Question about Echo Pb - 413t Backpack Blower
How to change fuel filter on back pac blower - Echo Pb - 413t Backpack Blower
  • Echo Master
  • 2,239 Answers
Bend a lenght of welding wire so as to have a loop at one eng, insert through the fuel filler hole, hook the fuel hose in the tank and pull it and the filter out,
Posted on Dec 08, 2012
Echo PB-251. Wont run full speed,changed ,plug,filters
I'm 99.9% sure it's the fuel line. The ethnoll in gas really shrinks the oem fuel lines
Jan 13, 2015 | Echo Pb-251 Leaf Blowers
How to change or clean the filter and where to download a manual
DeLonghi has the manuals for their portable air conditioners here: http://delonghiusa.com/support/product_manuals/5#table-jump . The direct link to the PAC C120 manual is http://delonghiusa.com/support/sites/default/files/product_manuals/m-PAC+C120.pdf .
Before cleaning, turn off the air conditioner. To clean the filter, pull it straight up from behind the top of the air intake (on the back of the PAC C120). Vacuum off the filter. If it is very dirty, immerse it in warm water and rinse several times. (The water should not above 40 degrees Celsius (104 degrees F)) several times. Then allow the filter to air dry. Slide the filter back into the air conditioner and turn the unit back on.
I hope this helps.
Jul 17, 2011 | DeLonghi PAC C120 Portable Air Conditioner
I have water coming from the back of the unit when it is on, please help
Air filter,Evaporator coil block or less speed of blower motor or drain pan blocked. Hence first service the unit frequently to avoid not only leak of water but also major problem.
Dec 08, 2010 | DeLonghi PAC C100 Air Conditioner
I have a homelite yardvark blower and I want to change the fuel filter. How do I change the fuel filter? Yardvark runs fine at beginning, but begins to run eradicatly after a short time. What's the...
could be fuel lines, fuel filter, or your carburetor needs to be rebuilt. The carb has thin rubber diaphragms that get hard over time, hot weather, or stale gas. Need more assistance,
email desertairrepair@aol.com.
Jan 31, 2010 | Homelite 'Yard Broom' Leaf Blower
I have a huskavarna leaf blower 140 back pac i run it for 5 min then it srarves for gas let off on the throtle for 10 seconds put on full it gos to full rpms the starves agian
Carburetor may need adjusting or rebuilding. I would try mixing up some fresh fuel mixture and try that first. Use gas from the station not from the can sitting in the garage.
Good Day.
Oct 28, 2009 | Husqvarna Backpack Blower, Model No. 356bt
How do you change the fuel filter on a ryobi backpack blower Model RY08570?
Disconnect the fuel Line from the carburetor and, using needle nose pliers, grab the fuel line in the tank just behind the filter and pull the line and filter out of the tank. BE CAREFUL YOU DO NOT PULL THE LINE ALL THE WAY OUT OF THE THE TANK!! Pull the filter off and replace with the new one and put the new filter back in the tank, then reconnect the other end of the fuel line to the carburetor. Hope this helps!
Sep 10, 2009 | Ryobi Garden
Can't get my Echo PB251 Blower to rev up at all, unit is 8 mo.s old was running fine now all of a sudden won't rev up, I have changed plug gas filter,cleaned all filters including spark arrestor changed...
guarantee exhaust is clogged maybe not muffler but exhaust port pull muffler off check screen and muffler then look into exhaust port usually rectangular port is closed down with carbon pull starter slowly to lower piston then scrape out carbon with screwdriver clean as good as possible then blow cylinder out make sure to get all pieces of carbon out reassemble should run fine
Jun 14, 2009 | ECHO, Inc. PB-251C Handheld Blower
Echo Pb - 413t Backpack Blower Logo
48 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
