Question about Norelco Health & Beauty
Norelco maverick t3000 disassembly - Norelco Health & Beauty
How to fix the spring and heads for a norelco maverick t3000
Unfortunately, the plastic that holds the spring in place is broken. To fix, you would need to replace the blade assembly. Unfortunately, the part you need was discontinued by the manufacturer some years ago
Nov 20, 2016 | Norelco Health & Beauty
How do i replace a battery in a norelco 4604x shaver
The correct battery can be found at shaveroutlet.com here:
http://shaveroutlet.com/shaver-replacement-battery-pack-fits-norelco-3605-others-p-277.html
Disassembly video is here:
http://www.youtube.com/watch?v=2oAnLpvdYqQ
Sep 21, 2014 | Health & Beauty
How to replace the batteries for a norelco r model 4865xl shaver
Correct batteries for your model can be found at shaveroutlet.com. See link bewlow
http://shaveroutlet.com/shaver-replacement-parts/batteries/philips-norelco/shaver-battery-pack-for-most-norelco-more-p-278.html
Videos for disassembly and installation can be found at links below
http://www.youtube.com/watch?v=rGD84BfKxAE
Nov 07, 2013 | Norelco Micro Action Shaver 4865XL...
Norelco Maverick T-3000 batter replacement
Yes, the batteries are replaceable. If you feel comfortable desoldering the old batteries and are competent enough to resolder new batteries look for them on the Radio Shack website. There are also online small applicance repair sites that will sell replacements for around $9.00. If you are not comfortable doing the soldering, Batteries Plus will solder the new ones in place. The total is less than $15.00 at my local store.
Mar 31, 2012 | Norelco Health & Beauty
How to clean norelco 8846XL shaver ?
You will need to disassemble the heads and brush them out. You can soak the parts in rubbing alcohol if they are gummed up. This will loosen the material up so that it can be brushed away. An old toothbrush works well for this.
To disassemble the heads you will find a tutotial video at shaveroutlet.com. Click on link below and scroll down for video
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
Aug 28, 2011 | Norelco Spectra 8846 XL Electric Shaver
How do I change the battery on my Norelco shaver Model 3805XL? Is there on online manual?
You will find batteries for 3805XL at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
Scroll down the page for helpful videos for disassembly and battery installation
Jul 20, 2011 | Norelco Health & Beauty
Can I replace the trimmer blades (not the shaver heads) on my Philips 8175XL? I use them all the time and they are wearing out. Where do I get them and how do I install them?
You will find a replacement trimmer at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-8100-series-sideburn-trimmer-p-388.html
See disassembly video tutorial at shaveroutlet.com using the link below. You will not have to disassemble as far as the video shows. Just remove the back cover and the trimmer can be 'disjointed' from the cover
http://www.shaveroutlet.com/philips_norelco_shaver_disassembly
Oct 27, 2010 | Philips Norelco 8175XL Electric Shaver
How do I change the Battery in My Norelco T3000 Beard Trimer
Remove Phillips head screw at bottom of trimmer. Separate body in two being careful to notice how on/off switch is assembled. Unsolder the ni-cad battery from circuit board. Install new ni-cad battery of the same physical size that has solder tabs on it and solder it to the circuit board. I used a ni-hi (nickle metel hydride) instead of ni-cad which had different charging requirements so I limit charge time to no more than 16 hours for a discharged battery. It had been working fine for over a year. Don't forget to apply a few drops of light oil to the cutting blades to extend cutting life. Replacement blades are about $30.00
Jul 06, 2009 | Norelco T770 Beard Trimmer
Health & Beauty Logo
330 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
