Question about Zanussi TC7114W Electric Dryer
Zanussi condenser drier: tank full light on even though empty
My drier will go for about 30mins of 90 minute cycle then says tank full [it's not]
Giving the drier a wiggle/tipping it up will reset sensor and allow another few minutes drying then trips again
!8 months old
Model no TC7103W
Tank at bottom [no pump]
No debris/fluff blockage [checked by repair man]
Pushed fully home
  • LnUK Feb 24, 2009
    I have the same problem. In addition to which the water seems to be simply draining onto the floor beneath the machine. I cannot see how to get to the float or the water tank. The machine seems to be rivitted together. The water tank never gets full because water simply leaks onto the floor. I noticed a white valve at the back of the machine and pulled it out, and water came pouring out. Why is this water not going into the resevoir? I now have the machine elevated on blocks with the back valve open and draining into a cup, so that the machine will work. Any suggestions?
Its either going to be fluff in the float which you can get at by taken the side panel off .or its fluff in the valve behind the water tank
Posted on Jan 31, 2009
The full tank light remains on even though the tank is empty. Is there a sensor which stops the dryer from restarting
The warm and cold air circuits cross inside the heat exchanger, which results in a thermal exchange which condenses the humidity contained in the warm air. The condensation which forms in the heat exchanger is collected in a sump, from which it falls by gravity into a tank. When the water in the tank reaches the max. level, the level of the water in the sump increases, which causes the float to move upwards, thus actioning a microswitch; The microswitch for dryers with electronic board sends a signal to the electronic circuit when the tank has been filled, switches off the appliance and lights a pilot lamp which indicates to the user that the tank is full. The microswitch with electromechanical control switches off the dryer (the timer motor is powered and ends its cycle) and lights a pilot lamp which indicates to the user that the tank is full.
The tank capacity is about 3.5 lt., enough for a drying cycle.
- Remove the screw (1) which secures the support micro and use a screwdriver for the two hooks which secure it to the sump.
- Lift them simultaneously and unthread the micro support towards outside
Putting upside down the support you can access the floating microswitch.
25069013-hcssld2gpo2sm22yg24xoxcy-3-9.jpg Inside the sump there is the float.
To extract it rotate the float 90° clockwise as shown.
Lift it up, rotate it towards outside and extract it.
While reassembling the pump, the float and the tank microswitch, repeat the same operations backwards, paying attention that when the micro support is remounted it is necessary to use a screwdriver in the fissure (indicated by the arrow), to lift the micro lever and lean it over the float (if this operation is not carried out the lever of the micro comes up alongside the float (it deforms) and the two components do not function anymore.
25069013-hcssld2gpo2sm22yg24xoxcy-3-20.jpg Dado
Sep 06, 2014 | Zanussi Dryers
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
Zanussi condenser dryers
It can be mechanical or electrical malfunction. I would check tank microswitch, float and lever.
Below is explained how the condensate drainage system works and that will facilitate fault detection.
Dado
Aug 10, 2014 | Zanussi Dryers
Why does the condenser tank full light come on even though its empty
Hello, before call the specialized service try this:
Turn off and unplug the dryer from the main supply.
Open the main door of the dryer and with your hand attempt to move the drum up several times.
Empty water light, empty condenser
I experienced the problem with a hotpoint TCYM 750, with the red empty water light failing to switch off. After removing the filter and cleaning it, cleaning the condenser and drying anywhere I had access to the machine still didn't heat and the light remained on. Reading the post about the machine having 3 reservoirs it struck me that one of the reservoirs may be hard to access. So I unplugged the machine and tipped it onto its front. The reservoir drained, I pushed the machine back upright and cleared up some water around the condenser. The drier now works properly and the empty water light is off - job done!
Feb 04, 2014 | Hotpoint Dryers
Hey, i have a zanussi model zdc46130w. it stops drying after a few mins,and the "empty water tank" light flashes,even though the tank is empty?
the float down by the pump might be stuck......or the pump could be knackerd,................cheers
Jan 17, 2014 | Dryers
I have a Zanussi Electrolux TC7103W condenser drier and for some reason the empty water light keeps coming on even though the reservoir is usually only half full. I have tried emptying it and tried un
Make sure lint build up is clear behind condenser
Sep 29, 2012 | Dryers
Zanussi 7102 won't start. Power is ok. Condenser tank full light remains partially on even when tank is removed. When startbutton is pressed condenser full light illuminates fully. Water pours out pipe...
Pat, Have you found a solution to this yet? I have got exactly the same fault today ! Having taken the top & left side of the dryer off, I found what looks like a broken drive belt - not the main drum drivebelt which is fine, but a shorter one (about 18cm diameter loop) with no obvious place for it to have come from. Any clues would be appreciated. Dave (drdave@fsmail.net)
Dec 31, 2010 | Zanussi TC7102W Electric Dryer
Zanussi tc470 condenser drier Red light is staying on even after the water container is emptied. switch appears to be faulty
excess water seems to be lodged in the drier and was drained out.There is a drain at the rear of the machine. I am concidering connecting a pipe here and draining permently to the outside.
Dec 28, 2009 | Dryers
Zanussi Tumble Dryer
Sounds like the condense pump is bad. Replace it, or look if there is lint in it. ;)
Dec 30, 2007 | Dryers
Zanussi TC7114W Electric Dryer Logo
1,533 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
