Question about Ovens
Fitting new oven element for Indesit KP 59 oven
KP59 MS (X)/g .01
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Indesit fan oven. Top oven works bottom fan oven
If the fan is working o/k, then it is going to be the element that is faulty, this is located at the rear of the oven compartment behimd a removeable cover.
Posted on Nov 26, 2010
Floor element not working have got new element need instructions on fitting
Hi
Please check this video for element replacement:
Hope this helps...please post back for further assistance.
Daniel
Mar 06, 2011 | Baumatic B205SS Stainless Steel Electric...
I have a hotpoint ew91 oven that stopped working after tripping house fuse. after resetting fuse fan works but no heat.
It is most likely that the oven heating element has failed which caused the house fuse to trip.
The replace the heating element will mean taking the back off the oven and removing the old heat element by undoing the fixing screws and the electrical connectors( normally this surrounds the fan assembly).
Fitting the new heat element should then be straight forward.
Remember to disconnect the power to the oven before removing the back.
Dec 09, 2010 | Ovens
Indesit fan oven. Top oven works bottom fan oven doesn't .Is it the element
Nov 26, 2010 | Ovens
My hotpoint cooker blows the mains fuse when the oven gets hot
If it is a fan assisted oven, and the fan is working o/k, then it is probably the oven element insulation resistance thatr is breaking down as it gets hotter, so probably requires a new element fitting.
The element is located at the rear of the oven compartment behind a removeable cover.
Nov 09, 2010 | Hotpoint Ovens
My candy fan oven has no heat when turned on
If the fan is working o/k, then it is going to be a faulty oven element, fitting a new one should solve the problem.
Mar 29, 2010 | Candy Ovens
Indesit fde20 main oven wont heat up
sounds like the circular element at the back of oven has blown.
Oct 23, 2009 | Ovens
Fitting a new heating element Neff U1721
You need to remove the element from inside the oven cavity, but it is a bit of a fiddle. Once you have removed the screws at both ends of the element you need to remove the fan blade to access the centre fixing screw. Once all srcews are remove you have to twist the element and pull forward to remove the wires from the hole on the left, then remove the wires and refit to new element.
Jul 11, 2009 | Neff U1721 Double circotherm Electric Oven
Fan and grill works but not heating up
Hi.
If the fan is working o/k, then you need a new fan oven element fitting.
Remove panel at rear of oven compartment, there you will see the element, undo any screws you can see to remove rear cover.
disconnect element taking care not to loose wires, and fit new element. test before you refit rear cover.
Plz rate this solution.Thanks
Dec 24, 2008 | Belling XOU252 Electric Single Oven
Neff B1432 Oven Not Heating; oven light flickering
If the fan is working o/k then you need a new element fitting.
Remove the panel at the rear of the oven, there you will see the element, remove the fixing screws and ease the element forward,taking care not to lose the wires, disconnect the leads and fit new element.
The light flickering is probably the bulb not screwed in propely or a bad contact, nothing to worry about.
Plz rate my solution.
Thanks
Dec 19, 2008 | Neff B1432 Single circotherm plus Electric...
Indesit grill element not heating up
It may be the oven temperature sensor.
Mar 24, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
