Question about Dryers
How to test dryer switch - Dryers
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Check it for continuity. Look at this page.
Posted on Dec 03, 2012
When turning on dryer all lights are on but dryer won't start?
I don't have the code list for this dryer, but I'm thinking the door switch maybe the problem.
Sep 28, 2014 | Whirlpool GEW9250 Electric Dryer
Dryer not powering/turning on
Investigate these areas if your dryer is not starting: Proper Voltage from the House Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in. Door Switch If your dryer's door switch is defective, it will not allow your dryer to start. Test your dryer's door switch. If it is defective, replace it. Start Switch A dryer cannot start if its start switch is defective. Test your dryer's start switch. If it is defective, you will have to replace it for your dryer to start again. Thermal Fuse A thermal fuse is a heat-sensitive fuse attached to your dryer's exhaust duct (in most models) that is designed to blow if the dryer overheats. A blown fuse would cause your dryer to not heat, or to not work at all. Open up your dryer's cabinet and locate its thermal fuse. Test the component. If it has blown, replace it. Thermostat A defective dryer thermostat could be what is preventing your dryer from starting. Open up your dryer's cabinet. Test each of your dryer's thermostats. Replace any that have become defective. Timer Motor Your dryer's timer will not function properly if its motor is malfunctioning. Open up your dryer's cabinet and locate its motor. Test the component. If it is not functioning as it should, replace either the motor itself, or the entire timer assembly. Motor A burned out motor could be what is keeping your dryer from starting. Test your dryer's motor and if it is defective, replace it. You will have to open your dryer in order to gain access to its motor. For more info see the following link: http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Aug 05, 2012 | LG DLG2532 Gas Dryer
HI, my dryer stopped working, check belt it not broken and in place. So what can it be. Can it be the starter button?
Hello there and thanks for choosing fixya
dryer_door-switch.jpg Door Switch
dryer_start-switch.jpg Start Switch
dryer_thermal-fuse.jpg Thermal Fuse
dryer_thermostat.jpg Thermostat
dryer_timer.jpg Timer Motor
dryer_motor.jpg Motor
Jan 23, 2011 | Dryers
The dryer will not start but the timer is working
May 21, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer gold not drying clothes
  • Check for proper air flow
  • Check the ignitor
  • Check gas jet
  • Test the gas valve coils
  • Check the flame sensor
  • Test the safety fuse
  • Test the thermostats
  • Test the centrifugal switch
  • Test the timer motor
  • Test the temperature selector switch
  • Here is a website to aid with these tests
    http://www.acmehowto.com/howto/appliance/dryer/diaggdryer.php
    Nov 11, 2009 | Whirlpool GEW9250 Electric Dryer
    Kenmore 90 Series Model 11060912990 Dryer won't start
    check motor (you have 2.4 Kohm ) very high read
    for motor must be lower.Check capacitor if hawe.
    Feb 15, 2009 | Kenmore 62602 Electric Dryer
    Whirlpool Duet Dryer WED9600 Beeping during drying
    Dear Customer
    Please perform the following
    please rate this,thank u
    Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
    Dryer stpped working
    with power disconnected
    if any wire disconnected before any test, reconnect & test dryer, reconnect wires after each test
    disconnect wires from start button and test, conduct when pushed, no conduct when release
    if fail replace start button test dryer
    disconnect wires from door switch and test, conduct when pushed, no conduct when release
    if fail replace door switch test dryer
    follow leads from start button to relay(relay is first device connected to start button), and make sure all wires connected at both ends. If any wires disconnected, test dryer
    locate thermostats and thermal fuses on fan housing and ducts
    individually disconnect wires from each and test. conduct good, no conduct fail
    replace any failed thermal fuse or thermostat test dryer
    if all prior test OK
    replace relay, test dryer
    Oct 10, 2008 | Magic Chef CYE4000AWW Electric Dryer
    Dryer won't start
    Dryer does not work at all
    Hope this may help;
    DON'T FORGET TO RATE:
    Aug 22, 2008 | Roper REX4634KQ Electric Dryer
    I had no problem with my dryer until...We vacuumed out our dryer, including the exhaust hose. The dryer doesn't dry clothes. The automatic dry will run until its manually shut off. The Timer still works...
    dear customer,
    I recommend you to kindly follow the rouitne below before taking it to your dealer..
    hope u find this useful. thank you.
    Jul 09, 2008 | Whirlpool Dryers
    Dryers Logo
    Top Dryers Experts
    Dan Webster
    Dan Webster
