Question about Hardware & Accessories
I've lost the instructions for a TRAC Immersion Heater Timer Model CPI24/7 13 (2) A250 Volts T45 22/240 50 Hz
AndystUK
  • 131 Answers
SOURCE: Where can i get a user guide/instruction leaflet
http://www.greenbrook.co.uk/pdf/T106-C.pdf
AndystUK
Posted on Aug 30, 2009
SOURCE: Need instructions for T.R.A.C. dial hot water
I thought I knew every water heater timer possible.
Never heard of T.R.A.C.
Is that a European timer?
Here's what to do. Set the pins one direction or the other. Start with cool water in tank, so it will turn on for sure when power is applied. Turn on power. Put your ear against water heater. Listen for bubbly-fizzing sound that tells you water heater is on.
Check label on side of tank to see voltage & wattage of tank. Watt rating for dual element tanks is same as element wattage, since only one element is ON at a time. Generally, 240V electric tanks are 3500, 4500, and 5500 watts. That is 16 amps, 21 amps and 23 amps. Make sure your timer has amp rating to match water heater.
Posted on Oct 06, 2010
SOURCE: Is it possible to buy the timer motor for a
1) Paragon is no longer making timers or parts except defrost timers.
7008-20 240V 24-hour mechanical timer is not a defrost timer.
Link below shows folks who might still have Paragon parts
http://portalgb.knowledgebase.net/display/1/index.aspx?c=15121&cpc=XobrEdQ5Lsnv624T2PBS4Exx6S5VyiL7gw3am4YYt6&cid=13013&cat=&catURL=&r=0.485034763813019
2) To see Paragon timers and manuals:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#7000
3) If you want to buy new timer: Intermatic cross-reference guide shows T7802B is correct replacement timer
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
4) Electric supplies online shows T7802B 4 pole 2NO/2NC
http://www.electricsuppliesonline.com/int7tidp20t.html
5) Manual for T7802B
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t7802b%20-%20english.ashx
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 09, 2011
SOURCE: Timer Model #: 49550/TM151P I've lost
Open following link to identify timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#49528
This Woods timer does not have replacement trippers available.
Replace with Intermatic TN311C
Posted on Jul 05, 2011
SOURCE: I have a Utilitech
Open following link for Utilitec timer manual:
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
This timer should have a back-up capacitor so that programming is kept in memory during power outage.
Power outage is known cause of timer failure. When power turns on, the surge knocks out electronics.
People writing to fixya report electronic timers and electronic water heater controls stop working after power outage. Probably many other electronic devices are affected too, but that would be out of my specialty.
Troubleshoot says 'in case of operational failure, press reset button to clear all settings and restart.'
If timer has failed, buy another from Lowes and return defect in new package.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Posted on Sep 11, 2011
Need instructions for grasslin 16 amp immersion heater timer
https://fauroanofi.files.wordpress.com/2015/03/grasslin-immersion-heater-timer-manual.pdf
Apr 21, 2015 | Hardware & Accessories
Www eemaxinc com support
My limited research indicates this heater is designed for USA electrical systems. That would mean single phase, 240/208 volts, 60 Hz. The drawings I reviewed shows a 2 pole, 240 volt breaker feeding each heating circuit. That means no "neutral wire" goes to the heater and therefore no 120 volts is needed. This is good. Kenya's system is single phase, 240 volts, 50 Hz. The heater should work reasonably well on the African system. Connect the power just like you would in the US.
Jan 17, 2014 | Water Heaters
I need a timer for a 208v water heater
Nope it is only rated for 120 volts
http://www.drillspot.com/products/43780/Intermatic_T1975_Indoor_Multi_Operation_Timer
You would need a Paragon timer that would be rated for 240 volts
kinda sorta like this defrost timer: http://www.ebay.com/itm/Commercial-Defrost-Timer-Paragon-8141-20-S814120-40-AMP-2-HP-208-240-Volts-60-Hz-/300933095423?pt=US_Replacement_Parts&hash=item4611029fff
Jul 16, 2013 | Dryers
Trying to find the right fuse for a eden World Tour 800 bass amp
Well, hope this helps you.
Fuse Requirements:
USA @ 120 Volts /60 HZ - 10 Amps, 5 x 20 mm GMC/T/slow blow
Europe @ 240 Volts/50 Hz - 5 Amps, 5 x 20 mm GMC/T/slow blow
Japan @ 100 Volts/60 Hz - 12 Amps, 5 x 20 mm GMC/T/slow blow
Mar 10, 2013 | Hartke HyDrive HX410 4x10 Bass Cabinet...
My Eurosonic 7 day programmable timer doesn't activate. I've lost the instructions, are they available?
1) Eurosonic appears to analog timer:
http://waterheatertimer.org/How-to-set-timers.html
2) There is new series of digital timers from china, also sold as Eurosonic:
Copy following link for possible manual. Always reset digital timers before programming.
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
3) Add a comment March 2013 and describe timer in detail
Mar 10, 2013 | Hardware & Accessories
Can you use a plug in timer to switch your storage heater on during the cheap rate electricity
Generally NO.
But...it Depends on amp rating of timer, wattage of water heater, and line voltage.
Look at label on side of heater for watts.
Electric water heater will work on any voltage.
1) Start with 120 Volt outlet::
Volts x amps = watts
Watts divided by volts = amps
Let's say outlet is 120Volts. Lets say water heater is rated 4500 watts.
4500 divided by 120 = 37 amps
There is NO plug-in timer rated for 37 amps.
Let's say water heater is rated 900 watts.
900 divided by 120 volts = 7.5 amps
Yes. The Intermatic HB113 timer will handle up to 8 amps.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#appliance
2) 240 Volt outlet
Same calculations as above.
1900 watt element divided by 240 volts = 8 amp.
Yes, the Intermatic HB112 timer will safely handle that element.
3) Here are some water heater timers:
http://waterheatertimer.org/Compare-13-electric-water-heater-timers.html
4) Here are some off-peak water heater ideas.
http://waterheatertimer.org/Off-peak-water-heater-ideas.html
Oct 31, 2012 | Hardware & Accessories
Hi experts! I've moved into a new Flat but there wasn't a manual left for the immersion heater timer. At the moment I'm leaving it on all the time which no doubt will start to cost more money than...
Mikey Mike, I think I may have found a link that you can find the Owners Manual you're looking for. You'll need to pick one that looks like yours (since you don't have a model #), click on it and after it takes you to another page, browser back and look at the top right corner and you'll see a highlighted technical link. Click on it and it will take you to the Owners Manual for that particular model.
By the way, your timer is manufactured under the name TRAC Immersion timer.
I hope this helps, because finding things in the UK ain't easy, for this good ol' boy from the US. If does, please leave me a good rating. Thanks!
http://www.tlc-direct.co.uk/Manufacturers/Trac/Timers_Wired/index.html
Mar 24, 2011 | Heating & Cooling
Where can I buy/get the instructions for a T.R.A.C. TC CP124 immersion heater timer?
Probably too late, but may help someone else. Sorry about the poor quality; https://www.dropbox.com/s/ib2hyco004qdtcn/TRAC%20CP124.pdf
Oct 31, 2010 | Kitchen Appliances - Others
Need instructions for T.R.A.C. dial hot water heater timer - not sure whether pins pushed in = off and out = on or vica versa
Oct 06, 2010 | Hardware & Accessories
Hardware & Accessories Logo
56 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
