Question about Scotch Dispenser with Magic Tape 0.75 x 350 Inches (C29)
How do I open the hub to replace a roll of tape in the Scotch C29 tape dispenser?
My sony snaplab is saying broken paper roll and ink,
Look at the ribbon ink roll to see if there is a tear in it. You can join it back together with scotch tape and put it back in the printer. Same goes for the paper
May 04, 2016 | Sony Office Equipment & Supplies
How do I load paper?
I have a casion hr-100tm calculator and found the easy way to load a new roll of paper. Take a 3x5 index card and cut it on 45 degree angle, then with angle on the right of the machine feet it into the machine pushing it as you go. Once it begins to feed so you can pull on it, then take other end of card, scotch tape to new roll of adding machine tape. As you feed the card through the roll of paper foillows. Once it has fed into machine cut off 3 x5 card. Easy.
The problem is that all rolls of machine paper are not equal and the thinner paper doesn't want to feed. This way it works for any type. Hope it hellps.
Oct 02, 2015 | Casio FR-2650A Calculator
How to unstick scotch tape roll
Hair dryer! Heat it up and it removes easy!
Oct 18, 2014 | Office Equipment & Supplies
How to change the tape roll
Facing the dispenser with the cutting edge pointed toward you slide the axle to the left
Nov 26, 2013 | Staples Executive Desktop Tape Dispenser,...
What makes duct tape stronger than scotch tape?
Duct tape is much stronger than scotch tape for a few reasons. The first being that it is generally wider than a roll of scotch. Also, duct tape is made using cloth and is even coated in polyethylene.
Jan 30, 2013 | Hardware & Accessories
How do you open a Scotch Tape Dispenser C60 to change the tape
The entire carriage lifts out using a good amount of lifting force. Slide your finger under the empty roll from the front of the dispenser. Apply upward pressure. You may be concerned that you will break the plastic roller, you won't. the entire carriage will pop up. When it does it's a simple matter to replace the old tape with a new roll. Snap the carriage back into place to use the new roll.
Jan 21, 2013 | Scotch C60 black 2 Tone Desktop Tape...
How do I open my Bright Pink Cupcake Tape Dispenser from Staples to put a new roll of tape in?
You have to shove your finger down to the bottom where there are two latches you have to pop out. They are on the bottom, closer to the front of the cupcake. good luck.
Jan 16, 2013 | Video Cameras
REFILL INSTRUCTIONS FOR SCOTCH C60
You have to insert your finger under the empty reel from the back of the dispenser and pull up with your finger. You might think that it will break, but it takes force and it will not break if done properly.
Aug 15, 2012 | Scotch C60 black 2 Tone Desktop Tape...
I am using Scotch Magic Tape 3/4" purchased from
I can't give you a refund, seeing that I don't work for Scotch, but you might have success if you go back to Costco, or if you call the Scotch company to complain about the lack of quality in their products.
Apr 04, 2011 | Scotch Magic Tape Multipack
How do I remove scotch tape from paited surface? When I peel it, it takes off the paint. I used scotch tape to hang spider webs for a Halloween party and now I cannot remove the tape without taking off the...
Yikes, sounds like you had a bad paint job! I would try goof off the waterbased orange gel first.
Sounds like you may need to take a bit of the peeling paint to your local paint store and get them to match it. A chip at least the size of a quarter will help them. Then fill the chipped area's with Crack Shot filler and touch up.
www.outbackpaintingusa.com
Nov 02, 2009 | 3M Scotch Filament Tape Hand Dispenser...
Scotch Dispenser with Magic Tape 0.75 x 350 Inches (C29) Logo
109 people viewed this question
Top Scotch Office Equipment & Supplies Experts
ka4iup
ka4iup
Andrew Taylor
Andrew Taylor
Mark Andrews
Mark Andrews
Level 1 Expert
Are you a Scotch Office Equipment and Supply Expert? Answer questions, earn points and help others
