Question about RIM BlackBerry 7250
Disconnect/close button does not work
The disconnect/close button on then side of my Blackberry only works on occasion. Is there a way for me to fix this? I am betting it is a contact problem, but I am reluctant to open the unit for fear of causing anothe problem.
  • pooja140683 May 20, 2009
    In blackberry when we don't add any screen command then it shows a "close" button by default .Is it possible to remove this command & when we press trackwheel ,it directly performs the functioning of "select " button of my application.if it is possible then how can i do it.Remember that my application is extends by MIDlet & not blackberry's UIAppliction.
  • 883 Answers
Try this: turn it off. fill a bowl with alcohol. while holding the Blackberry under the alcohol at the place where the disconnect/close button is located, press the button many many many times until you are nuts. The goal here is for the alcohol to penetrate into the contact area and wash away any debris. Then towel dry and use a blow dryer (be careful!). Any change?
Posted on Jun 08, 2007
I flew to Italy this morning and trying to use a TELECOM ITALIA MOBILE (TIM) SIM car with my O2 Blackberry. I have done this before without any difficulties, but on this occasion my TIM SIM card will not...
Looks like you just simple change your o2 sim card with tim simcard on your blackberry. You can't do that if you want to use TIM sim card on your blackberry, you must use blackberry bold 9700 unlock code for O2 to unlock your blackberry network. After your blackberry unlocked then you can put any sim card from other network in your phone.
May 25, 2011 | RIM BlackBerry Bold 9700 Smartphone
My blackberry curved 8520 toggle button doesn't work. how do I fix it.
my blackberry curved 8520 toggle button doesn't work. how do I fix it.
Mar 28, 2011 | RIM Blackberry Curve 8520
My middle button of my bb 8520 has stopped working?
If you can open front case then its very easy to solve. just clean dust and then with small pin or any small pointed pin push internal plastic to down side so that button can work well. after done test it then close that case. if not solved then may be issue with circuit side problem and it also related to switching IC of keyboard so if this is damage then you need to replace IC.
Dec 06, 2010 | RIM BlackBerry Curve 8520 Smartphone
My volume button doesnt work on my blackberry bold 9000 is there any way to fix this or work around it to turn up the volume
You volume button needs to be replaced. If you want to do it yourself, the good news is, it's not too hard to open it. Here is an Blackberry Repair Guide that shows how to open a Blackberry. If you want somebody else to do it for you go to Blackberry Repair.
May 20, 2010 | RIM BlackBerry Bold 9000 Smartphone
Camera display to clo0se applications to use camera,how?
When you press the red or end button to close a program it does not exit but rather minimizes it. you need to hit the menue button the blackberry key ( the one with all the dots next to the trackball) and select close or exit
Feb 22, 2010 | AT&T Blackberry Curve 8300 Smartphone
Blackberry storm buttons wont work
Have you tried pulling the battery? Often times my Storm has locked up and nothing worked. The only way to really do a restart, is by pulling the battery.
-Take the battery out and wait 1 minute. -Replace the blackberry and wait for Operating System to startup -Test
If this doesnt fix the problem, you may have a problem unit and you should take it in to the Verizon Wireless store.
Jun 20, 2009 | RIM BlackBerry Storm 9530 Smartphone
How do i reset blackberry curve 8330 to factory settings
are you actually going to the menu button and selecting close on each screen or just hitting end or the return button to get to the home screen? If you don't actually select close in the menu screen some progams remain open. go into all applications when there press the menu key and scroll down to close this should help
Jan 17, 2009 | RIM Blackberry Curve 8300
Blackberry camera
turn off ur bb mobile by disconnection the battery from mobile phone and put the battery after 1 min and start the hand set
Nov 16, 2008 | AT&T Blackberry Curve 8300 Smartphone
RIM BlackBerry 7250 Logo
98 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
