Symptom k7s5a shuts down after 1 second
After blackout. Changed PSU... same symptom. If all disconnected (disks, pci slots, etc) except Mobo, cpu, ram ... same symptom; reset cmos... same symptom. Hardware troubleshooting needed; e.g. bad caps? some burnt component?
  • 5,660 Answers
1) http://capacitorlab.com/visible-failures/index.htm
2) Starts at 0:04,
http://www.youtube.com/watch?v=KN6_-8fYHo0
3) http://www.hardwaresecrets.com/article/616
However, the Electrolytic Paste inside the Radial Aluminum Electrolytic Capacitors; can also dry up, and show no outward visual signs of damage.
4) If the Thermal Paste (Or Thermal Pad), has dried up in-between the Processor, and Heatsink. you can see the same.
Regards,
joecoolvette
Posted on Dec 03, 2012
  • 7 more comments
  • Juan Barreto Dec 04, 2012
    Thank you for the links, specially hardwaresecrets.com. Looking forward for next weekend to replace all the 2200uF capacitors around the chokes and mosfets
  • joecoolvette
    joecoolvette Dec 05, 2012
    You're welcome Juan, and thank you for the rating! 1)http://www.hardwaresecrets.com/article/H... 2)http://www.youtube.com/watch?v=YCSNWi3UH... 3)http://www.mouser.com/Passive-Components... 4)http://www.radioshack.com/product/index....
  • Juan Barreto Dec 06, 2012
    Not only Gluxon capacitors, a big mosfet L3103S is short-circuit (removed and verified; i have replacement). It seems that one additional small surface transistor (SOT23 packaging) is damaged too. Its labeled "1P", other aside is labeled "2F". How can I find the complete code? Could be IRLML9301 but not sure. Thanks for ANY hint to find and solve this.
    Found :-) 1P = FMMT2222A (NPN), 2F = FMMT2907A (PNP)http://www.repairfaq.org/REPAIR/F_SMD_tr...
  • joecoolvette
    joecoolvette Dec 06, 2012
    Excellent job Juan! I'm following right along. You should try motherboard component level repair, for other people too. They could use your knowledge, and you may be able to save them loads of money. Just my 2Cents. Regards, joecoolvette
    Hello... it worked!! completely. In fact i'm posting from the repaired PC :-) Resuming a) Replaced 11 x Gluxon capacitors, several were bulged b) Replaced 1 mosfet IRL3103S (smd) with equivalent IRF3205 (TO-220 case) with a heatsink; c) Replaced small driver labeled "1P" (smd) with 2N2222A (TO-18 case). I first turned on with only CPU, RAM and ATX conector to Mobo, same original PSU; it didn't shut off :-) and beeped (expected). Then I plugged PCI, hard disks, etc Then beeped again, lost CMOS (expected). Then plugged all: keyboard, monitor,etc, entered BIOS to see voltages... all normal. Once reconfigured cmos, booted, windows, tested disks, temperatures, etc ALL normal so far. I hope this stands up a couple of years :-)
  • joecoolvette
    joecoolvette Dec 07, 2012
    Years ago a Capacitor Plague happened. It is still affecting us today,http://en.wikipedia.org/wiki/Capacitor_p... A tale of revenge, and espionage. Lab tech is fired from major Japanese electrolytic capacitor company. Felt wrongly fired, a female co-worker decides to steal the heavily guarded electrolytic paste formula. She was found out beforehand, and given a bogus formula. Formula doesn't have ingredient/s needed to hold down Electrolytic Paste gas formulation. Formula is taken to another country, and this manufacturer manufacturers Thousands, upon thousands of bad capacitors. Also if an electronic unit sits around not plugged into power, for a trickle charge to those 'Caps', the Electrolytic Paste chemically breaks down. My guess is that those 1200uf caps are in the motherboard voltage regulator circuit, and without regulated needed voltage to the Power MOSFET, the Gate/Source was too high, and smoked the IRL3103S Power MOSFET. The rest were just 'dominos' in the circuit 'chain'. And now back to you Bobby.............................................
