Question about Mitsubishi Televison & Video
Pip won't turn off. can the pip be removed or bypassed?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Some of the older sets with PIP require only the original remote to operate or turn on and off.
The PIP board usually develops problems with surface mounted caps and there is a "modification" where traces are cut and two 4.7 mfd caps inserted which will bypass the PIP board from the set--a model number would tell me if this is possible in your set or not--you missing the original remote? Almost any Mitsubishi remote of the era with PIP controls should do the job.
Posted on Dec 03, 2012
PIP won't work
PIP is probably set to an input with nothing connected.
Feb 03, 2013 | Hitachi 65T500 65" Rear Projection...
Pip won't turn off
PIP for this model is usually only via the rear audio/video jacks---if using a cable or sat box look there as they also now have that feature
Dec 03, 2012 | Hitachi Televison & Video
My Rca 52 inch has lost color But If I set the feature
PIP means the set uses either two tuners or a dual tuner--could be a issue with the tuner. If it has a swap feature in the PIP use it to see if color when tuner is switched from main to PIP tuner.
A possible way around the issue is to look to see if rear audio/video inputs have color---you could route signal from a box etc to one of those and BYPASS the problem if rear inputs do not have this problem(not likely they will).
Jun 15, 2012 | RCA HD52W59 HDTV Projection Television
Car died and won't start
If the Rpm gauge is not responding while turning over you are not getting a pip signal from the distributor, if no rpm replace distributor
May 18, 2012 | 1993 Honda Accord
Second Chip key for 2005 Aveo won't work
assuming the 2005 model year stil uses viper security systems...the chip in the key carries a magnetic resistance frequency. if the chip is damaged or corroded the frequency will change and wont engage the igntion. you can either get another key made (about 75 dollars) or bypass the ignition lockout feature.
May 18, 2012 | 2005 Chevrolet Aveo
Why won't my starter turn my engine fast enough on
bypass the battery cables with jumper cables if there bad they will not carry the amps needed to crank it
Apr 23, 2012 | Briggs & Stratton Garden
Do I have to remove the air conditioner compressor on a 1996 buick roadmaster so I can install a air conditioner bypass pulley for serpentine belt?
Yes, the bypass pulley fits into the same area that the compressor will have to be removed from.
If it's for fuel efficiency, some people just remove the wiring/plug from the compressor and tape it to the side so that it won't engage, if the clutch isn't damaged it's the same as using a bypass pulley.
Also, the clutch can be replaced and used instead of the bypass pulley, in the event it is bad, retaining the ability to go back to an A/C system should you ever desire.
Good luck !
Mar 29, 2012 | 1996 Buick Roadmaster
Can't get blue bypass cap off to put water filter
are you sure what you're turning is a bypass cap? KitchenAids don't usually have bypass caps.
If it is a bypass cap though, make sure you're turning to the left. It could be tougher because it's under pressure, so turn the water off going to the fridge and run the water out the dispenser if there is any.
Mar 09, 2012 | KitchenAid Refrigerators
Mitsubishi tv model VS6061 rear projection with rolling picture.
I know this is an old thread, but I would like to post this information in the hope that someone will find it useful.
I just finished fixing this problem on my 1994 VS-6061... the problem is the PIP (Picture In Picture) board located on the Power Signal board. The PIP board contains the numbers 530B552. I bypassed the PIP board by following the directions I found at the following link:
http://forum.doityourself.com/entertainment-center-tvs-stereos-vcrs-dvds/130383-mitsubishi-cs-35301-rolling-picture-problem.html
"Plug in a 4.7ufd @ 35v filter cap (+)at pin 5,(-)at pin 11. Plug in a .01ufd(any voltage) between pin 7 and 9. Just plug the caps into the socket, where the PIP board was mounted (they don't need to be soldered). Just don't let the leads from the two capacitors touch, as they cross each other. The 0.01 cap is non-polarity, so either way it plugged is fine. Basically you will bypass y-signal through 4.7u, in pin 5, out pin 11, and bypass c-signal in pin 7, out pin 9 of the PIP socket.”
The bypass requires 2 capacitors: One 4.7ufd @ 35v and one Non-Polar 0.01ufd @ any voltage.
Remove the PIP board, then plug the two capacitors into the socket where the PIP board was mounted: plug the 4.7ufd capacitor with (+)at pin 5,(-)at pin 11 and plug in the non-polar .01ufd capacitor between pins 7 and pin 9.
If there is a ground wire (possibly brown) soldered to one of the tin cases on the PIP board, then you should connect this ground wire to the PIP socket either at pin 2, 4, 6, 8 or 10 which are grounds of the socket.
This PIP board was used in many Mitsubishi televisions and they were plagued with problems...This is why many of these older Mitsubishi televisions had similar problems…
Good luck
Jul 19, 2008 | Mitsubishi VS-60611 60" Rear Projection...
Hi i have a 93 Mitsubishi model# ck35402. I was told that the pip had went out. was hoping someone could walk me through on how to remove and reroute
From the bottom of the main board locate IC 2004 between the PIP module and the tuner. Remove the jumper between pins 2 & 6, then jump pins 6 & 7. Next , pull the pip module from its socket and toss it. The symptom for a bad PIP module could be black screen, no picture, blue streaks, wavy or jittering picture.The audio will not be affected. Make sure the symptom fits the cure before you bypass the PIP. Good luck!
Mar 12, 2008 | Televison & Video
Televison & Video Logo
334 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
