Question about Garden
Husqvarna 125b. I have a mess. Blower would only run for.a.few.minutes and shut down. Ifirst changed the l and h carb settings and the spark plug. Didnt help so i took both settings t 1.25 turns. Now it will only run when choked. There seems to be no where to find the recommended sdttings. Please help. This is killing my.arm.
  • 2,239 Answers
The factory will not give carb settings as these machine are set from the factory for the best emmisions, this is why there is a special tool required to alter the screws, the screws are fuel screws not air screws, so as you un screw them ( anti clockwise ) more fuel is let through the carb, your machine is running too lean so the screws are in too far, before making any more adjustments check the fuel filter in the tank is not blocked, check the block the carb is connected too is not loose on the cylinder ( i have seen the screws coming loose ) if all is ok unscrew both screws out a further 1/4 turn and try again.
Posted on Dec 08, 2012
2 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: Husqvarna model 125b Hand held blower (Gas) No
If you have tried a new spark plug and you still have no spark, then your Ignition Coil, (Module) has gone bad. They aren't cheap if you buy it new. Try to find a used one if you can for around $10.
Good Luck!
Jim
Posted on Aug 02, 2011
Gas is leaking from husqvarna 125B blower when priming
Either the return line to the tank from the primer has a hole in it, is broke, disconnected; or the diaphragms in the carb are stiff and the unit is flooding
Jul 26, 2014 | Husqvarna 28cc Hand Held Blower HVH 125B
My blower runs good for first 15 minutes, then will quit
Will it start again after you let it cool off? Run it till it quits then immediately remove the air filter and cover and give a quick shot of carb cleaner into the carb and attempt to start. If it wont start on a prime but will start later after you have let it cool, then does the same thing ( dies after 10 or 15 minutes of use) then it is likely the ignition module going bad.
I suggest you find a serviceing dealer to verify that the module is failing. Husqvarna warranties thier ignitions for life on most models.
Oct 08, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
Have a husqvarna 125b have spark and fuel wont start done every thing i know new plug rebuilt carb gaped coil im tired of pull on it any answers please help it
the rule of thumb is spark, fuel, compression. I found I gad a plugged air filter. It would not start until I removed it and tried to start.
May 07, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
Blower cranks easily and runs fine for about 1 minute and quits. I have cleaned the air filter and changed the spark plug but no luck. Any suggestions would be appreciated?
run it till it quits. pull the plug wire and check to see if you still have spark when pulling it over. if no spark replace the ignition module. if you still have spark then your fuel tank may not be venting. loosen the fuel cap enough that you know its venting and try running it again. if problem solved replace check valve and or fuel cap. hope this helps you
Aug 16, 2011 | Husqvarna 952711918 Leaf Blower Gutter Kit...
Good Luck!
Jim
Aug 02, 2011 | Husqvarna Hand Held Blower 125 B Grass...
Husqvarna Hand held blower. Model # 125-B No Spark
husqvarna model 125b weed trimmer what spark plug do i use manual says rcj-6y in technical data and rcj-8y in monthly maint. ????
Jul 21, 2011 | Husqvarna 125bvx Hand Held Blower Vac
The blower will not start. I changed the spark plug but it still will not fire..
Maybe you have some problem with the carburator. You can put some gas in the carb if it start and then turn out your problem was the carb.
Jan 08, 2011 | Husqvarna 28cc Hand Held Blower HVH 125B
I have a Husqvarna 125B handheld blower, will not stay running
probable clogged screen in carb. rebuild carb with a kit. also check fuel lines and fuel filter
Nov 22, 2009 | Husqvarna Garden
Garden Logo
607 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
