Question about Olevia LT37HVS 37 in. LCD HDTV
Sco-P5092A1-MAO main board sales
The Audio has gone bad and is only intermittant static. Volume control works, remote works. Audio is bad.
How do i fix a non responsive tv set?
Do the ballast first. That should get the picture back. The main board controls everything else.
Oct 08, 2016 | Televison & Video
Volume intermittently increases all the way to 100 and cannot be controlled by the remote
This happens with some models. You can open the TV from the back and disconnect the connector for the side control board. You will only have control via the remote but your volume issue should be resolved.
Apr 12, 2014 | Samsung Televison & Video
Samsung hlr6167wx xaa
Bad main board part number BP94-01858A.
Feb 15, 2014 | Televison & Video
I have a denon 1801 and the master volume goes to +60 which is all the way up and i cant seem to lower it, the knob turns and everything else works just fine
First solution would be to try and use the remote. If the remote is able to, the problem is in the knob. If the remote does not work, the problem resides in the volume board.
The problem resides in the circuitry that the knob is controlling. Unfortunately this knob has a full range of motion, which means that it is simply controlling a computer chip within the unit. (i have an 1801 as well). What has happened is that some component on the volume board has gone bad, which is resulting in your non functioning volume knob.
Unfortunately this is usually a job for a professional.
If you have standard electronics skills (soldering / disassemble / reassemble), you can open the case and find where the volume knob leads to. There should be a smaller board, and see if you can access it. Usually they are rather hard to get to, or to get free to actually see what is going on. The best solution would be to find a parts receiver, and swap boards. This shotgun approach changes everything. Otherwise, look for any damaged components on the board. Swap out any components that are damaged, or appear damaged with comparable replacements.
Mar 15, 2011 | Denon DRA-685 Receiver
Sony model KDL-32L5000 does not respond to the commands of its remote control model RM-YD028. We have been using a Direct TV remote as well to control volume but its not reacting this remote either...
If the only thing not reacting is the audio, then the audio board or the main board has gone bad. Enter the model number and tv make on you tube to get more detailed info.
Dec 15, 2017 | Sony KDL32L5000 32 in. LCD HDTV
Static electricity fried the button panel
static electricity can damage the chips on the boards. it all depends were the static voltage went to, if it was just to the buttons controller board or to the main av board. you could need new button board or you could need to replace the main board and the button board its hard to say with static shock.
Jul 11, 2017 | Emerson EWL3706 37 in. LCD Television
Volume is intermittent
If anything works after it is moved suspect a bad solder joint somewhere.
Mar 03, 2010 | Harman Kardon AVR 300 Receiver
All remotes controlling my Onkyo TX-SR304 stopped working
try putting the remote an inch away from the IR receiver on the unit and see if it works then, if so then you definitely know its broken. This can and does happen. From what you have posted it sounds like no remote is working on the receiver, the ir receiver can break. If you need further assistance let me know.
Thank you,
Lee
May 28, 2009 | Onkyo TX-SR875 Receiver
Volume can not be increased low static sound
No / intermittent audio is caused by vibration damage to the audio circuit. Unit needs to be put under a microscope and inspected for micro cracks in the solder joints of the audio circuit components.
Volume control is adjusted by remote switch on handle bar. You can contact HD for a wiring harness schematic
Sep 30, 2008 | Harley Davidson 426290 AM/FM Radio
Olevia LT37HVS 37 in. LCD HDTV Logo
91 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
