Question about Singer 7426 Mechanical Sewing Machine
To get the bottom off 7426 machine - Singer 7426 Mechanical Sewing Machine
  • Singer Master
  • 1,564 Answers
The machine is like a laptop... the case comes apart, typically 2 halves. Remember this is a computer with all the dangers of other electronics some of which could be deadly if you aren't experience with electronics. I wouldn't advise it... take it in.
Posted on Dec 04, 2012
Its blinking when i turn it on doesnt do nothing what to do?
This sewing machine has circuit boards, switches, and inlet harnesses as well as CPU circuit board boxes. There is a way to find where the problem is by a step by step method. Take your sewing machine to a qualified repairman.
Nov 27, 2015 | Singer 7426 Mechanical Sewing Machine
How do i change the light bulb on a singer model 7426 ? my bulb does not work.
That's easy to do, and designed to be done by the user rather than a technician. However, I just downloaded and took a look at your user's manual, and it doesn't seem to include that information. The light assemblies are usually identical for a number of machines, though. I would send an email to Singer customer service, or go to the Singer Facebook page, and just ask them. Either they will have a printed flyer, or they'll be able to steer you to a similar model that does have this info in their user's manual. I also noticed that they sell replacement bulbs on their site.
Jul 08, 2014 | Singer 7426 Mechanical Sewing Machine
How do i change the light bulb on singer model 7426 ?
You have to unscrew the cover of your sewing machine on the left top and once it is unscrewed you take the cover off and insert a new bulb and then replace the cover.
My top stitch is okay, however the stitiching on the bottom is wiggly, more like a zigzag stitch then a striaght stitch. Why?
try changing the needle--flat side to the back of machine
try adjusting the tension one number up--if it doesn't help put the tension back where it is
check to make sure the bobbin is in correctly
also check to make sure the bobbin is wound correctly
it's also possible that the machine is out of time which means a sewing machine repair shop would have to refix the timing of the machine, because they have the tools for the job
Jan 31, 2012 | Singer 7426 Mechanical Sewing Machine
Singer sewing machine won't pick up bobbin thread
Make sure that the area is clean and free of lint. Change the needle and rethread the machine.
Nov 24, 2011 | Singer 7426 Mechanical Sewing Machine
Como usar puntadas decorativas
Tienes un manual?
Lo puedes conseguir uno de la pagina web de Singer.
http://www.singerco.com/accessories/manuals.html
Introduce el numero 7426 y hacer clic en search.
En el sigiuente pagina hacer clic en free download!
El manual esta escrito en Ingles, Frances y Espanol.
Paginas 62 a 64 da consejos sobre puntadas decorativas.
Espero que este tu ayuda.
Oct 29, 2010 | Singer 7426 Mechanical Sewing Machine
I have a Singer 7426. The needle is hitting the hook area incorrectly, making a jerking motion with the needle along with a tapping noise. Any idea how to correct it?
the needle probable is bent-has to be replaced so it won't damage the needle bar
if the needle is hitting the needle plate then it needs to be check for burrs, small burrs can snag the fabric
Jul 29, 2010 | Singer 7426 Mechanical Sewing Machine
Singer 7426 timing off
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Aug 25, 2009 | Singer 7426 Mechanical Sewing Machine
Oppertaes hard
Certainly all machines need oiling except for bearings that have their own impregnated oil. Any two parts that are metal (not plastic or nylon) and move togeather need oil. Gears need grease, vaseline works ok. The needlebar and takeup lever and everything under the cover on the upper left. Also below the hook on bottom. This will require removing covers. Its more than likely it needs a good cleaning also or there could be thread caught up in a tight spot where two parts move togeather.
Just a drop or two though as too much will just collect more lint or dirt etc and cause more issues.
Dec 20, 2008 | Singer 7426 Mechanical Sewing Machine
How do I adjust the machines timing?
Does your machine still stitch correctly or does it skip stitches
Jun 19, 2007 | Singer 7426 Mechanical Sewing Machine
Singer 7426 Mechanical Sewing Machine Logo
60 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
