Question about Scosche Industries Scosche Je01b Wiring Harness for 1988 1997 Jeep/Eagle
Wiring under dash 1968 galaxie xl 428 there is a small red and yellow/or gold/ hanging down..what does it go to ?its located in the middle?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
You are talking about the wireing harness for the factory (Radio) It is for the indicator lights on the radio,
Posted on Dec 03, 2012
I have a jvc cd player in my s40. and now it stopped working. getting 12 volts in red wire but only 2.4 in yellow. anyone know why
Corrosion/broken wires in the wiring. Yellow is B+, power all the time. I would just run another wire for it. I tend to run it to a B+ in the fuse panel. But you can run it all the way to the battery if you want. There are many wires under the dash to cut into. Ignition or fuse panel are the best to use. Stay away from really small wires, they can be for computers. I just use under dash b+ wires to save some one down the road headaches.
Jun 13, 2016 | 2003 Volvo S40
Polar start car starter
Check for a live skinned wire or tape wire,the wire had only be twist and taped(red should be battery wire)
May 04, 2014 | Cars & Trucks
Sennheiser head-phone cable problem?
This should help, skip to the part where he starts soldering the parts
http://www.youtube.com/watch?v=OhnXUQRQ4u4
Feb 17, 2013 | Sennheiser HD428 Stereo Headphones
I have a 1968 xl with a 428 .uder the dash is a re and gold,or yellow wire where does it go code wise/
That is for to control the brightness of the bulbs in the factory radio,
Dec 06, 2012 | Car Audio & Video
Where is the body control module located on a 2000 catera
BCM OR DASH INTEGRATION MODULE LOCATED UNDER DASH JUST FOLLOW YELLOW WIRES FROM IGNITION SWITCH TO THE BCM ITS A SMALL BOX UNDER DASH IN A BRACKET.
Sep 11, 2011 | Cadillac Catera Cars & Trucks
I need a radio wiring digram color code for 2009 chevy silverado
2009 CHEVROLET SILVERADO C1500 4DR TRUCK WITH 4.3L ENGINE AND STANDARD AUDIO SYSTEM
Remote Start
WIRE COLOR POLARITY LOCATION
Battery RED/WHITE (+) IGNITION SWITCH HARNESS
LOW CURRENT, FOR HIGH CURRENT USE RED/BLACK AT VEHICLE FUSE BOX
Ignition 1 PINK (+) IGNITION SWITCH HARNESS
Accessory 1 BROWN (+) IGNITION SWITCH HARNESS
MAY BE YELLOW ON SOME MODELS
Accessory 2 PINK/BLACK (+) IGNTION SWITCH HARNESS
FOR REMOTE START INTEGRATION
Starter 1 YELLOW/BLACK (+) AT MODULE UNDER HOOD BEHIND DRIVER HEADLIGHT
NOT FOR REMOTE START, FOR REMOTE START INFORMATION
Starter 2 PINK/BLACK (+) IGNITION SWITCH HARNESS
Anti-Theft Type GM PASSKEY IIIĀ® ANTI-THEFT SYSTEM
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense PINK (+) IGNITION SWITCH HARNESS
Tachometer WHITE (-) AT IGNITION COIL
Speed Sense YELLOW/BLACK (AC) AT ECM MODULE UNDER HOOD ON DRIVER FENDER
BLACK PLUG PIN #57
Parking Lights LIGHT BLUE (-) AT VEHICLE LIGHT SWITCH
Brake Lights LIGHT BLUE/WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
IGNITION MUST BE ON FOR THIS WIRE TO TEST
Reverse Lights DARK BLUE (+) AT BCM MODULE UNDER DRIVER DASH
Horn TAN (-) IN HARNESS AT STEERING COLUMN
ALSO AT BCM MODULE UNDER DRIVER DASH
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock WHITE (-) AT BCM MODULE UNDER DRIVERS SIDE OF DASH
THIS WIRE UNLOCKS THE REAR DOORS ONLY, WILL REQUIRE A 5-WIRE SET-UP IN EACH FRONT DOOR TO INTEGRATE OR A SERIAL DATA MODULE FROM AN ALARM MANUFACTURER
PowerLock LIGHT BLUE (+) AT BCM MODULE UNDER DRIVERS SIDE OF DASH
THIS WIRE LOCKS THE REAR DOORS ONLY, WILL REQUIRE A 5-WIRE SET-UP IN EACH FRONT DOOR TO INTEGRATE OR A SERIAL DATA MODULE FROM AN ALARM MANUFACTURER
i would use a DLPK module
DLPK (2009 Chevrolet Silverado)
W2W
CC-Heated Seats Activation
DL-Arm Factory Security
DL-Disarm Factory Security
DL-Door Lock Control
DL-Door Unlock
DL-Driver Priority Unlock
PK-Immobilizer Bypass-Data No Key Req'd
RS-RAP Shut Down (Remote ACC Power)
RS-Tach / RPM Output
SS-Entry Monitoring ALL Door Pins
SS-Entry Monitoring Driver Door Pin
SS-Entry Monitoring Front Door Pins
SS-Entry Monitoring Hood Pin
D2D
CC-Heated Seats
DL-Door Unlock
Hope helps.
Mar 31, 2011 | Chevrolet Silverado 1500 Cars & Trucks
I have a 1991 Chrysler new yorker fifth avenue, I'm trying to convert the radio to a Kenwood... I've been searching for a Diagram and none of them have the colors that are on my car...
New Yorker and Fifth Ave have different colors for RR speaker neg. Does either of these match up?
1991 Chrysler New Yorker Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 3 1/2?
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Yellow
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
1991 Chrysler Fifth Avenue Car Radio Wiring Schematic
Right Rear Speaker Negative Wire (-): Brown/Yellow
Oct 03, 2010 | Chrysler Fifth Avenue Cars & Trucks
For the Clarion DXZ945MP CD Player for car audio, I do not know the the wire harness color wire diagram? The wiring harness on my Monte Carlo 2000 reads what color wire goes to what, on the side of the...
3amp yellow battery for deck
15 amp yellow is another battery wire
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
red accessory
hope this helps
pls rate cause people arnt rating
Nov 05, 2009 | Clarion DXZ945MP CD Player
Scosche Industries Scosche Je01b Wiring Harness for 1988 1997 Jeep/Eagle Logo
54 people viewed this question
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
ravie__s
Level 1 Expert
Jose Velazquez
Jose Velazquez
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
