Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Where is the air filter located on a PT-50LC14
4 Suggested Answers
  • 19 Answers
SOURCE: how do i clean the air filter in my pt-50lc14 tv ?...
hi here u solution, no easy, but u can try,good look :)http://schematicsforum.com/schematics//TV/Panasonic/PT-50LC14.pdf
Posted on May 27, 2010
SOURCE: pt-50lc14
Unplug the unit! Pull off the access silver panel from the front of the tv. there are 2 sma ll access panels on the front behind the silver panel. The one on the left, allows you to change the bulb, one screw to remove, Just to the right of it there is a second one. This has 2 small screws to remove to access the opening. Once you take this small cover off, you will see the fan compartment. On the top of it on the left side is one small filter, mine was pretty clean. The bear is the one on the bottom, that you can only see the edges, but there is a small opening on the bottom. It looks like it is suspended in mid air. Take a cue tip and clean the underside! I slightly wet my cue tip and it worked fine. I tried to remove the fan compartment, but it would not come out and I did not want to force and break it. Remember to unplug the unit first. After I used the cuetip on the filter, I have a small vacuum and cleaned everything carefully. I had heard to leave it unplugged for about two hours to let it clear after I reassembled the covers. I turned on the set and the message was gone and has never come back. I did not have to reset anythi.ng and worked for me. That was it for mine and it is working fine
Posted on Jan 11, 2008
SOURCE: OSD Message Panasonic PT-50LC14 Air Filter Needs Cleaning
I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it.
Posted on Nov 04, 2008
I need the service manual for the Panasonic PT-50LC14. Can u help. We have to change the Blue Filter and I cannot find my service manual. Thanks
It's $38.95 at Partstore at this link
http://www.partstore.com/Part/Matsushita/Panasonic/PT50LC14/Matsushita/Panasonic/SMPT50LC14/New.aspx
Sep 28, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Lamp reset on a panasonic model pt-50lc14-k
This works for mos Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Nov 12, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Air filter location for samsung dlp hl-s5086w
More or less make sure there is no dirt or dust Blocking Air way CK Fans and Lamp housing blow out all dust and dirt.
Sep 30, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Sep 28, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Grennish/yellow spots pt-50lc14
I received a new blue polarizer unit from Panasonic. I installed it and it fixed my problem!!!
Duane
Apr 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Air Filter message
ok you know i would just take it back with the warrenty but heres what i think you should do in the manuel there should be a help line from that brand they should able to help more then me but there should be a compartment at the back where the filter is located if you need anymore help contact me at mid.nightclub@hotmail.com
Jan 01, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