  • Juan Barreto Dec 11, 2012
    Yes, I'd seen that Wikipedia entry. Interesting story. In fact, it's not the first time I repair something just replacing bad caps... I repaired 2 years ago an ADSL WiFi Router just replacing 4 10uF capacitors.
  • joecoolvette
    joecoolvette Dec 12, 2012
    Interesting Juan, about the ADSL router. AT&T wireless routers had a problem with the Electrolytic 'Cap's. Capacitance was correct, but Voltage value was too low. I believe it went from 16 Volts to 24 Volts, but don't quote me. Been a long time since I replaced caps in an AT&T router, and read the information I just stated. (May have been 20 Volt) Wikipedia entry? Yes. the added info I added, may not be found on the 'net anymore. Made a certain country look bad, and it's resident Electrolytic Capacitor manufacturer/s. (This is also why Japanese Electrolytic Capacitors are looked on with great favor)http://www.hardwaresecrets.com/article/H...http://www.hardwaresecrets.com/article/6...
sandrew
  • 2961 Answers
SOURCE: CPu fan turns for 1 second and then stops.
If all was working fine before, then, you have either not connected the cpu power cable, as is sometimes required other than being powered by the processor socket, or your power supply unit is not pentium 4 compatable and is unable to power the processor.
Posted on Apr 07, 2007
SOURCE: P4i65G - brand new want start.
What kind of P4 3.4Ghz is it? if it has 2mb of L3 cache, it doesn't work with that motherboard
Posted on Oct 25, 2007
Kurth
  • 86 Answers
SOURCE: shutting down then starting back up whenever
Ya. If it keeps re-booting then it may be a virus (my things virus)
If not, go to system properties and start up and recovery settings. remove reboot on error settings (in XP) It doesnt fix the root cause but may stop your frustration
Posted on Apr 11, 2008
johnychel
  • 796 Answers
SOURCE: Boot problem
click here
this could help you
Posted on Jun 18, 2008
  • 101 Answers
SOURCE: NO video @ bootup
Are you sure that the memory you have installed is compatible with your motherboard.
It is weired but some memory do not work with certain motherboards, irespective of speed or voltage rating.
Posted on Aug 05, 2008
Motherboard booting problems...How do I solve?
Hi
Try to boot with 1 stick of ram then swap it with the other and try again. Next unplug the case front connections from the mobo header (pins). Draw a sketch where they all go so you don't forget. I'm talking about the power switch, reset SW, HDD LED etc. Also remove anything connected to the back panel printers etc. Also remove the mouse and keyboard. Carefully, momentarily short the pins that were connected to the power switch and note results.
If it still doesn't boot, remove all parts from the mobo except 1 Stick of RAM, graphics card, PSU, and of course CPU. Leave the mouse and keyboard unplugged. Try to boot by shorting the mobo pins again. If it doesn't boot it is most likely either the PSU or the mobo. It could also be the CPU or RAM but it is less likely.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 04, 2011 | EliteGroup RS482-M754 Motherboard
Asus M4A88TD-V EVO/USB3 BIOS: 1702 AMD Phenom II X4 955 PSU Ultra 500watt ATX RAM Patriot DDR3 1600Mhz 2x4Gb Mobo will not POST, no beeps, fans turn for one second and stop. Mobo replaced with same,...
So you changed everything except 1 thing, power supply. Try another power supply or power suply cord.
If it doesn't work, try another graphic card, maybe there is some shor circuit.
May 07, 2011 | ASUS Motherboard M4A88TD-V EVO/USB3 AM3...
I have a Compaq Presario SR1830NX desktop, I leave it on all the time, when I got up this morning, it was off, so I pressed the power button, but it doesn't power on, nothing happens.. I checked the power...
step 2 the TECH uses a voltmeter and checks all wires on PSU for correct voltage.
PSU in Desktop dead, my guess fans dead too right>
you never said, what it does inside PC ,except nothing
does nothing mean dead silence?
the fan must run for 1second, then goes off.
a 1 second run tells me the PC power switch told the MOBO to turn on and in turn it tells the PSU to turn on,
the PSU then turns on for at least 1second,and if the voltages are ok
then the PSU stays on, else off goes.
