Question about Whirlpool Accubake RF362LXTB (Dual Fuel) Electric Kitchen Range
I have a code E6. What is the code?
My dual oven hasn't worked for a bit. I need to findout whats wrong and the price of getting it fixed.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
The should be another code with the E6 - Fx.
Posted on Dec 03, 2012
  • Arnette Theriault Dec 03, 2012
    yes, i think its e6f2 or something similar. When I push the buttin to bake it makes a beeping sound and nothing happens.
  • Richard Roth
    Richard Roth Dec 03, 2012
    Remove the power from the oven. Open the control panel and unplug the key pad ribbon from the control board. Assemble the control panel back and turn the power on. Wait a few hours. If the error code came back on, replace the control board. If the error code did not show up, replace the control panel (the key pad comes as a control panel assembly). Here is the control board if you need to order it.http://bit.ly/WCYpvq Here is the control panel to order.http://bit.ly/YFPZsB
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
I have a 2000 honda accord v6 3.0 vtec. the engine light come on and the engine shakes. i went to the auto parts store and they told me it was the spark plugs. i the spark plugs in but it shakes a little....
The auto parts store has counter people that
take your money when you buy parts
Some of them may be skilled in auto repairs
but you don't go there for advice
Personally I think for $60 your better off buying
your own code reader & start educating yourself
on OBD2 Systems. You have everything you need
on the internet generically,you just don't have wiring
diagrams & factory manuals you really need.
After the parts store 99% of people pay a shop or
dealer to do the same code checking all over,so skip
that step.
You surely can not believe that with a check light on that
spark plugs are on a list of codes. There not.
Have the codes checked & use the internet to find
out what they refer to.
No code tells you to change a part or what is wrong with a part
You study each sensor or part & learn how to test them
They have to fail a test before they need replacing,common sense
I would think ignition wires on wrong if that applies,or bad ignition
coil,a timing belt that jumped a few teeth,vacuum leaks,egr valve
leaking.
May be faster & cheaper to have it fix this time & be involved
at the shop to learn something
Sep 04, 2012 | 2000 Honda Accord
Displaying E6 & F2 code
F2/E6 fault code implies a Cancel key drive line open. This means the key pad ribbon connector could be loose or dirty where it connects to the oven control board or a faulty oven control board.
Press Cancel. If the error code returns after 60 seconds, replace the key pad. If it continues to display F2/E6 after replacing the key pad, replace the oven control board. The parts can be ordered from Sears PartsDirect
NOTE: Disconnect the power supply from the oven before servicing.
Check additional details in THIS IMAGE LINK.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 13, 2011 | Ovens
Our oven read a problem # E6 F2 what that's mean?
The E6-F2 error code means that the control board thinks there is a problem with the cancel button on the touch pad. Sometimes its due to a loose connection from the ribbon cable on the touch pad. You can push cancel and clear it and if within 5 or under the error code returns the touchpad needs to be replaced. But first check/have the connection checked to make sure its tight. The way modern things work though is grand and Whirlpool say if after replacing touchpad the error code returns once again the clock/control board is what needs to be replaced.
Gene
Aug 11, 2011 | Whirlpool RBD305PD Electric Double Oven
My control panel on a whirlpool oven rbd305pds15 now shows E6 F2 codes and I am not sure what they mean??? How do I fix this?
An F2 E6 error means that there is a problem with the keypad. Make sure that the keypad wire is firmly connected to the control board. Then press Cancel. If the error returns in 60 seconds, you need to replace the keypad. With some Whirlpool ovens the keypad and control board are a single unit and you will need to replace the entire assembly.
For this oven, it seems that the control panel assembly is available here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5139596&diagram_id=28216054 (On the Control Panel diagram, there are three listed - pick the one that matches your oven color.) The price depends on the color option.
I hope this helps.
Jul 08, 2011 | Ovens
Received E6 and F2 code. repair man replaced the control panel key padand it worked for a while. stopped working and got same codes E6 and F2. Repairman saw the control's behind the key pad needed to be...
Hello & Welcome to FixYa
F2-E6 error code indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure then before replacing the sensor you can test it with a voltmeter for around 1100ohms....if it reads more then 1120 ohms then it needs replacement however, if the reading is between 1080-1120 ohms then it is the control board that needs replacement. However, after reading your problem it seems that the sensor is causing this and replacing it is recommended repair. Please get back to me if you have any other questions.
Kevin
Mar 15, 2011 | Whirlpool GBD307PR Electric Double Oven
I have a whirlpool oven which has an error code flashing "E6 F2" the display is coming and going
F2 is most likely the oven temperature sensor. I cant find any reference for E6
Sep 15, 2010 | Ovens
My whirlpool oven is displaying E6 and F2. It
Your cancel key is defective at this point. follow these steps below?
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Aug 08, 2009 | Whirlpool RBS305PDS Electric Single Oven
Error code E6 F2
We repair these control boards frequently. The E6 F2 error is very common for whirlpool ovens and almost always is caused by the control board. It can be repaired quickly and reliably. www.fixyourboard.com
Jul 07, 2009 | Ovens
Whirlpool RbD275pdq10 double oven E6 F2 error
I have a "double oven", Model # RBD275PDQ10 and it has Error Code E6 F2, What is the part that I need to fix it?
Dec 20, 2008 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool Accubake RF362LXTB (Dual Fuel) Electric Kitchen Range Logo
292 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
