Note that the stereo audio cable shoulb be connected from the headphones jack on your laptop to the headphones jack on you home theater system if you have one or buy this adapter plug the stereo audio cable coming from the laptop into it and connect it to the stereo audio in (red and white audio)of your tv
http://www.amazon.com/Male-3-5mm-Stereo-Female-Y-Cable/dp/B000I23TTE
Aug 18, 2011 | HP Pavilion DV6449US Notebook
How to connect hitachi tv 42" to internet inorder
A computer and a VGA computer cable. The TV has to have the computer VGA hookup in the back of the set. Once hooked up you will need to get the proper input on the TV to VGA or PC.
Jun 23, 2011 | Hitachi 42HDS69 42 in. Plasma Television
How can i connect my advent qrc430 to a hd television
There are two options available with this laptop. Unfortunatley you will not be able to produce a High Definition picture, but nether the less it is possible to connect it to a HD TV.
The connections available are;
1x VGA - You will need a VGA Cable (as long as your HD TV has a VGA/PC input) cheapest found on Ebay. There is also a VGA to HDMI cable. Still wont be HD but an alternative to think about.
1x S-Video (TV-Out) - You will need a S-Video Cable (make sure HD TV has this input) also cheapest on Ebay.
Both of these options do not produce audio through them so for this you will need a 3.5mm audio jack to 3.5mm audio jack. Plug one end into your earphone socket on your laptop and the other end into your HD TV PC Audio in socket/Audio in socket. If you have a Cinema/surround system you will need a 3.5mm audio jack to stereo phono, as long as the surround system has an audio input.
LINKS
VGA to HDMI cable: http://cgi.ebay.co.uk/1-8m-VGA-to-HDMI-Cable-Adapter-M-M-For-Laptop-PC-LCD-TV_W0QQitemZ350312945946QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item519047591a
VGA to VGA: http://cgi.ebay.co.uk/5M-VGA-SVGA-15-PIN-CABLE-PC-TO-TFT-MONITOR-LCD-TV-LEAD_W0QQitemZ330370826650QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item4ceba2c19a
S-VIDEO to S-VIDEO: http://cgi.ebay.co.uk/5m-S-Video-Svideo-SVHS-4-pin-Cable-Lead-Male-GOLD-16ft_W0QQitemZ360181396530QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item53dc7bf432
3.5mm AUDIO to 3.5mm AUDIO: http://cgi.ebay.co.uk/1-8M-3-5mm-3-5-Jack-to-Jack-Audio-Cable-Lead-Wire-Gold_W0QQitemZ270522394462QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item3efc64275e
3.5mm AUDIO to PHONO: http://cgi.ebay.co.uk/5M-3-5mm-to-2-RCA-Stereo-phono-Audio-Cable-for-iPod-Mp3_W0QQitemZ250574651547QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item3a5769c09b
Hope this helps. If it does please leave a thumbs up....Thank you.
Feb 04, 2010 | Computers & Internet
Hi can u hep? i connect my hdtv connector from my x box to a hitachi plasma 42 " tv which also acts as the pc port, but get no sound?
make sure that the connection you are using is providing audio to the tv. If it is VGA, or DVI, those cables do not carry audio, only video.
Sep 07, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
How to connect samsung pasma tv to pc?model number is PS42B450B1XUM
That does depend on the PC, but I'll assume it's a pretty standard PC.
You ideally need a Male 15Pin VGA cable to Male 15Pin VGA cable. (aka A normal Monitor Cable) The same as you probably have connected between your PC and Monitor.
Your TV has a 15Pin VGA Female socket on the back, this cable plugs into here.
For Sound the TV has what looks like a headphone socket next to the VGA Plug. You need to use a Stereo Jack Plug to Stereo Jack Plug Cable. 3.5mm. This goes from your PC's Audio Line Out (rear of the PC) to the Plug on the rear of the TV. It is usually marked Aux In or PC Sound.
Enjoy, The PC will look great on the Tv.
Sep 06, 2009 | Samsung Televison & Video
Mar 16, 2009 | HP Pavilion dv2000t Notebook
Can I connect my dell latitude d360 laptop to my tv?
you need to have the same connections on both my laptop has svideo or vga connector, some have Hdmi which is the newest, but the tv and laptop have to bot have the same connectors, it may be a dvi, or any that I mentioned, then you need a cable for your video, and another for your audio, both the audio and video cables are run to the tv, the only one that has both audio and video is the HDMI which tv's from the last hear or 2 usually do have. Then depending which input the laptop is using which it will tell you where the connection for the tv is, you set it to that input and that turns your tv into a giant monitor
Dec 22, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
