Question about Mitsubishi WD-60735 Projection Television
Black horizontal bars after replacing DLP chip in Mitsubishi
4 Suggested Answers
chan_kurt_a
SOURCE: we just replaced the DLP chip in our mitsubishi 1080P tv because we had white spots all over the screen. Now after replacing the DLP chip we have no picture at all but we have sound. Help?
Likely you either forgot to reattach your color wheel ribbon connector, or have it on upside down. It's the tiny ribbon cable behind your circuit board that will come off as you pull the board away from the DLP chip.
Posted on Dec 02, 2012
  • 135 Answers
SOURCE: Mitsubishi WD5725 DLP set. Picture is Ok before
The set has over 150 capacitors that could be causing the problem but it is at least 1 doing this. Contact Mitsubishi. Some people have been able to get new replacment TVs because of this problem
Posted on Mar 04, 2010
  • 8457 Answers
SOURCE: i have white spots and
This tv is it the DLP projection light engine block main board itself is the problems,not easily to go into the tv itself and replacing the IC chip itself.Must take out many mechanical parts to get u the Light engine block it self.U can replaced IC but somethime the IC chip it replaced,will not solved the problems,because the tv problems now the it is spreading and going on beyond the IC chip itself.If want to keep this tv very exspensive repair,i would reconmend hire a bound qualify tv tech replaced the whole Light projection block itself,but first call Mitsubishi for some kind of deal,they might help with the repair amount cost.
Posted on May 13, 2011
My Mitsubishi T.V. recently had a problem with the DLP chip so I replaced it, but now there is a thick black horizontal line in the middle of the screen.
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 30, 2016 | Mitsubishi Televison & Video
Black bar on dlp tv.how do I fix this?
Sounds like a connection problem between board and DLP chip. The BGA connection which connects the DLP chip to the board, or the flex connector may be bad, causing the row and column section to not activate the micro-mirrors on the DLP chip. Not an easy fix. Regards.
Nov 23, 2015 | Mitsubishi WD65737 65" DLP TV
Can I diagonally adjust (clockwise/counterclockwise) my Mitsubishi DLP TV? The picture is off center
You need to align the optics mechanically. If you changed the dlp chip and its not centered then the chip is not shimmed properly or the reflection mirror behind the lens needs adjustment. You should get a service manual for that chassis and follow the directions. there may be an electronic method but I am not aware of one.
Sep 05, 2015 | Mitsubishi WD-60C9 60" DLP HDTV
Dlp chip after replacing
you will need to pull the chip out & clean out the dust & other foreign particles that were allowed to fall in & lightly brush off the chip (with a very soft brush, again to remove dust & foreign particles.
Apr 28, 2015 | Mitsubishi Tv Dlp Lamp 915p061010 For...
I am getting wide lines of bars on the screen after replacing dlp chip in wd- 73735 73" mitsubishi
you will need to pull the DLP chip out & clean the dust & foreign particles that got in while you had it apart.
Mar 11, 2015 | Mitsubishi WD-73735 73-Inch 1080p DLP HDTV
Replace chip for white dots now have two black bar top and bottom model wd65735
Probably ok. Check the picture ratio or format settings to see if the bars go away when aspect ratio is right setting.
Feb 06, 2015 | Mitsubishi WD65737 65" DLP TV
I have lines and black spots all over display
Most likely you have a failing DLP chip. The DLP chip is the one that forms the image that is projected onto the screen. Search for "Mitsubishi Black Dot" in your search engine and you will see you are not alone. Apparently, a lot of DLP chips in Mitsubishi products are failing. With the low price of projectors these days, your best bet is replacing it. If you want to repair it yourself, the chip will run you about $200 to replace and may require soldering.
Hope that helps,
Bax
Nov 10, 2013 | Mitsubishi EX240U Projector
After replacing the dlp chip in my mitsubishi tv there are vertical lines on the screen. any ideas?
i had the same lines on my 65' mitsubishi tv after replacing the DLP chip. after going back over everything i realized that the casinf that holds the chip in was not in the lock position. i took the chip out and replaced it then turned the little locking mechanism to the locked position. now my screen is perfect. hope this helps.
Nov 21, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
Mitsubishi dlp tv WD65733 has white spots, like stars on screen, what causes this
If you get White or black dots all over the screen (DMD symptom)
If you get a pixilated picture (DMD Board)
Mar 27, 2010 | Mitsubishi WD-65733 65" HDTV
What Causes the white dots on a DLP Mitsubishi tv?
the white dots (sometimes you get black ones too) are caused by a faulty DLP chip. you can find the replacement for your TV at the following website:
http://www.shopjimmy.com/dlp-chips/
Mar 20, 2010 | Mitsubishi WD-60735 Projection Television
Mitsubishi WD-60735 Projection Television Logo
262 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
