Question about Campbell Hausfeld CW207588AV Pressure Switch w/Unloader
Campbell hausfeld pressure switch problems leaking air
  • 89 Answers
SOURCE: help! air compressor trouble.
ASSUMING YOU ARE TALKING ABOUT THE PRESSURE SWITCH. YOU SHOULD EITHER HAVE 2 WIRES OR 4 WIRES ON THE SWITCH. THE SWITCH IS TYPICALLY MARKED LINE-LINE-LOAD-LOAD. IF YOU CAN SEE THE INSIDE OF THE SWITCH YOU WILL SEE THE CONTACT POINTS. ONE CORD WIRE CONNECTS AND PASSES THRU ONE SET OF POINTS TO ONE WIRE OF THE MOTOR. THE OTHER CORD WIRE PASSES THRU THE OTHER SET OF POINTS AND CONNECTS TO OTHER MOTOR WIRE. YOU TYPICALLY WILL NOT HURT THE COMPRESSOR BY HAVING THIS WIRING INCORRECT - PROBABLY JUST POP THE BREAKER INSTANTLY. IF YOU CANT SEE THE PATH THRU THE POINTS YOU CAN OHM THRU THE POINTS AND GET A CONTINUITY BEEP ON A VOLTMETER. IF THATS NOT AN OPTION, JUST SWITCH THEM AROUND UNTIL IT RUNS. HOPE YOU BOUGHT THE SAME CUT-IN AND CUT-OUT PSI. GOOD LUCK AND WRITE BACK IF THIS DOESNT GET IT. JODY
Posted on Apr 07, 2009
comax
  • 154 Answers
SOURCE: Does anyone know what the spark plug gap setting
Most gas engines will work fine at .030 to .035 sparkplug gap
Posted on Apr 16, 2009
  • 98 Answers
SOURCE: campbell hausfeld 20 gal compressor builds
Needs pressure switch adjusted or new
Posted on Jul 21, 2009
  • 384 Answers
SOURCE: PW1345 Campbell Hausfeld Won't run
Got gas?
Posted on Jul 22, 2009
  • 98 Answers
SOURCE: I have a Campbell Hausfeld Quick Air DK618300AV without a fuse...
3.5 amp fuse
Campbell Hausfeld 4.5 H.P. 20 gallon tank , I have an air leak in the unit that houses the on / off switch and the guages ....
They call it a pressure switch the tube maybe lose and use a wrench to tighten you can buy the switches on eBay or online home depot
Jan 28, 2015 | Campbell Hausfeld Air Tools & Compressors
Campbell hausfeld 60 gallon sight glass oil leak
Try here http://www.about-air-compressors.com/campbell-hausfeld-air-compressors.html
Jul 30, 2012 | Campbell Hausfeld Air Tools & Compressors
I have a campbell hausefield vs series air comp and when it reaches full air supply and shuts off air leaks (alot) out of the switch i replaced and nothing changes.
There is a check valve on the tank where the line from the pump goes to. It should also have a smaller line running to the pressure switch. If the valve or spring inside is broke or stuck it will leak as you describe. You need Campbell Hausfeld part number CV221502AJ.
Dec 22, 2010 | Campbell Hausfeld 5HP 26 Gallon Single...
Electric compressor motor problem
Unloader valve on switch. That switch is not bleeding off cylinder head pressure,when it shuts off.
Apr 06, 2010 | Campbell Hausfeld 26 - Gallon Air...
Charge unly to 60 pnds,MOdel wl 6166 26 gls. I change the pressure switch look for air leaks seems to ok
The pressure switch only starts and stops the motor, if there are no leaks and it will not build pressure, then the pump has lost its capacity.
Feb 12, 2010 | Campbell Hausfeld Air Tools & Compressors
Air leaks from pressure switch
The safety over-pressure valve is leaking and needs to be changed.
Nov 05, 2009 | Dishwashers
Campbell Hausfeld CW207588AV Pressure Switch w/Unloader Logo
42 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