15 and 16?
the 20 pin older supplies those are both ground
but 24 pin ATX pins are correct there.
the voltages are here.
https://en.wikipedia.org/wiki/ATX
There are 2 causes, of dead power button.
1: the buttons 2 wire cable ends fell off. at button or PC mobo.
2: The PSU is bad.
3: the MOBO is bad.
The mobo can also shut off any PSU, if the PSU fails
or it sees the regulators in the MOBO fail.
the Desktop runs on many power rails.
some in the PSU, others on the MOBO.
THe mobo creates special low voltage for the CPU.
the power good pin, does that #8,
One way to see if the MOBO is overload
is to remove things from it, I start at RAM
lacking a voltmeter, this is very hard to fix any thing electric.
only guessing or pulling objects PC can find shorts.
pull all power cables there, hdd, power, cdrom.
all things that use red/yellow wires.
all SATA cables, all USB , then ram. even a fan can short
a good tech keeps an open mind, and finds why the PSU shut down.
in most cases, the PSU is bad. but not always.
This is a feature, of ATX it keeps you from blowing up say a
$300 microprocessor.... or fancy gaming Video card (have one)?
yes, pull the video card too.
Jun 25, 2017 | HP Compaq Presario SR1630NX PC Desktop
When I turn on the computer it starts to beep every four or five seconds; it doesn't even turn on the screen. The display at the motherboard is "04". What does it mean? There was nothing wrong with my...
This is do with a device failure it can be the RAM of your system , Try swapping the RAM and if you find two RAM in your system remove one to check the error.
Kindly send me your valuable feedback.
Jan 16, 2010 | Abit KV8 Pro Motherboard
Not Booting
Hi, This is an old board trying to run a hungry CPU. From the symptom you describe the poor thing may be wearing out right in front of you. Anyhow, - In order of likelihood your problem(s) are probably:
1 - Defective motherboard. PC chips is well known as a maker of cheap mobos. When run even a little hot they have a short lifespan. A 3Ghz Pentium Prescott needs a lot of power. A faulty part may not always kill a session but it can ruin your life. Try running the PC underclocked at ~2Ghz. See if the prob goes away. If so, better cooling the support chips may help. Best solution is replace this old warrior with a new mobo. You will also need a new PSU & CPU if this is the problem. Except for playing games, even slow dual core CPUs will perform better than a single core unit.
2 - Bad PSU. These also wear out, especially if run hot. Best solution is new PSU. If you do this, get a modern model that will handle a mobo upgrade should that also become necessary. Many options & prices here - be careful.
3 - Bad PCI card or RAM. If you already haven't - try removing all unnecessary hardware... then test for problem. Switch your DDR2 RAM in & out to test for defect.
4 - Bad CPU. Not likely but possible. try running the PC underclocked at ~2Ghz(if this mobo lets you). See if the prob goes away. If so, better cooling might be the hot tip
Dec 15, 2008 | Intel D915GVWB Motherboard
No beeps on boot up with asrock mobo? help plz
While booting BOIS goes for POST check for detecting the all the hardware .
Disconnect all the connection to DVD, HDD, FDD from MOBO.
Rmove all RAM and start the ssytem from testing RAM Serviceability. If you listened a long intermittent beep place a single pices of RAM in MOBO ( repeat test with other RAM also).
Other wise your video card is unserviceable, if you have any addon plugins like NVIDA graphics card you can check
Jun 10, 2008 | Asrock K7S8X-R3 Motherboard
Asus P5GD1-FMS 775 Intel 915GExp. need help..
v i i i
P5GD1-FM specifications summary
(continued on the next page)
CPU
Chipset
Front Side Bus
Memory
Expansion slots
Storage
High Definition
Audio
LAN
USB
IEEE 1394
BIOS features
Rear panel
LGA775 socket for Intel® Pentium® 4/Celeron processor
Compatible with Intel® Performance Universal FMB 2005
processors
Supports Intel® Hyper-Threading Technology
Northbridge: Intel® 915P Memory and Controller Hub (MCH)
Southbridge: Intel® 82801FB ICH6
800/533 MHz
4 x 184-pin DIMM sockets support unbufferred non-ECC
400/333 MHz DDR memory modules
1 x PCI Express x16 slot for discrete graphics card
3 x PCI slots
Intel® ICH6 Southbridge supports:
- 2 x Ultra ATA 100/66/33 hard disk drives
- 4 x Serial ATA hard disk drives
Realtek® ALC861 8-channel CODEC with Jack-sensing
and Universal Audio Jack (UAJ®) technology
1 x Optical S/PDIF out port
Realtek® RTL8101L LAN controller
Supports up to 8 USB 2.0 ports
T1 controller supports:
- 2 x IEEE 1394a ports
4 MB FWH, AMI BIOS, Green, PnP, DMI2.0, WfM2.0,
ACPI 2.0a, SM BIOS 2.3
1 x Serial port
1 x IEEE 1394a port
1 x LAN (RJ-45) port
4 x USB 2.0 ports
8-channel audio ports
Nov 24, 2007 | Computers & Internet
Computer in black screen, no energy outputted
A few possibilities(the only problem is if you never get any display to try many of these suggestions): -Suspend. With suspend, everything is put to RAM and the computer goes to low power state, shutting off USB, HD, and most other things, but the PSU is still on so the fans keep spinning. All it takes to wake it up is either a punch on the keyboard (that is still active) or tapping the power button again. I saw a computer act like that once except it wasn't really in suspend. It had basically half-crashed, half shut down. r-emove "extra" components that are not needed for the computer to run. Like Sound cards etc, leaving only the essential components in and see if this fixes it. -Possibly, one of your attached devices is telling the PC to hibernate/shut down, but it's not happening correctly. If you go into Device Manager and look at the properties of most devices like NIC, soundcard, etc, you'll see a checkbox for "Allow this device to wake computer up/put it to sleep" etc. Check that out. -Violent spyware/viruses can also cause these symptoms. -ACPI, incorrectly implemented at the BIOS level, will not wake from suspend correctly. You would flash your BIOS to the latest version, and then in the power settings in BIOS and in XP, turn off power management (while on AC in XP). If the BIOS does not correctly detect keyboard or mouse wakeup, it will not and appear as it is. A telltale for lockup (bypassing keyboard/mouse) is if the system does not respond to the power switch. The power switch also is tied into ACPI. A push of the power switch also send a wakeup or suspend/off message. By holding the power switch for 5 seconds, the off is forced through the BIOS (and that is a surer sign that it locked up.) -A faulty HDD might not wakeup also (ignores or does not get the start signal). -Also, it is not recommended that you "turn off" ACPI. ACPI APIC adds the benefit of better IRQ handling. If you really can force ACPI "off", you may run into more frequent issues with IRQ conflict resolution (does not mean they will happen, just increases the chances.) -could be a defective RAM stick, if you get a good one, and replace it one by one with yours, you might find one that when replaced takes away the problem. or run memtest86, or Prime95(on testing - memtest tests ram, prime95 will test cpu/fsb, futuremark will test video,everest can see mobo temps/voltages in windows, a digital multimeter will test a power supply for voltages but it is not 100% accurate because these can change under full load) -Could be caused by Java issue with Azureus, a bit torrent client. -Do you have an nvidia card? newer nvidia drivers have issues with java. Try This: 1. Start->Control Panel->System 2. Click the Advanced Tab 3. Click the Environment Variables button 4. Click the New button 5. For Variable name:_JAVA_OPTIONS 6. For Variable value:-Dsun.java2d.d3d=false That solves a lot of problems with java it seems, by making it simply not use direct3d for everything. -updating your motherboard's bios. -Bad PSU, try switching. -mobo grounding out. 1. Remove all unnecesary components from mobo, then take it out, leaving it still hooked up to the power source and monitor 2. set mobo on floor, 3. try booting up 4. what happens now? -Bad mobo DIMM slots. -It could be something basic including a device driver. Check your eventvwr 's system log and see if the stop was listed. It should at least list the stop number. I hope something here will clue you on the way to solve your problem, good luck!
Jun 18, 2006 | E-Machines eMachines T3830 PC Desktop
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
